2003-2004 IGNITION SWITCH RECALL
Burgman 650 specific.
Moderator: Site Moderators
Postby bernabeu » Wed Nov 02, 2005 12:43 12
As per the NHTSA and SUZUKI RECALL NO. 2082:
ALL 2003 models are affected
2004/400: through *42101092
2004/650: through *42101022
required replacement part: Kit # 99103-11199
(the proper replacement switch terminal case can be identified by a black line on the coupler case)
dealer should have special tool (PN 99103-11200) on hand (free from Suzuki) as well as the TSB (GV/AN Bulletin No. 20 - 9/1/2005)
UNLESS YOU PERSONALLY KNOW THE ORIGINAL IGNITION SWITCH WAS NEVER (I MEAN NEVER, EVER) PLACED BETWEEN OFF AND ON ACCIDENTALLY THE BIKE IS NOT SAFE TO RIDE UNTILL IT IS REPLACED
bernabeu
Super Poster
My Ride: Other scooter
Current mileage: 0
BurgmanUSA.com
Postby apleschu » Wed Nov 02, 2005 15:48 15
Any idea what the problem is?
Andreas Pleschutznig
Chief Cat Herder for BMWLT.com, k-bikes.com and a couple of other sites
IBA: #9451
'05 AN650K5
Houston, TX
User avatar
apleschu
BurgmanUSA Supporter
My Ride: Burgman 650
Year model: 2005
Current mileage: 20000
Postby Selias » Wed Nov 02, 2005 15:54 15
A search for 'ignition recall' (all words) will result in quite a bit of posts on this. Look HERE (newer summary of THIS THREAD) for some good info on the problem and why there is a recall.
Here are vfdcaptain's AWESOME photos which will give you a better idea of why there is a recall... http://burgmanusa.com/gallery/album89
here's a thumbnail off page two:
And this is a GOOD example of why these BUSA forums are such a great thing! Thanks to vfdcaptain (and I believe others) we knew about this problem before just about anyone and I personally believe members of this forum were instrumental in this particular recall being issued (at least in the USA)? :D
In essence the problem with the ignition switch (as I understand it) is not having the switch all the way ON has created a 'shorting'/overheating problem on older models (2003 and part of 2004) which can create an unsafe driving condition or prevent ignition switch usage. Definately worth have the recall done if your model is one of the ones listed in the recall!
-Stu-
Gallery Pics
(\__/)
(")_(")* Come home SAFE!
User avatar
Selias
FAQ Team Member
Year model: 2006
Purchase date: 01 Jun 2006
Current mileage: 27000
Postby Brian » Thu Nov 03, 2005 3:33 03
apleschu wrote:Any idea what the problem is?
As Selias said.
One of the contacts in the switch was too small on the early 250s, 400s, and 650s, and if the key was not turned completely on there could be arcing with possible meltdown.
Even if the key was turned all the way to start, vibration or a bump of the knee could nudge it off the detent.
The biggest problem was that engine power and all lights could suddenly quit without warning. Not a good thing if you're hard into a turn in the middle of the night.
—Brian— Quo Fas et Gloria Ducunt
Silver AN650K3 since June 9, 2004.
CH250 Elite '85 - '87
CH125 Elite '84 - '85
User avatar
Brian
Insane Poster
Year model: 2003
Purchase date: 09 Jun 2004
Current mileage: 25000
Postby pirmil » Thu Nov 03, 2005 6:39 06
sorry... "eternal english beginner" :oops:
AN650 k6 Silver 64000 km (since March 16, k6)
AN650 k3 green 58000 km (36000 Mi) sold
www.pirmil.info ->Suzuki AN 650 & Piaggio X9 500 web site
User avatar
pirmil
Super Poster
First the switch -- now the switch plug
Postby dcook8222 » Thu Nov 03, 2005 13:53 13
I took my 2003 AN650 to the dealer and they performed the ignition switch replacement under the recall. Then starting a week later the ignition was cutting out while running and I was getting the F1 error lights when trying to start it. I took it back to the dealer and the "dealer mode" diagnostic pointed to the ignition switch not getting proper power to the computer module.
The mechanic discovered that when the ignition switch overheated it warped the plug that mates to the back of the ignition switch. Suzuki does not sell the plug -- the solution replace the entire wiring harness. Then Suzuki informs me the wiring harness is backordered for three weeks! I assume I am not the only one with this issue.
If you have the recall performed, get the dealer to check the plug for the back of the ignition switch, for heat damage.
In an attempt to get my Burger on the road I am looking at finding a wiring harness through salvage channels. If you have any resources let me know.
Dwight
User avatar
dcook8222
Postby Brewman » Thu Nov 03, 2005 15:12 15
Would the recall or any kind of warranty pay for the wiring harness or it's installation? That could get rather expensive, I'd imagine.
Brewman
2005- Burgman 650- One of the faster Silver ones
User avatar
Brewman
Site Moderator
Site Moderator
Year model: 2005
Purchase date: 01 Mar 2005
Current mileage: 10000
Reall and wiring harness
Postby dcook8222 » Thu Nov 03, 2005 15:48 15
Suzuki said they will pay for the wiring harness. It is a result of the recall ignition switch failure on my Burgman 650. I do hate to have the scooter in the shop for 3-weeks!
Dwight
User avatar
dcook8222
Postby Sails » Thu Nov 03, 2005 16:20 16
There is a Canadian recall as well. I emailed Suzuki Canada with my VIN and got a reply that told me to call my dealer.
Interesting, I just put my bike into storage for the winter, I guess I will have to call and see if I can do it in the spring or whether I have to pull the bike out.
Knowing my luck it'll be at the dealer and we will get 3 feet of snow!
Ken , Silver 650
Criticism never built a house, wrote a play, composed a song, painted a picture, or improved a marriage.
User avatar
Sails
Year model: 2004
Purchase date: 0- 7-2004
Current mileage: 0
Recall, time and winter
Postby dcook8222 » Thu Nov 03, 2005 17:08 17
Ken, I would check with your dealer. Usually there is a window in which a recall can be applied. As far as putting up my Burgman for the winter ... I'm in Houston and can ride year-round. I am just putting up my bike for the recall. :?
Dwight
User avatar
dcook8222
Re: Recall, time and winter
Postby Sails » Fri Nov 04, 2005 11:31 11
dcook8222 wrote:Ken, As far as putting up my Burgman for the winter ... I'm in Houston and can ride year-round. I am just putting up my bike for the recall. :?
Nothing personal,
I hate you! :naka:
I hate you! :naka:
I hate you! :naka:
Ken , Silver 650
User avatar
Sails
Year model: 2004
Current mileage: 0
Return to Burgman 650
Who is online
Users browsing this forum: Google Adsense [Bot] and 9 guests
