BurgmanUSA.com
by Elliott Larron » Sat Mar 26, 2011 23:09 23
Strange i did find some Oil in Mines as well Chris, as you said crankcase breather tube is where it's coming from but thats inside the Air Box it should not be leaking out of the Airbox onless there is a Crack or Breach on that Corner someware - On The Second Picture from the look of the Top Cover Seals theres no Oil Getting thru there..
One thing you can Check Chris, is the crankcase breather tube and see if there a Split on the Rubber Tube, to the Airbox.
if it's not coming from inside the underside Airbox it could be leaking from the crankcase breather tube itself and flowing to the under Corner dripping on to the engine.
Gary,
- Attachments
http://burgmanusa.com/gallery/Elliott+Larron/Polini Variator|Polini Clutch | Polini ClutchBell| Yoshimura exhaust |K&N Oil - Custom.K&N Air| NologyHotWires | PowerCommander 3GIVI AF266|AC 400W|JVC CD Radio|3BBR|Stebel TM80|5WMR16 Leds|| Sean Polacik Speedo|HID|VectorVM| MotoBatt
Elliott Larron
- Insane Poster
- My Ride: Burgman 400
- Year model: 2007
- Purchase date: 05 Apr 2007
- Current mileage: 17485
by Daboo » Sun Mar 27, 2011 1:40 01
Your theory sounds good Gary, but I'm at a loss to figure out how it can happen. I could be wrong, but the breather tube opening is on the left side of the air filter box. There is some oil residue going across a small ledge on the back side of the box from the left side to the right. Even if the oil was traveling from the left side at the breather tube up into that ledge and over to the right side, I can't see how I'm getting fresh oil on the bottom of the engine, since everything outside those couple inches in the first picture is dry. Dirty yes, but dry.
In other words, how does the oil in the air filter box, go all the way to the bottom of the engine without leaving a visible trail?
This isn't like I'm spewing oil everywhere, it is more like an annoyance when you want things to be perfect and they aren't. Maybe in 5000 miles, I'm using a couple ounces of oil.
I appreciate the thoughts Gary. If I had it all figured out, I wouldn't have asked the question. Gosh, now you have me wondering. Could the oil seep under the built up dirt and get from up above in the air cleaner box and then show up where it would pool till it dripped off on the bottom? Maybe I should take the bike to one of those car washes with the hand held sprayers and do some cleaning?
Chris
Ebenezer - 2011 Honda NT700V Deborah - 2008 Suzuki Burgman 400 (AN400K8) Barak - 2007 Suzuki Burgman 400 (AN400K7) 48,969 miles. (Gone, but not forgotten.)IBA# 49894 True Rounder = 0-20's - Rounder — to — 100's+ Red Hot Rounder John 14:6
Daboo
- Site Moderator
- Year model: 2008
- Purchase date: 09 Apr 2011
- Current mileage: 26000
by Desert Rat » Mon Mar 28, 2011 16:13 16
Chris Have you cleaned it real well and checked again. Mine has the same type of oil leak but it's coming from were the (2) engine side bolt togeather. I guess it just thinks it's a Harley
Mike 07 400 sold with 46,818 miles 3/23/13 Black 09 650 Exc Bought 3/30/13 7350 miles, grip puppies & Bearcat back rest added. First bike new 1966 blue Honda 175 Scrambler Romans 10:9
Desert Rat
- Gold Member
- My Ride: Burgman 650 Exec
- Year model: 2009
- Purchase date: 30 Mar 2013
- Current mileage: 10088
by Daboo » Mon Mar 28, 2011 16:38 16
I sprayed it down yesterday a couple times with Simple Green and polluted the environment. So yes, I cleaned it.  Now that you mention it, the independent shop I take it to for tire changes, did mention that there was a leak where the two halves of the crankcase join. They offered to fix it for me, but before I do that, I'll sell it and buy another. The repair bill would probably end up as much as the bike is worth.  (While they are good honest mechanics, I think they were hoping I'd pay for a new add-on to their building. Ain't gonna happen.) I was really tempted the other night to sell this Burgman and buy another. There's a brand-new 2008 in black on the Olympic peninsula for $4000. Brand new. And I also like the black color. It would be my second choice for color after the blue. Tempting, but I'm only barely through braking this one in. Chris
Daboo
- Site Moderator
- Year model: 2008
by Elliott Larron » Mon Mar 28, 2011 20:11 20
Did you try tightening the screws first before you make the Plunge, maybe there just Loose,
Gary,
Elliott Larron
- Insane Poster
- Year model: 2007
by bobo44 » Tue Mar 29, 2011 1:34 01
Tightening the screws over recommended torque on important places like this make things worse usually
bobo44
- Active Member
- Year model: 2007
- Purchase date: 29 Sep 2006
- Current mileage: 39999
by Elliott Larron » Tue Mar 29, 2011 1:44 01
bobo44 wrote:Tightening the screws over recommended torque on important places like this make things worse usually
When i had my Old China Vento i had Oil leaks just like that What i did was Put JB Weld around the Seals, and it did work But make the engine Look Nasty onless it's Done Correctly. as a matter of fact i did the same for this Burgman when i found some Cooling Fluid leaking from the Crankcase i JB welded it and had no leaks ever since... Gary,
Elliott Larron
- Insane Poster
- Year model: 2007
by happytech » Tue Mar 29, 2011 9:40 09
I've heard of some riders patching an oil leak with a product called "Water Weld" - it's also by J-B Weld. Yes, it's for underwater but might be a better product than the standard J-B weld stuff.
I’m not afraid to go fast – it’s the crashing and burning that scares me.
Actually, I'm too cheap to go too fast. Have you seen the price of gas lately?
It's SO time for another long road trip!!!
happytech
- Insane Poster
- Year model: 2009
- Purchase date: 22 Nov 2009
- Current mileage: 11575
by Elliott Larron » Wed Mar 30, 2011 8:00 08
Chris, What's The Status of your Oil Leaks What have you Done for it? have you made a Decision what your gonna Do? Gary,
Elliott Larron
- Insane Poster
- Year model: 2007
by Daboo » Wed Mar 30, 2011 10:46 10
Yes, I'll leave it alone and just watch it.
There are some things worth fixing and others worth leaving alone. This is one of those where the payback to fix it, is probably more costly than the bike is worth. Since I'm not losing enough oil to warrant adding any in 5000 miles, it is more of a nuisance than anything.
Chris
Daboo
- Site Moderator
- Year model: 2008
by micbergsma » Wed Mar 30, 2011 11:02 11
micbergsma
- Insane Poster
- Year model: 2007
- Purchase date: 27 Jun 2007
- Current mileage: 43200
by Elliott Larron » Wed Mar 30, 2011 15:07 15
from the look at Mic's Picture that there is a Little Hole where that Plastic Rubber Tube connects to the Airbox, But u guess it never fills with Oil anyway, But i have read Some cases that Oil did fall into that Hole ... Gary,
Elliott Larron
- Insane Poster
- Year model: 2007
Return to Burgman 400 (2007+ model)
Who is online
Users browsing this forum: No registered users and 4 guests
