I'm at my wit's end. Had to give a presentation this morning and I was in a hurry to set up. I plugged the serial cable into the wrong port in the back of the project, the Display Out instead of the Display In. From there the screen would flash every 2 seconds. Gave up, got a different computer.
I run a dual monitor setup off my laptop. Simply involves plugging a monitor into the same serial port I used to run the projector, boom- two monitors at once. Despite having this work for the last 1.5 years, after the goof up this morning, my second monitor will no longer work, just a black screen. Both the 2nd monitor and the laptop recognize when I plug in the cable for the monitor, but nothing I do will make the display extended onto the 2nd monitor.
At one point, I made the 2nd monitor the "main screen", in which case both screens went black. After hitting the CTRL-ALT-DELETE buttons a few times I got the login screen to appear briefly on the 2nd monitor. Problem: Colors were pinkish, everything was darker, and it didn't fill the entire screen and it only displayed for about 3 seconds. Rebooting into Safe Mode, and nothing else seems to be working.
At this point I thinking it's a hardware problem, caused by plugging into the monitor out of the projector. I can't find anything on the Epson website about this problem. I do almost entirely GIS work and I REALLY need 2 monitors for this. Any ideas? Is there any other way to do a diagnostic on the VGA port? What's a good computer forum to post on?
