Hi, Jay,
We had the same problem and I wrote my "solution" here on the forum a while back.
Here it is:
Greetings to All,
As some of you may be aware, I had previously posted a request for information on how to open the trunk when the last key was locked inside.
Well, thanks to several of you I was able to get the trunk open without any damage and... NO key.
We had lost them both.
So we drive to our Suzuki dealer and they wanted more than $300 to change out all three locks (ignition, glove box, gas cap lock).
Sunrise Cycles
1559 E Little Creek Road Norfolk VA 23518
Phone: 757-583-2223 Fax: 757-588-0813
Well I talked to one of their technicians and he suggested that we haul the bike off to the following locksmith:
ACE Locksmith
7802 Merritt St
Norfolk, VA 23513
(757) 587-1463
That is located one block off (south) of East Little Creek Road just west of Military Highway. If you see the WaWa gas station you are about two blocks away.
As the glove box was not locked he did his majik by unscrewing the lock for the glovebox and fitting his trials to that lock.
And while his initial try got the ignition to work it did not open the trunk. Once I advised him that 3/16th of an inch had to be ground off of each shoulder of the key (which he did at no additional cost) the ignition and trunk locks both worked.
Total cost to fit and make a new key: $35.oo
Total cost for the 2nd, 3rd, and 4th copy: $3.00 each.
Total time from when we drove up with the bike on a trailer until we departed - about 25 minutes.
Small shop, Master locksmith with a big heart.
Go and have your problem resolved. But do remember to have the edge of the key cut back so it works.
Stan Db
