Burgman 650 specific.
BurgmanUSA.com
by Colchicine » Mon Jan 26, 2009 8:42 08
You may not have read everything  ... search for "rollingbones" as he has posted pictures and a full description of how to run the wire in an Exec mirror. Sorry I don't have the link on hand. I did it the hard way and removed the mirrors. If you do find it, post it here. Good luck!
Colchicine
- Knowledgebase Manager
- My Ride: Burgman 650 Exec
- Year model: 2007
- Purchase date: 24 Feb 2007
- Current mileage: 22000
by paulcbrowne » Mon Jan 26, 2009 12:11 12
This looks like the link that you referred to: viewtopic.php?f=19&t=21429&p=197413&hilit=+mirror+exec+lights#p197413But, I'm trying a different approach that replacing the single filament 1156 bulb with a dual filament (1157) bulb -- LED 1156 (single contact) LED bulb with the Magic Blinkers and balancing resistor. I was just trying to find where those dang turn signal wires are inside the tupperware.
Shepherdstown, WV USA 2011 Suzuki Burgman 650 Exec
paulcbrowne
- Lifetime Member
- Year model: 2011
- Purchase date: 24 May 2011
- Current mileage: 10
by Colchicine » Mon Jan 26, 2009 12:32 12
You found the post, thanks for digging that up. I'll be sure to add it to my index this time.
Don't be afraid to take the tupperware off. You could probably get to the wires with just the top dash off, but it wouldn't be a bad idea to take off the headlight section either. Just as simple as tracing the wires.
Colchicine
- Year model: 2007
by paulcbrowne » Mon Jan 26, 2009 18:50 18
Ha, stripping off the tupperware can't be any worse that on my BMW K1200LT that I used to strip down annually! Just hoped to avoid the "learning experence" on the Burgman. It's a bit hard to trace the wires and they changed the '08 harness and routing as I examine the manual. Now, if that wiring diagram wasn't so small!
paulcbrowne
- Lifetime Member
- Year model: 2011
by paulcbrowne » Wed Jan 28, 2009 8:53 08
I found the two plugs for the right and left turn signals. I had removed the upper dash with the small cubbies, handlebar covers, but what really helped was taking off the nose piece above/between the headlights. It comes off very easy after -- there are 5 straight-in push connectors that can be pried up easily with a screwdriver and a piece of cardboard to keep from scratching the paint. I had taken off the windshield but that was unnecessary.
The turn signal plugs are cabled tied to another set of wires on the crossbar that easy to see with the nose off. The plugs for the turn signals have an oval cross-section. The other wires have a squarish connector -- assume those are for the mirror motors. Left turn signal is black for hot and black/white for ground. Right turn signal is light green for hot and black/white for ground.
I found it easiest to see and disconnect the turn signal plugs after I unplugged and pushed aside all of the other connectors under the removed nose piece.
One thing I did for testing was to use Posi-connectors that could be undone easily, unlike crimp connectors.
paulcbrowne
- Lifetime Member
- Year model: 2011
by Rollingbones » Fri Jan 30, 2009 18:15 18
When I wired mine, I pulled the lamp assembly, fed the wire through the mirror post to under the dash. No need to remove any tupperware; only pull the dash cover. There's a small hole with a rubber plug on top that I popped out to help feed the wire (underneath the rubber dam). I fed the wire to the hole, grabbed it with some small/narrow needle nose pliers and then fed it down and to the space behind the dash. I then wired them to their own switch. I also have a couple of small lights for my controls on the same line. My riving lights have their own switch and line. Here are some pics: The new lamp socket from Pep Boys  The hole where the plug came from to help with the feed:  The switches:  I hope this helps...Rb
Mark...Rollingbones 2007 AN 650A Executive (Sold) 2008 Kawasaki Vulcan 900LT Classic (Eljay) PHOTO STUFF!!!------------------------------------ I didn't lose my mind...I sold it on eBay!!!
Rollingbones
- Charter Gold
- My Ride: Other bike
- Year model: 2008
- Purchase date: 07 May 2007
- Current mileage: 7500
by markc50 » Sat Jan 31, 2009 16:26 16
I've been to AdvanceAuto and Autozone. Both say the vendor is out of the 84725 socket. Does anyone know of an alternate socket that will work, like for a flat base bulb? Thanks Mark
markc50
- Gold Member
- Year model: 2008
- Purchase date: 20 Sep 2008
- Current mileage: 4700
by TechArtGuy » Thu Mar 11, 2010 22:25 22
Just finished up wiring in a set of magic blinkers from custom dynamics. Here's a short vid of how they operate -> LinkI have these paired with a solid state flasher relay as well from custom dynamics.
TechArtGuy
- Site Moderator/Lifetime Member
- Year model: 2008
- Purchase date: 12 Apr 2013
- Current mileage: 3918
by QuantumRift » Thu Mar 11, 2010 22:41 22
Look for the 'Mystery Molex Connectors' mentioned in a new thread.
Clearview XXL Vented shield KRISS Headlight Modulator Kisan TailBlazer Brake Light Flasher 20W-D - Plug-In Manic Salamander Bar End Weights (with throttle lock) Grip Puppies 3Brothers Backrest
QuantumRift
- Insane Poster
- Year model: 2006
- Purchase date: 30 Jun 2008
- Current mileage: 24600
by Dave_J » Fri Mar 12, 2010 0:49 00
TechArtGuy wrote:Just finished up wiring in a set of magic blinkers from custom dynamics. Here's a short vid of how they operate -> LinkI have these paired with a solid state flasher relay as well from custom dynamics.
Yep, thats how mine work. But two years ago I had added two amber LED lamps under the mirrors as side running lamps. I have wired them into my Magic Blankers too. I had cut the black (L) and Green (R) wires on the mirror side of the stock connector and used bullit connectors so I can wire back to stock if needed. I then took 12v and ground from the power plug to run the Magic Blinker. I did not cut the ground wires. No need to fish a wire into the mirror housing when using Magic Blinkers. So, Paul, ya got it figured out?
"Never mount a passenger car tire on a motorcycle rim; the flat profile of a car tire is incompatible ....."
TOTALLY HOG WASH!!!
50,000 miles on a CAR TIRE/DARKSIDE.
***TRAVEL STOP***
Dave_J
- Insane Poster
- Location: Auburn WA Where God takes Vacation. ***TRAVEL STOP***
- Year model: 2008
- Purchase date: 24 Dec 2010
- Current mileage: 37000
Return to Burgman 650
Who is online
Users browsing this forum: No registered users and 1 guest
