Removing the front box.
Burgman 650 specific.
Moderator: Site Moderators
Postby asolof » Sat Feb 25, 2012 16:36 16
To change the cooling fluid I want to remove the front box. I removed all the screws, the parking brake handle, and the connectors for the accessory plug. It seems the be blocked where it abutts against the perforated front center section of the foot board. Is there some trick in removing this?
Arnold Solof
2009 B650
2006 B400 - 36000 miles - Sold 4/25/2010
User avatar
asolof
Lifetime Member
Lifetime Member
My Ride: Burgman 650
Year model: 2009
Purchase date: 12 Aug 2009
Current mileage: 15857
BurgmanUSA.com
Re: Removing the front box.
Postby snakehomsi » Sat Feb 25, 2012 16:52 16
No need for all of that,,,check this
https://docs.google.com/View?docid=dgnd ... gd=1&hl=en
snakehomsi
Active Member
My Ride: Burgman 650 Exec
Year model: 2006
Purchase date: 10 Oct 2006
Current mileage: 55000
Postby asolof » Sat Feb 25, 2012 17:22 17
Yes,
I'm using LeDude's site plus the Suzuki manual. I must be doing something wrong though.
Arnold Solof
2009 B650
User avatar
asolof
Lifetime Member
Lifetime Member
Year model: 2009
Postby Jim » Sat Feb 25, 2012 18:14 18
The only thing I recall removing was the black radiator cover in the front, and the hump cover. I had enough access to do the job from there.
Pictures of Modifications and Accessories
Jim's Photo Gallery
User avatar
Jim
Site Moderator
Site Moderator
Year model: 2003
Purchase date: 23 Sep 2003
Current mileage: 40000
Postby Buffalo » Sat Feb 25, 2012 19:11 19
Did you removed the 2 screws inside the main glove box?
--- Craig AKA Cliffhanger----
"Big Red" 2007 Red Executive - 96,679 miles
"Little Blue" 2006 Blue 400S - 38,275 miles
My Gallery
User avatar
Buffalo
Lifetime Member
Lifetime Member
Year model: 2007
Purchase date: 20 Feb 2007
Current mileage: 96679
Postby Buffalo » Sat Feb 25, 2012 19:15 19
There is a hook right in the center that hooks it to the tunnel cover that you have to wiggle a little to get to release.
My Gallery
User avatar
Buffalo
Lifetime Member
Lifetime Member
Year model: 2007
Postby asolof » Sat Feb 25, 2012 21:33 21
<<The only thing I recall removing was the black radiator cover in the front, and the hump cover. I had enough access to do the job from there.>>
You are right. Removing the front box is unnecessary.
THANKS!
Arnold Solof
2009 B650
User avatar
asolof
Lifetime Member
Lifetime Member
Year model: 2009
Postby asolof » Sat Feb 25, 2012 21:35 21
<<Did you removed the 2 screws inside the main glove box?>>
Yes.
Maybe I didn't giggle it right. In any case, I was able to change the coolant without removing it so I just screwed it back.
Arnold Solof
2009 B650
User avatar
asolof
Lifetime Member
Lifetime Member
Year model: 2009
Postby ErikDK » Sat Mar 23, 2013 10:38 10
I can't get the sucker off as well.
I looks so easy in LeDudes video.
Maybe the mechanic did something wrong when he installed a new one after my crash.
It seems to be sticking at the nose of the center glove compartment.
Suggestions?
Mileage is in kilometers
EC-2000 electronic cruise control operated from Executive screen switch
Oxford heated grips
Custom-made true cartridge fully adjustable fork.
SpeedoHealer for speedo healing
SpeedoHealer for healing the CVT
ErikDK
Insane Poster
Year model: 2007
Purchase date: 28 Jun 2010
Current mileage: 29000
Postby NormanB » Sat Mar 23, 2013 11:08 11
Erik
I had no problem with mine after following Le Dudes instructions.
Maybe your chap has zip tied something!
An expert = ex is a has been and a spurt is a drip under pressure.
AN650AL0 (new toy)
AN650K4 (Av 44mpUSG) (Sold 11/4/2010)
AN400 - 2001 (Sold 8/13/05)
Norm's Pics
User avatar
NormanB
Year model: 2010
Purchase date: 04 Nov 2010
Current mileage: 3000
Postby LeDude » Sat Mar 23, 2013 11:32 11
I just finished updating the DIY doc and added the video link to it.
Tupperware - Front Box
There are a total of six screws that hold it in place, make sure you have removed them all.
You also have to remove the 12 volt connector and disconnect the wires.
Don't forget the emergency brake handle.
I personally always remove my Leg Shield before removing the Front Box, just less of a chance to break tabs etc.. but one can do otherwise.
You may want to pay attention to the way the front box and floor board interconnect at their bases, and make sure that there are no screws holding
them in place where the two pieces connect.
Otherwise, it is a rather simple piece to remove.
good luck.
Happy Riding . . . . .LeDude's Burgman Center
LeDude .... . . . . . . . LeDude's Burgman Center Blog
. . . . . . . . . . . . . . . . LeDude's Burgman Center Video Library
User avatar
LeDude
Insane Poster
Current mileage: 0
Postby ErikDK » Sat Mar 23, 2013 12:37 12
Well, it's off now, but I broke it at the top right corner of the fuse door opening. :banghead: :banghead: :banghead:
Afterwards, I practiced with the front box that was damaged in my accident, and it was still a fight.
Loosening the floor board made it much easier, and I wonder if I should take off the floor board before trying to re-install the front box, or if tha floor board has its own issues?
Oxford heated grips
ErikDK
Insane Poster
Year model: 2007
Return to Burgman 650
Who is online
Users browsing this forum: Google [Bot] and 5 guests
