BurgmanUSA.com
by v8eyedoc » Mon May 07, 2012 1:09 01
mqracing3 wrote:The left side brake lever--- which I usually use (squeeze in) to start the bike has quit working. So for now I am using the right brake lever and the bike is starting.
How do I go about fixing the left side brake lever interlock? Anyone have the part number I would need and how to change it?
Many thanks.
MSL
What do you mean by - "interlock"........??????
OWNED: 51 HD EL Vespa 55 HD KHK 98 Boss Hoss 2 GSXR-1000's
PRESENTLY OWN: 01 Honda GL1800 08 Burgman AN400 Coocase colormatched handguards heated grips Denali lights "PROUD MEMBER OF THE PATRIOT GUARD RIDERS" "RIDE WHEN IT'S SUNNY - WORK WHEN IT RAINS"
v8eyedoc
- Insane Poster
- My Ride: Burgman 400
- Year model: 2008
- Purchase date: 10 May 2010
- Current mileage: 5340
by Quantum Mechanic » Mon May 07, 2012 4:05 04
He means the rear brake lever brake light switch isn't working properly or at all and it's not completing the starter circuit when he pulls the lever and presses the starter button. It a no go on that switch for engine starting.The only way I would suggest it to replace the brake light switch on that side. It's the safest way. I've just had both brake light switches on my brand new 2012 400zABS replaced under a warranty recall due to the potential for these switches to fail in heavy traffic. Only affected about 442 bikes but was potentially lethal as you brake lights don't work if they fail and you can't start the engine (without bypassing the switch) once you have turned off the engine.
Quantum Mechanic
- Super Poster
- My Ride: Burgman 400 ABS
- Year model: 2012
- Purchase date: 01 Mar 2012
- Current mileage: 3500
by v8eyedoc » Mon May 07, 2012 8:43 08
Quantum Mechanic wrote:He means the rear brake lever brake light switch isn't working properly or at all and it's not completing the starter circuit when he pulls the lever and presses the starter button. It a no go on that switch for engine starting.The only way I would suggest it to replace the brake light switch on that side. It's the safest way. I've just had both brake light switches on my brand new 2012 400zABS replaced under a warranty recall due to the potential for these switches to fail in heavy traffic. Only affected about 442 bikes but was potentially lethal as you brake lights don't work if they fail and you can't start the engine (without bypassing the switch) once you have turned off the engine.
Thanks for the explanation ( in plain English!) I thought that the OP thought that the front & rear brakes were linked....!!
v8eyedoc
- Insane Poster
- Year model: 2008
by rweis » Mon May 07, 2012 15:43 15
I had the same problem a year or so ago.
Go to whomever microfich and ID the little electrical switch that you need to replace. LEFT is DIFFERENT than RIGHT part numbers. Order it. Get it.
2 small screws hold it on, unscrew, switch drops out where you see the electrical connectors to the scoot electrical harness, disconnect, new switch, reconnect (does not matter the order since it is a DC circuit closed / open switch), position, 2 screws back in, done.
Initial swap took about 20 minutes and I take pictures of everything so if I forget something I have a picture of the way it WAS.
Very easy job.
At least the right brake lever would make contact as a backup.
Bob Weis
Bob Weis, Winter Haven (Central), FL, Red 400K8 "Rebekah" "You never see a maxi-scooter parked in front of a Psychiatrist office" ***TRAVEL STOP***Winter Haven, FL
rweis
- Gold Member
- Location: Winter Haven, FL (Central Florida) ***TRAVEL STOP***
- Year model: 2008
- Purchase date: 01 May 2008
- Current mileage: 43000
by Buffalo » Mon May 07, 2012 16:32 16
Just remember that if it is not working to start the bike it is not working to turn on the brake lights either so pull in your right brake lever whenever you slow down until you can get it fixed.
--- Craig AKA Cliffhanger---- "Big Red" 2007 Red Executive - 96,679 miles "Little Blue" 2006 Blue 400S - 38,275 miles "STING" 05 B650 gone but not forgotten, RIP My Gallery
Buffalo
- Lifetime Member
- My Ride: Burgman 650 Exec
- Year model: 2007
- Purchase date: 20 Feb 2007
- Current mileage: 96679
by RashaMatt » Tue May 08, 2012 1:05 01
There's a Suzuki recall for this issue, but I think it only covers the 2012 model.
Peace, Rasha
~ 2012 Burgman 400 ABS, Givi Airflow ~
RashaMatt
- Active Member
- Year model: Other
- Purchase date: 21 Apr 2012
- Current mileage: 1400
by mqracing3 » Tue May 08, 2012 22:01 22
Thanks everyone for your replies. I have to dig out my service manual and find out how to locate, fish out and change this part. It is an intermittent problem--- sometimes it works sometimes it doesn't. In the cases where the left brake lever doesn't allow the engine to start I pull in the right lever and we're off to the races. From the safety points several posters mentioned--- I almost always use both brake levers while riding. And I pay attention to who is behind me and etc. I take it no one else has had this problem on an earlier Burg 400 (like K7, K8, K9, etc). I still love my Burgman 400 to pieces... that won't change
2009 Buell Ulysses XB12XT 2007 Suzuki Burgman 400 2004 Triumph Daytona 955i cafe/streetfighter (for sale) 1984 Moto Guzzi V65SP 1963 SHL M11
mqracing3
- Active Member
- Year model: 2007
- Current mileage: 8700
by v8eyedoc » Wed May 09, 2012 1:26 01
mqracing3 wrote:Thanks everyone for your replies. I have to dig out my service manual and find out how to locate, fish out and change this part. It is an intermittent problem--- sometimes it works sometimes it doesn't. In the cases where the left brake lever doesn't allow the engine to start I pull in the right lever and we're off to the races. From the safety points several posters mentioned--- I almost always use both brake levers while riding. And I pay attention to who is behind me and etc. I take it no one else has had this problem on an earlier Burg 400 (like K7, K8, K9, etc). I still love my Burgman 400 to pieces... that won't change
Perhaps the left brake lever electrical switch can be fixed (since the problem is intermittent) by liberally spraying some electrical contact cleaner onto the switch.??
v8eyedoc
- Insane Poster
- Year model: 2008
by Chet_Benson » Wed May 09, 2012 6:51 06
I saw a recall some place for the brake switch. Check with Suzuki for the recall and your brake lights are not working. Recallhttp://www.suzukicycles.com/Recalls/201 ... witch.aspx
From the hills of Tennessee Welcome to another day the Lord has made 2009 White Burgman 400
Chet_Benson
- Lifetime Member
- Year model: 2009
- Purchase date: 03 Dec 2010
- Current mileage: 2500
Return to Burgman 400 (2007+ model)
Who is online
Users browsing this forum: No registered users and 5 guests
