Burgman 400 before the 2007 model.
BurgmanUSA.com
by billmeek » Tue Sep 07, 2010 9:20 09
When the speedometer fails, most of the time it's the speedometer rotor (part 21) in this fiche page: http://www.yamahasuzukiofcoolsprings.co ... 5%2FSK6%29Several people have just glued the rotor back together. I've had to replace the entire sensor assembly (part 19) once when a broken rotor damaged the sensor too. I don't recall any other causes for speedometer failure on the forums.
Bill '03 Burgman 400 in blue '03 Burgman 400 in silver (rebuilt) "Yes, I ride it all year round. No, I'm not insane. I'm poor. With insane, you get free room and board."
billmeek
- Insane Poster
- My Ride: Burgman 400
- Year model: 2003
- Purchase date: 08 May 2004
- Current mileage: 60000
by Buffalo » Tue Sep 07, 2010 11:29 11
As you say you've checked the sensor rotor and it is not broken, I would guess that the wire you found with the insulation rubbed off shorted out either the sensor or the meter.
The service manual says to test the sensor and if it test good to replace the meter. There is no test procedure for the meter. The manual does list a procedure to test the sensor. It is on page 8-27 of my manual. If you don't have a manual post back and I will type in the procedure.
--- Craig AKA Cliffhanger---- "Big Red" 2007 Red Executive - 96,679 miles "Little Blue" 2006 Blue 400S - 38,275 miles "STING" 05 B650 gone but not forgotten, RIP My Gallery
Buffalo
- Lifetime Member
- My Ride: Burgman 650 Exec
- Year model: 2007
- Purchase date: 20 Feb 2007
- Current mileage: 96679
by Delfino 100 » Fri Sep 10, 2010 14:35 14
Mine was recently fixed part was $144.
Delfino 100
- New Member
- My Ride: Burgman 400 Type S
- Year model: 2005
- Purchase date: 27 Nov 2008
- Current mileage: 5000
by Peter Hall » Mon Oct 04, 2010 20:18 20
Mine crapped out today at 4560 km. Was driving down the highway and it just quit. I took the speed sensor off and a couple of pieces of plastic fell out. I checked the fisch and the magnetic rotor has been replaced by a new part number. It would seem Susuki is aware of the problem and should have a good will warranty for this?
Peter Hall
- New Member
- Year model: 2004
- Purchase date: 10 Jun 2010
- Current mileage: 10576
by billmeek » Thu Oct 07, 2010 8:07 08
Doubt it. Expect to pay for the part yourself unless you are under warranty.
billmeek
- Insane Poster
- Year model: 2003
by Buffalo » Thu Oct 07, 2010 9:06 09
Or just do what many of us have done, glue the rotor back together and reinstall it. Mine broke at around 7,000 miles. I glued it back together with epoxy and it is still working fine with the bike now having over 21,000 miles on it. I just put a new front tire on yesterday and I pulled the rotor out to inspect it. It is still looking just fine. I cleaned it up, regreased it and put it back in.
Buffalo
- Lifetime Member
- Year model: 2007
by Peter Hall » Sat Oct 09, 2010 20:31 20
OK, so I pulled the wheel off and removed the speedo send unit, no problem there. The plastic end piece that turns the magnet was broken free and spun freely. the magnet itself is stuck to the shaft. I'm going to try gently heating itto see if it will come free. It looks like the old grease had hardened and caused the sender to break. If I can get this fixed, looks like regular greasing will prevent this from happening again. Comment anyone?
Peter Hall
- New Member
- Year model: 2004
by Buffalo » Sun Oct 10, 2010 22:02 22
Cleaning and regreasing seems to be working to keep mine going since I repaired it. I've added it to my regular mainenance schedule.
Buffalo
- Lifetime Member
- Year model: 2007
by Peter Hall » Mon Oct 11, 2010 13:25 13
Well, good news. I managed to get the magnet unstuck and reglued. It's working for now but the magnet has a linear crack and I don't know how long it will last. the cause of my grief was that the magnet stuck to the center shaft. probably never greased and the old grease hardened causing it to break. Proper maintenance would have prevented this and I'll be doing this on a yearly cycle from now on.
Peter Hall
- New Member
- Year model: 2004
Return to Burgman 400 (pre-2007)
Who is online
Users browsing this forum: No registered users and 1 guest
