BurgmanUSA.com
by motorpap1 » Fri May 15, 2009 18:38 18
Majorghan: To the best of my knowledge,after reading the posts on Burgman. there are no Aftermarket Mounting Brackets for hard Bags for the 400; They are made by someone in Germany for the 650 and one on my buddys has them an indeed they are nice. Check the posts under the 650. I would have liked them also but could not find them for a 400 . and after a lot of shopping I bought a pair of so called Soft ons ,on line, from Sams Club. They are black with a Silver Stripe as Throwovers. I attach then under the seat using the Velcro Straps.The cost several month ago was $59.00 are are more than equal to some of the name brands costing$115.00 or more. If you do find the Brackets please post on Burgman because a lot of riders have looked for them.
Ride Safe motorpap1 Mt.Wolf Pa. 09 400 Grey Burg.
motorpap1
- Gold Member
- My Ride: Burgman 400
- Year model: 2009
- Purchase date: 0- 9-2009
- Current mileage: 20500
by spsreef » Sat May 16, 2009 11:15 11
Blue 400K7, 48L Coocase, HID Rt & Silverstar modulated Lt headlamps, Givi windshield, Hand Guards, Dragon Customs riser, Brakeaway, Grip Puppies, ATGATT Hit Air airbag jacket, Arai Quantum/f helmet, Firstgear Escape pants & armored gloves, Tourmaster Response SC boots
spsreef
- Super Poster
- Year model: 2007
- Purchase date: 23 Aug 2008
- Current mileage: 8200
by Blackbeard » Sat May 16, 2009 16:45 16
Spsreef!
Just wanted to say "THANKS SHIPMATE" for those links! I just ordered a set of the Givi Racks for my E21's. BTW, for anyone else ordering, Twisted Throttle only charged me $18 for UPS Ground, whereas Two Wheel Touring wanted $30.
Cheers!
BB
Blackbeard
- Turbo Poster
- My Ride: Other scooter
- Year model: 2009
- Purchase date: 11 Jul 2009
- Current mileage: 293
by DewaltDakota » Sun May 17, 2009 15:17 15
I have the Fehling mounts on my 400, and am about to go outside to remove them, until I can get a replacement spacer and passenger hand rail bolt. I lost one of mine on the first trip out with them. I was going to put blue thread lock on those bolts, but since I wasn't sure if I was going to like the way it makes my Burgman look, I didn't want to make it impossible to remove the upper bolt, without stripping the torx head. The folks at Twisted Throttle are looking into getting me replacement parts from Fehling, but don't know when or if they'll be able to do so. In the meantime, I'm still looking for a local source. Below are a couple of pictures of my Givi E21's on the Fehling side case mounts...
- Rear view
- Side view
So ... when you install them, definitely go with the thread lock on the passenger hand rail, regardless of how long you plan on leaving them on!
Barbara Jo (BJ) 2009 Suzuki Burgman 400 (gray) 2012 Honda Rebel CMX250C
DewaltDakota
- Lifetime Member
- Year model: 2009
- Purchase date: 14 Jun 2010
- Current mileage: 901
by Blackbeard » Sun May 17, 2009 19:16 19
DewaltDakota!
Your E21's look GREAT on your 400! I see that one of the three points is mounted to the Bungee Hook Loop under the seat. Where exactly are the other two connecting points? I'm assuming one of them is under the Passenger Hand Rail Mount? The third point looks like it's bolted to the Passenger Foot Rest. If so, is there any drilling required?
Which bolt and spacer are you missing, the Suzuki Passenger Hand Rail bolt, or the Fehling bolt?
Thanks in advance!
Cheers!
BB
Blackbeard
- Turbo Poster
- Year model: 2009
by DewaltDakota » Sun May 17, 2009 21:00 21
The first thing I did was install the Givi mounts to the Fehling Frame, and test fitted the E21's, to ensure I could easily add and remove them.
The three Burgman 400 attachment points for the Fehling side case frames are (in no particular order): 1) Front of Fehling Frame to rear of the passenger footrest - Lift up the rearmost edge of the rubber floor mat, and remove the short, phillips-head, self-tapping screw. Punch a small hole through the rubber cover, in line with the hole you just uncovered (there's conveniently a square in the pattern on the underside, that aligns with where you need to make the hole). Insert the supplied 12mm long chrome spacer into the (now empty) screw area of the footrest. Take the supplied M5 washer and longer (4.8mm x 38mm) tapping screw through the Fehling Frame hole, through the rubber mat and chrome spacer, and thread it into the footrest hole. Tighten with an 8mm wrench, being careful not to strip the hole.
2) Top of Fehling Frame to underside of passenger handrail - Remove the frontmost small rubber plug from the underside of the passenger grab rail. Carefully feed the supplied M6 x 25mm flat socket head bolt through the Fehling Frame, through the chrome spacer (10mm long), and into the passenger handrail. There is very little clearance to work with, so you might want to use some painter's tape to protect your Burg's body while tightening. I also highly recommend using thread locker, as a) the female threads you're screwing into are about 20mm deep, but you're only going to be getting about 8mm of bolt in there, and b) due to its position, it's prone to work its way loose. It's this bolt and spacer that disappeared, somewhere on my way home from work on Thursday.
3) Rear of Fehling Frame to Burgman tie down point - You should have an M8 x 20mm bolt, an M8 washer, and a funky, oval-shaped chunk of chrome-plated metal left. The bolt goes through the washer, through the Fehling Frame, through the rear tie-down metal loop, and into the threaded hole in the oval-shaped hunk o' metal (flat side towards the tire). Tighten it down with a 12mm wrench.
The only damage you'll be doing during the install, is the 5mm hole punch you need to put in the passenger footrest mat. Everything else uses existing bolt/screw holes.
Let me know if you need me to clarify anything!
DewaltDakota
- Lifetime Member
- Year model: 2009
by Blackbeard » Mon May 18, 2009 17:56 17
Perfect! Thanks BJ! I just received confirmation from UPS today, that my Fehling Rack from Twisted Throttle shipped this afternoon. Can't wait to get it in and installed. Thanks again for the tips, especially the one about the Lock-Tite for the bolts.
Cheers!
BB
Blackbeard
- Turbo Poster
- Year model: 2009
by DewaltDakota » Mon May 18, 2009 19:47 19
No problem! Post pics, when you get yours mounted!!
One thing I forgot to mention... the M6 x 25mm bolts use a 4mm allen/hex key for installation. I incorrectly stated "torx" in my first post.
DewaltDakota
- Lifetime Member
- Year model: 2009
by Blackbeard » Mon May 18, 2009 23:31 23
Thanks again BJ!
I'm currently using a Med-Lrg "Biker's Friend" Roll Bag (WONDERFUL BAG!!!) on the back seat of my Burgy. I have the Sport Saddlebags made by Cortech on the sides, but I don't like the way they're mounted. I do have them on there securely, but I have them as high as they can go, and the bottom of the right bag, is too close to the muffler for my tastes. The bags have heat shields on the bottom of them, but it does tend to get a bit warm after a ride.
Oddly enough, I bought the E21's late last year, when I had my Tow-Pac Trike Kit installed. The E21's were to be mounted on the Tow-Pac Kit, however, I didn't really like the way the Trike setup rode, so I removed it. Since December, I've had the Tow-Pac Kit up For Sale on Craigslist, and I was going to throw the new unused E21's in as a Bonus. When I saw this thread about the Fehling Racks, I said "YESSSSS", and ordered a set. I've since removed the "BONUS" option for the Tow-Pac listing, since I'm keeping the E21's.
I certainly appreciate all of the info, and certainly will post pics when I get them installed next week (they're due in next Tues the 26th, according to UPS.).
Cheers!
BB
Blackbeard
- Turbo Poster
- Year model: 2009
by drjbg » Sun May 24, 2009 10:36 10
A few parts to this post: - I'm amazed that some entrepreneurial Burgmanusa member hasn't come up with a lower priced saddlebag frame for the 400. (If I only knew how to weld...) If Fehling is the only rack out there for the 400, I would think there would be room for competition. Actually, I would think Suzuki would've made something for the bike even if they only sold it in other countries. - I was going to purchase a Mutazu FY hard saddlebag set for $115, but I noticed that the JM series looks like it would fit the lines of the Burgman better. What do you think http://www.mutazu.com/products.php?cat_id=7&menu=Hard%20Saddlebags&product_id=41&s=prod.php Not sure why the JM set is more than twice the cost of the other series, but it is. I've decided on the Wolfman Beta rear soft bag for touring http://www.wolfmanluggage.com/Tail/BetaRearBag.html, but would love to have some more space for commuting (brief case, change of clothes/shoes, etc.) For $450 for the hard cases and frame, I guess they'll have to sit on my wish list a little while longer though.
2008 Red Burgman 400 Suzuki Handguards & Suzuki Side Visor Set Bestem 2012 T-Box Utopia Backrest Dynabeads
Testing a prototype of DOT approved Burgman antenna helmet
drjbg
- Gold Member
- Year model: 2008
- Purchase date: 27 Oct 2008
- Current mileage: 15629
by DewaltDakota » Tue May 26, 2009 20:02 20
I've created my own version of the installation instructions, including a few pictures, if anyone is interested: http://64.235.33.174/dewaltdakota/Fehli ... lation.pdfI make no warranties, expressed or implied, regarding my instructions (i.e., follow at your own risk!) I would have attached it here, but the board doesn't seem to accept "pdf" files.
DewaltDakota
- Lifetime Member
- Year model: 2009
by micbergsma » Tue May 26, 2009 21:55 21
nice... .BB you better show them to me in person someday!
micbergsma
- Insane Poster
- Year model: 2007
- Purchase date: 27 Jun 2007
- Current mileage: 43200
by Blackbeard » Tue May 26, 2009 23:24 23
BJ!You're the GREATEST! I sent you a PM! Thanks again! Mitch!The next time I get up to the Austin area, I'll send you a PM and I can show them to you. Cheers! BB
Blackbeard
- Turbo Poster
- Year model: 2009
by Blackbeard » Sun May 31, 2009 14:25 14
Okay! I installed the Fehling Brackets yesterday, and "BOYYYYY",  were they a bit of a pain. Not much clearance at all in some places to get the tool in to tighten the Bolts. For anyone looking to install a set of these, here are two extra steps I did, in addition to BJ's PDF File (I could "NEVER" have done this without those AWESOME Directions!!! Thanks BJ!!!):1. When installing the Top Center Tab of the Rack to the Burgman, I removed the Front Bolts (under the seat...) from the Left/Right side of the Passenger Handrail. This allowed me to swing the Handrail out a bit, and made it much easier to slip an Allen Wrench in there to tighten the Bolt. 2. I had some Blue Locktite, and added some to the First Bolt for the Top Center Tab of the Rack, but it was drying while I attempted to get the Bolt in. What I did instead, was add some Clear Caulking around all of the Bolts and Nuts, so they'd stay put, and would be easy to remove if I needed to take the racks off in the future. I painted the top of the E21 Cases, Yellow (what else.....), and added some decals to them. Let me know what you think! All-In-All, it was well worth the effort! I took a ride today, got up to 70mph, and the Cases didn't budge an inch. Very sturdy and secure. http://img.photobucket.com/albums/v605/ ... PX1857.jpghttp://img.photobucket.com/albums/v605/ ... PX1858.jpghttp://img.photobucket.com/albums/v605/ ... PX1859.jpgCheers! BB
Blackbeard
- Turbo Poster
- Year model: 2009
by emmettken » Sun May 31, 2009 15:41 15
Looks great BB.
emmettken
- Gold Member
- Year model: 2008
- Purchase date: 13 May 2009
- Current mileage: 0
by DewaltDakota » Sun May 31, 2009 17:40 17
It looks great! I'm definitely planning to paint the lids of my E21's... I just need to "not need them" long enough, to allow them to dry. What method did you use for prepping the surface, before applying the top coat(s)?
I used the blue Loctite gel on my bolt threads, which seems to give you a little more working time, than the liquid version.
(glad to hear my instructions helped, as well)
DewaltDakota
- Lifetime Member
- Year model: 2009
by Blackbeard » Sun May 31, 2009 17:53 17
BJ!I used the Krylon Fusion Spray Paint (made for plastic... No Primer needed...), sold at Walmart. 1 Can was enough for both lids. I let it dry about 15 minutes between coats, and then waited an hour between the Paint and Clear Coat. I did about three coats of Clear Coat, and about two hours later, I removed the Painters Tape and installed them on the Burgy. The only prep I did before I started painting, was cleaning the tops with Alcohol Pads to remove any film, dirt, and grease. Worked like a champ! Thanks again for your help! Cheers! BB
Blackbeard
- Turbo Poster
- Year model: 2009
by DewaltDakota » Sun May 31, 2009 18:30 18
I don't think the Krylon Fusion in burgundy would match Ingrid well enough to get away with it, but I may buy a can and do a test spray on a glad container, just to see what it looks like. Dupli-color has an adhesion promoter/primer, though I don't know if their top color paint will be flexible enough to deal with what I'm looking to use it for. ColorRite is just so expensive, and I've heard mixed results on trying to get the red to come out correctly over the black primer base coat. If only Givi would actually sell the R301 lids that I keep seeing represented in the photos on the sites that sell the cases!
The chrome Fehling frame is a little too "Tah-dah!!! Look at me!!!!" for my tastes, and I want to blend it in with the rest of my bike a bit more. I'm thinking the next time I take my side racks off, I may hit them with the red Dupli-color Metalcast paint, and see if that tones them down.
DewaltDakota
- Lifetime Member
- Year model: 2009
DewaltDakota
- Lifetime Member
- Year model: 2009
by Blackbeard » Sun Jun 21, 2009 11:50 11
BJ!GREAT JOB!!! It's matches close enough, that no one could really tell. Only the "Artist" knows the truth, as they say. Mine's not an exact match either, but as I used to say in the Navy..... "It's close enough for Government Work!"  As for the Chrome Rails, I'm not a Phan of Chrome either. Chrome is kinda funny to work with, so what I may do, is to buy some rolls of colored Bicycle Handlebar Wrap Tape, and see if I can just "Wrap It". Not sure if I'll do anything with it, but the wheels in my head are still turning. Enjoy! Cheers! BB
Blackbeard
- Turbo Poster
- Year model: 2009
by TechArtGuy » Mon Sep 21, 2009 19:09 19
Bit of reviving here, but does anyone have any other model hard case besides the E21. Wish to see photos for reference to make a decision on what to get.....
TechArtGuy
- Site Moderator/Lifetime Member
- My Ride: Burgman 650 Exec
- Year model: 2008
- Purchase date: 12 Apr 2013
- Current mileage: 3918
by Rubble » Tue Sep 22, 2009 23:26 23
Man! you guys are killin' me. Those E21's on the 400 look phenomenal! I've been flip-floppin' back and forth on what to buy for some light touring and those pics are making me rethink the whole thing again. I've always been very fond of the 400 and this makes it even more appealing.
Dave
Rubble
- Turbo Poster
by Stephen Hutchinson » Thu Sep 29, 2011 4:41 04
Guys. Absolutely love the painted lids. Looks smick. Thanks for the painting tips. This is the reason why I joined BurgmanUSA. As a newbie I have learned a lot from the forums - well done. Cheers
Stephen Hutchinson
- New Member
- My Ride: Burgman 400 ABS
- Year model: 2007
- Purchase date: 12 Sep 2011
- Current mileage: 12000
Return to Burgman 400 (2007+ model)
Who is online
Users browsing this forum: Google [Bot], Phorts and 3 guests
