Burgman 650 specific.
BurgmanUSA.com
by jenkins » Fri May 06, 2011 0:31 00
I see no reason you can't use it on the 400, also. Tks, LeDude!!  Jim
jenkins
- Turbo Poster
- My Ride: Burgman 400
- Year model: 2008
- Purchase date: 10 Jan 2011
- Current mileage: 7100
by LeDude » Fri May 06, 2011 0:39 00
jenkins wrote:I see no reason you can't use it on the 400, also. Tks, LeDude!!  Jim
I am not at all familiar with the 400...the retrofit design principals should apply equally if it has a similar air filter.
LeDude
- Insane Poster
- My Ride: Burgman 650
- Current mileage: 0
by Dave_J » Fri May 06, 2011 1:28 01
I made my own years ago using "UNI" green foam and RTV.
"Never mount a passenger car tire on a motorcycle rim; the flat profile of a car tire is incompatible ....."
TOTALLY HOG WASH!!!
50,000 miles on a CAR TIRE/DARKSIDE.
***TRAVEL STOP***
Dave_J
- Insane Poster
- Location: Auburn WA Where God takes Vacation. ***TRAVEL STOP***
- Year model: 2008
- Purchase date: 24 Dec 2010
- Current mileage: 37000
by Max T » Fri May 06, 2011 4:50 04
Max T
- Super Poster
- My Ride: Burgman 650 Exec
- Year model: 2007
by LeDude » Fri May 06, 2011 11:19 11
Max T wrote:This is how I Made mine
Nice job, I like the metal clip idea, I may have to borrow that for my second generation retrofit kit.
LeDude
- Insane Poster
by Valerio » Fri May 06, 2011 13:19 13
LeDude:
I think it's more convenient to buy that "Uni" green foam that is used for filters, similar to lawn mowers, etc.
I purchased a roll at the local foam shop for dirt cheap and I used it for my 400 b/4 buying a 650 in '09.
With this product you would just cut to fit inside the frame, insert and voila ?????
....My two cents. I already did this several times on the 650.
Valerio
"If you're not the lead rider the scenery never changes"
Valerio
12 Burgman 650 Exec 09 Burgman 650 Exec(Sold) - Clearview Windshield - Izuzu Back Rest - Puppie Grips - Breakaway Cruise Control 07 Burgman 400 (sold)
Valerio
- Super Poster
- Year model: 2012
- Purchase date: 10 Apr 2012
- Current mileage: 6000
by LeDude » Fri May 06, 2011 14:42 14
LeDude
- Insane Poster
by LeDude » Fri May 06, 2011 14:45 14
Valerio wrote: ... I think it's more convenient to buy that "Uni" green foam that is used ...
I wanted to stay with a paper element like the one used in the OEM filter, the folks at Suzuki would have used an all sponge filter if they deemed it to be more efficient. I am sure both solutions would work equally well...
LeDude
- Insane Poster
by born1928 » Sat May 07, 2011 15:51 15
Great work Le Dude. I was hoping something like this would spring up on this forum. There was a similar project on the Honda Pacific Coast site which I used as a substitute for the OEM filter on my PC. The main difference was the addition of caulk around the perimeter of the DIY filter. May not be necessary with your method. When it's filter change time I will use your idea.
born1928
- Super Poster
- Year model: 2007
- Purchase date: 15 Sep 2011
- Current mileage: 20
by LeDude » Sat May 07, 2011 17:53 17
born1928 wrote: ... The main difference was the addition of caulk around the perimeter of the DIY filter. May not be necessary with your method. When it's filter change time I will use your idea.
I went through a few design alterations before deciding on the foam frame, it has proved to be the most reliable thus far, stays in place well and puts enough pressure on the paper element to hold it in place via friction. I thought about using some sort of sealant, but in the end after 1k miles of testing it became clear that the foam frame was going to do the job. One options was to put some kind of sealant or hot glue along the curved edges of the paper element before inserting it into the foam frame, it turned out to be too messy and didn't work very well, limited one's flexibility when it came time to adjust the paper element inside the foam frame. the foam frame fits very snuggly against the edges on the inside of the air filter where the old paper element used to be. I tried to blow / suck some dirt through the setup but nothing made it past the foam or the paper, and I used a very generous amount of small debris. I made 10 of them and should be set for the next 50k miles, I am going to change my air filter every 5k miles when I change the oils on the bike. let me know how it works out for you.
LeDude
- Insane Poster
by poldark » Mon May 09, 2011 8:53 08
Not quite as budget conscious as your excellent solution, but I'm just waiting for this EBay purchase to arrive. At the price I thought it was worth a shot, not 100% till I've dismantled existing filter but having had a quick look I'm hopeful that this would near enough just slot straight in (200mm x100mm x15mm). http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=250811447855&ssPageName=STRK:MEWNX:IT#ht_1410wt_905Any thoughts about whether the claimed airflow increase will be something the ECU can accommodate, or could this have any issues to engine longevity because it may end up running too lean. I've assumed (dangerous!) that any airflow increase would be relatively small (despite marketing claims).
poldark
- Super Poster
- Year model: 2003
- Purchase date: 12 Sep 2009
- Current mileage: 25274
by poldark » Wed May 11, 2011 8:30 08
Bit too early to say but on a short test ride I thought (placebo?) it rode a bit smoother, but then the old filter was pretty grubby. Either way it cost £2.49 and a bit of time to remove the old paper insert and trim the glued remains, plus trim the small amount to get the off-the-shelf piece to fit. Next time an easy swap out and saves tons on either OEM (£30) or Pattern filter (£20). Old filter -  Paper removed and trimmed -  Supplied foam piece trimmed and inserted -  I don't have anything specifically holding the foam in place, but I made sure to not cut it too small, so I'm expecting it to remain in situ, did a quick check after the test ride and all fine. Should I be worrying it somehow works loose, given the direction of the airflow I can't see it being a danger?
poldark
- Super Poster
- Year model: 2003
by LeDude » Wed May 11, 2011 10:14 10
poldark wrote:Bit too early to say but on a short test ride I thought (placebo?) it rode a bit smoother, but then the old filter was pretty grubby ...
looks good, I doubt that the foam will work its way up, especially with the fuzzy stuff left behind by the old filter on the sides ... you can always add two retaining clips like max-t did, very easy to do...
LeDude
- Insane Poster
by poldark » Wed May 11, 2011 11:53 11
Yes just paranoia on my part I think. I have to say I must have spent half an hour with my wife's best nail scissors trimming off the excess "fuzzy stuff" as I was worried it would get sucked in, so there's not too much there but as you say it 'll actually help keep the new foam seated.
poldark
- Super Poster
- Year model: 2003
by NormanB » Wed May 11, 2011 12:43 12
My word,I thought I was cheap! Much as I admire this innovative initiative, personally I would be nervous of following suit. My concern is the potential bypassing problem. Not sure how we could go about measuring or even if it is practical to detect a true pressure drop, but it would involve drilling and mounting stubs to hook up a manometer. Never mind look forward to the DIY oil filter.
An expert = ex is a has been and a spurt is a drip under pressure. AN650AL0 (new toy) AN650K4 (Av 44mpUSG) (Sold 11/4/2010) AN400 - 2001 (Sold 8/13/05) Norm's Pics
NormanB
- Administrator
- Year model: 2010
- Purchase date: 04 Nov 2010
- Current mileage: 3000
by poldark » Wed May 11, 2011 13:12 13
Maybe I didn't make it clear but the "foam" is motorbike air filter specific replacement material with I suspect greater filtering capability than the original. I have concern on airflow and eventual air/fuel mix, particularly as mine is an early bike with no Lambda sensor on the exhaust (IIRC). The only danger to me is it runs too lean and may cause damage long-term, would appreciate any views.
poldark
- Super Poster
- Year model: 2003
by LeDude » Thu May 12, 2011 19:40 19
 was looking at your pictures again and a thought popped into my head. You may want to use some of the scrap pieces and cut them width wise and put them under the big piece to make the top of the foam flush with the rim of the air filter carcass... that way, nothing can get in there and it won't act as a trap for unwanted debris.
LeDude
- Insane Poster
by poldark » Fri May 13, 2011 5:15 05
LeDude wrote:Was looking at your pictures again and a thought popped into my head.
That's a good thought, the only worry for me is by doing that it will expose the remains of the original filter at the lower section on the housing. At the moment the exposed part is at the top, which is "above" the filter so any loose bits wouldn't get sucked into the engine. I hope with all my nail scissor efforts there aren't any stray bits of fluff, but I sorta like the fact the new foam is flush at the base of the holder sealing it neatly against the mesh underneath. Hope my logic makes sense, appreciate any thoughts you have on the air/fuel mix by using air filter foam rather than OEM filter, I'm not risking any engine issues am I? Thanks for your inspiration and excellent maintenance materials.
poldark
- Super Poster
- Year model: 2003
by fred122333 » Fri May 13, 2011 9:39 09
I really like the idea of making our own replacement air filters. However, when I looked for air filter material, I find all kinds of material rated 35 ppi, 40 ppi, 50 ppi, 65 ppi. So, anybody know which ppi material I should acquire.
Thanks for the great ideas......and, keep em com'n.
2008 Burgman 400 Red
fred122333
- Gold Member
- Year model: 2008
- Purchase date: 28 Apr 2008
- Current mileage: 4678
by poldark » Fri May 13, 2011 11:03 11
Perhaps little use as this is a UK supplier, but I just called RamAir who supplied the filter piece I used (EBay link above) and they advised the structure has 2-tier make-up. 10mm of 45ppi material then 5mm of denser 60ppi. They highlighted that the key factor in any filter is it's flow density (ability to stop airborne particles) and were proud of the fact that they have a patented dry oil facility so achieved 99.4%, whereas average paper filters start at 81% and reduce as they clog up. No idea how accurate these claims are, but I basically spent £2.49 instead of £20/30, it runs well and I'm happy. But when my engine blows up you can all laugh at me!
poldark
- Super Poster
- Year model: 2003
by Bazza » Tue May 17, 2011 1:07 01
Uni Filters are madein a factory unit about 10km from me so I rode over to buy some of the "real" filter foam for the mod. Guess wot??? They wouldn't sell it to me, saying the extra airflow could weaken the mixture and cause burnt valves! Perhaps they were'n aware that Burger has EFI cos I reckon EFI is clever enough to compensate for the additional air. Anyhow, I never got around to it. Paper mod looks good.
Bazza
- Super Poster
by LeDude » Tue May 17, 2011 11:57 11
Bazza wrote: ... They wouldn't sell it to me, saying the extra airflow could weaken the mixture and cause burnt valves! Perhaps they were'n aware that Burger has EFI cos I reckon EFI is clever enough to compensate for the additional air. Anyhow, I never got around to it. Paper mod looks good.
That's good information to have, thanks for sharing.
LeDude
- Insane Poster
by Dave_J » Tue May 17, 2011 22:59 22
LeDude wrote:That's good information to have, thanks for sharing.
I made my own air filter using 5/8 " UNI green foam. I dident blow up the engine or burn any valves. Bazza, I still have some but post to you would be too much.
TOTALLY HOG WASH!!!
***TRAVEL STOP***
Dave_J
- Insane Poster
- Year model: 2008
by Bazza » Wed May 18, 2011 1:53 01
Thanks for your kind offer Dave but you're right about the freight, I've just bought some stuff from a couple of different shops in the US, had the items sent to "Bongo" where they cosolidated the packaging and air freighted it to me (DHL), cost.......wait for it,,, $159 USD, takes the shine off buying in the US even though our dollat is about $1.06US. Regards.
Bazza
- Super Poster
Return to Burgman 650
Who is online
Users browsing this forum: Google [Bot] and 2 guests
