Burgman 650 specific.
BurgmanUSA.com
by Socal Local » Sat Jun 23, 2012 0:06 00
Ken, Congrats on a tough job well done. How did you end up torquing the secondary shaft nut?
R in OB
Socal Local
- Active Member
- My Ride: Burgman 650
- Year model: 2007
- Purchase date: 03 Oct 2011
- Current mileage: 21000
by Ken » Sat Jun 23, 2012 10:01 10
Socal Local wrote:Ken, Congrats on a tough job well done. How did you end up torquing the secondary shaft nut?
R in OB
I wish you had not asked that question as I am sure I will be chastised for the way I did it. But you did ask so I will answer. Per the book, I used blue thread locker and I went into the back of one of my tool cabinets and dug out an old air impact that on a good day will deliver 175 lbs torque at 120 PSI. I set the air regulator at 115 PSI to slightly decrease the torque the impact could give. I held the adapter with a strap wrench and let the impact do the rest. I really don't know the exact torque I put on the nut although I am probably close enough for govt work. Let the flames begin but I'd bet I am very close to spec. I did use a torque wrench to torque the new bolt at 65-70 lbs. That bolt also got a dose of blue thread locker.
Ken
Blue 2003 Burgman 650
Ken
- Charter Gold
- Year model: 2003
- Current mileage: 0
by Dave_J » Sat Jun 23, 2012 10:12 10
Ken, its to GERMAN spec's, Gutentight.
"Never mount a passenger car tire on a motorcycle rim; the flat profile of a car tire is incompatible ....."
TOTALLY HOG WASH!!!
50,000 miles on a CAR TIRE/DARKSIDE.
***TRAVEL STOP***
Dave_J
- Insane Poster
- Location: Auburn WA Where God takes Vacation. ***TRAVEL STOP***
- Year model: 2008
- Purchase date: 24 Dec 2010
- Current mileage: 37000
by LeDude » Sat Jun 23, 2012 10:25 10
LeDude
- Insane Poster
by MJR » Sat Jun 23, 2012 10:29 10
I think it's more likely a dealer mechanic would just use an impact rather than a torque wrench anyway.
'09 White 650 my regular ride, Yoshi Carbon/Stainless Exhaust, Bazzaz Z-Scoot Fuel Control '06 Gray 650 new project bike, CVT to fix '05 650 stripped down/rebuilding back up '03 Blue 650 stripped CVT primary pulley splines/failed bearing, fixing and upgrading in process '03 Blue 650 parts bike
MJR
- Insane Poster
- Year model: 2009
- Purchase date: 28 Apr 2011
- Current mileage: 20700
by Socal Local » Sun Jul 15, 2012 13:06 13
Help!!!?/
I dont know what bolt Ken is talking about. There are none on the secondary and my manual and Le Dude say the primary shaft bolt is torqued to 46.5 lb-ft. What is torqued to 70 lb-ft? I am about to torque my primary shaft bolt (on the port side of Suzie) and now I am worried. My manual had the bolt in the wrong place, does it have the torque spec wrong too?
R in OB
Socal Local
- Active Member
- Year model: 2007
by Buffalo » Sun Jul 15, 2012 13:11 13
46.5 ft-lb is correct for your 07 650. The higher value is for the 03 and 04 models. dangit got that backwards  . 46.5 is for the 03 and 04 models. My manual says 67.5 for the 05 and later models.
--- Craig AKA Cliffhanger---- "Big Red" 2007 Red Executive - 96,679 miles "Little Blue" 2006 Blue 400S - 38,275 miles "STING" 05 B650 gone but not forgotten, RIP My Gallery
Buffalo
- Lifetime Member
- My Ride: Burgman 650 Exec
- Year model: 2007
- Purchase date: 20 Feb 2007
- Current mileage: 96679
by MJR » Sun Jul 15, 2012 13:29 13
Buffalo wrote:dangit got that backwards  . 46.5 is for the 03 and 04 models. My manual says 67.5 for the 05 and later models.
Yup 46.5 lb-ft for '03-'04 and 67.5 lb-ft for '05-'12.
MJR
- Insane Poster
- Year model: 2009
by Ken » Sun Jul 15, 2012 13:37 13
Buffalo wrote:46.5 ft-lb is correct for your 07 650. The higher value is for the 03 and 04 models. dangit got that backwards  . 46.5 is for the 03 and 04 models. My manual says 67.5 for the 05 and later models.
Craig, you scared me for a minute that I may have torqued the wrong value on the 06. I did get it torqued correctly at 65-70 lbs. As a follow-up, my friends bike is doing great and has 700+ miles on it and no issues. We haven't done very much riding for the past few weeks as heavy rains doesn't seem to want to stop.
Ken
Ken
- Charter Gold
- Year model: 2003
by Buffalo » Sun Jul 15, 2012 14:20 14
Realized it as soon as I posted but it took me a minute to double check the manual and post the correction. Ken you guys have been getting a bit of rain for the last few days  .
Buffalo
- Lifetime Member
- Year model: 2007
by Socal Local » Tue Jul 17, 2012 0:08 00
I just discovered a posting that the guidance from Suzuki is to replace the primary pulley shaft bolt each time you take it out. After researching "single-use fasteners" on the web it seems to me this bolt does not qualify. Generally you throw away a bolt after one use if it has a special coating (corrosion prevention or threadlock) or it is a TTY (torque to yield) which generally means the instructions are torque it to spec and then add some degrees of turn. One example given was almost humorous:
Here is an example of what occurs when replacing the cylinder head bolts on one vehicle maker’s engine. The steps must be done in a specific sequence and if the sequence is not followed, the bolt can break, causing damage and difficult removal.
The six steps are as follows: 1. Tighten to 40 N•m (30 ft-lb). 2. Tighten an additional 90°. 3. Loosen 360°. 4. Tighten to 40 N•m (30 ft-lb). 5. Tighten an additional 90°. 6. Tighten an additional 90°. These fasteners become misshapen and cannot be reused because of the excess amount of stress that was forced on them during installation
R in OB
Socal Local
- Active Member
- Year model: 2007
by LeDude » Tue Jul 17, 2012 12:08 12
There are definitely two torque values for this bolt, page 14-45 in the supplemental section for the 05 model has the new torque value for the 05+ models
03/04 models ----> Primary Pulley Shaft Bolt: 64 N-m (6.4 kgf, 46.5 lb-ft)
05+ models -------> Primary Pulley Shaft Bolt: 93 N-m (9.3 kgf, 67.5 lb-ft) ) 05+ models
LeDude
- Insane Poster
Return to Burgman 650
Who is online
Users browsing this forum: No registered users and 3 guests
