OKO Aftermarket Shock Absorbers
Add ons for the Burgman line. (Windshields, saddlebags, exhaust, etc...)
Moderator: Site Moderators
Postby Gabe502000 » Wed Mar 24, 2010 15:45 15
A Bro. Animal, that's a Bergman owner,+ a member here.Has expressed a desire for a better rear shock absorber. I am the Distributor for OKO Shock Absorbers in this part of the world. If some of you that are in the midst of spring maintenance on your scoot's, both 400 & 650. Would be kind enough to remove a shock absorber,& measure the distance between the mounting hole centers in mm, and post it here. Or, email me at gabe502000@yahoo.com I'm about to place an order with my Vendor in Taiwan for the new 235mm nitrogen/hydraulic 50cc Scooter shocks that look like conventional cycle shocks,they are about to come out with at the end of the month.It may be that they'll be able to source, or mfg, a standard shock that's just a bit taller, for your scooters that will give you a really good ride. Or, one of the new N2/Oil units w/o the tank hanging on it's side, that won't cost you an arm and a leg! I won't know until I get the shock measurements and ask. I got involved in this business because of the crazy high prices people were charging for shocks for my Yamaha C3 SCooter.I Decided to see if I could do something about it & found that I could! Blessings, Gabe
"You never see a scooter parked in front of a Psychiatrist's Office!"....Gabe
Gabe502000
New Member
My Ride: Other scooter
Year model: 2007
Purchase date: 08 May 2008
Current mileage: 5934
BurgmanUSA.com
Re: OKO Aftermarket Shock Absorbers
Postby QuantumRift » Thu Mar 25, 2010 10:54 10
Yea, if I can go pick up good shocks for my truck or car for less than $100 or so, I really don't want to pay $250 for TWO shocks for a scooter. :thumbup:
Clearview XXL Vented shield
KRISS Headlight Modulator
Kisan TailBlazer Brake Light Flasher 20W-D - Plug-In
Manic Salamander Bar End Weights (with throttle lock)
Grip Puppies
3Brothers Backrest
User avatar
QuantumRift
Insane Poster
My Ride: Burgman 650
Year model: 2006
Purchase date: 30 Jun 2008
Current mileage: 24600
Postby Gabe502000 » Thu Mar 25, 2010 21:57 21
Well, How much better does your pickup ride afterward? If I can get the lengths of the Bergman 400 + 650's
shocks, I can tell you what two units will cost. And, I don't expect it to be as much as you think! I don't pay my bills by doing this! :D Gabe
Gabe502000
New Member
Year model: 2007
Postby jbtcajun » Thu Jun 24, 2010 8:26 08
Well what did you come up with?
Looking for a 650 shock that will handle 500 lbs carrying weight.
Every shock I come across doesn't increase carrying weight just a better ride.
650 06 BURGMAN EXECUTIVE:
Hyper-Pro front and rear, Dark-Side, Kisan head and tail light flashers;
Stable air horn, Clearview Xl tented with vent; Givi E52 with light kit and back rest, HJC cl33; Mesh armor pants and jacket; Icon riding gloves; orthopedic boots, Zumo 550,Burgman GRIN
User avatar
jbtcajun
Charter Gold
Charter Gold
My Ride: Burgman 650 Exec
Year model: 2006
Purchase date: 03 May 2006
Current mileage: 31283
Postby QuantumRift » Fri Jun 25, 2010 9:44 09
I don't think anybody posted the specs for him.
As for how my truck rides after I put new shocks on it, well, it rides like it has new shocks on it. :wink:
Grip Puppies
3Brothers Backrest
User avatar
QuantumRift
Insane Poster
Year model: 2006
Postby rtAnimal » Fri Jun 25, 2010 10:08 10
Babe's website is:
http://gabesscooterparts.vpweb.com/
He published his email address in the first post of this thread. TechArtGuy sent Gabe the specs of the shocks for the Burgman 650. I emailed Gabe around a week ago about shocks for the 650. He had not found a supplier of shocks to fit the 650 at the time I had emailed him. You could try giving him a email. I've also been waiting on him to find a good deal on shocks, like he has for the smaller scooters. Any shocks can be sprung for the added weight. It all depends on the spring rate of the shock.
You also need to upgrade the springs in the forks. An option in the forks, is to add air fittings like a Goldwing and a lot of dirt bikes has. Adding air fittings to the forks is cheap and easy to do. It also helps out the overall spring rate of the forks. It doesn't require a very high amount of air pressure. Normally with a air pressure of 5-7PSI you can see a good improvement. The air tends to act as a variable improvement in the spring rate. That is because as the fork is compressed, the internal volume is decreased. Therefore it increases the air pressure. That acts better than any variable rated spring.
Unfortunately for the rear in takes new shocks with higher rated springs or air shocks. Both of these options are more costly than adding air fittings to the forks. In the situation of the shocks with the higher rated springs. It's not as easy to adjust the rate as it is with a set of air shocks. With the air shocks you just need to adjust the PSI setting.
Happy Scøøterïng!
rtÅnïmal
Realize deeply that the present moment is all you ever have. ~ Eckhart Tolle
User avatar
rtAnimal
Insane Poster
Location: Ohio, City is home of the Pumpkin Show ( Circleville ), USA
Year model: 2005
Purchase date: 05 May 2009
Current mileage: 14680
Return to Aftermarket and Accessories
Who is online
Users browsing this forum: Google [Bot] and 1 guest
