1) Before you begin installation, you'll need to figure out how much your speedometer needs to be adjusted. Mine was exactly 10% off. When I was traveling at an indicated speed of 80 MPH, I was actually only traveling at 72 MPH. I used my GPS to compare indicated to actual speed.
2) Go to http://www.healtech-electronics.com (the official website of Speedo Healer) and use their online adjustment calculator. You can then print the exact instructions for setting your Speedo Healer's adjustment.
3) Put your Burg. on the center stand and open the seat. You'll be working on the left side of the bike.
4) Remove the phillips screw (see pic below). The screw is located near some fuses and the helmet hook.
5) Lift up the plastic piece and place something under it to help keep it lifted so you can have easy access to the wires (see pic below).
6) There is only one plug that matches the wire harness provided with your Speedo Healer. Unplug the wires (see pic above) using a small flat head screw driver.
7) Plug in the Speedo Healer wire harness connectors that match the plugs you just separated in the previous step. Then plug the other end of the harness into the Speedo Healer.
See pic below for suggested location of the Speedo Healer device. Some people prefer to route the wire into the trunk or other places instead. I chose this spot, because it's easily accessible and it won't get damaged by things being placed into or removed from the trunk. The unit lifts out easily and there's plenty of wire on the harness.
That's it for installation. Just put the plastic panel back in place and put the screw back in. Now you'll need to program the unit by following the directions that came with it and the adjustment settings you printed from the website.
