General SCOOTER talk. Please use the tavern for "other" general topics.
BurgmanUSA.com
by Bluebottle » Fri Mar 02, 2012 16:08 16
Glad you are in one piece
Bluebottle
- Super Poster
- My Ride: Burgman 400 ABS
- Year model: 2010
- Current mileage: 0
by MLavore » Fri Mar 02, 2012 16:19 16
It's good to know that you are alright and didn't sustain any damage to the bike, but it has been proven that ABS does not reduce braking distance. So even without it you would have very likely been okay, although it wouldn't have been as smooth
Knowledge is knowing that a tomato is a fruit, but wisdom is knowing not to put it in a fruit salad.
MLavore
- Active Member
- Year model: 2011
- Purchase date: 20 Mar 2012
by ErikDK » Fri Mar 02, 2012 17:42 17
MLavore wrote:It's good to know that you are alright and didn't sustain any damage to the bike, but it has been proven that ABS does not reduce braking distance. So even without it you would have very likely been okay, although it wouldn't have been as smooth
If you're very trained.
Mileage is in kilometers EC-2000 electronic cruise control operated from Executive screen switch Oxford heated grips Custom-made true cartridge fully adjustable fork. SpeedoHealer for speedo healing SpeedoHealer for healing the CVT
ErikDK
- Insane Poster
- My Ride: Burgman 650
- Year model: 2007
- Purchase date: 28 Jun 2010
- Current mileage: 29000
by EthanolBurgman » Fri Mar 02, 2012 18:10 18
MLavore wrote:It has been proven that ABS does not reduce braking distance. So even without it you would have very likely been okay . . .
What?
2005 AN650 Burgman ("chipped" ECM) running on E-85 ethanol. Custom engine oil, transmission and final drive fluids. BMC (FM388/19) Air Filter. Power Commander III. Xenon Headlights EBC HH Brake Pads and Rotors. TCB on all Brakes. Metzeler (Made in Germany) FeelFree Tires.
EthanolBurgman
- Super Poster
- Year model: 2005
- Current mileage: 12350
by Gbjbany » Fri Mar 02, 2012 18:15 18
Steve D UK wrote:Yep, it's true, but I'm sure that some will disagree anyway. On my way to work this morning. It was misty and the road was damp and greasy. I was filtering (lane splitting?) at about 15-20 mph between two lanes of stationary traffic when some bloody idiot in the passenger seat of a van in the right hand lane suddenly opens his door to lean out and empty an ashtray full of dog ends (cigarette butts) underneath his van! I was practically on top of him when he did this and just grabbed a big handfull of brake. The ABS worked perfectly. I came that close to the inside of the open door I had to back up to let him shut it - after I'd given him a mouthfull of abuse of course! Probably wouldn't have hurt myself but would have done sone damage to the front of my scoot if I didn't have good ol' ABS.
must have been a day for it - Twice yesterday i had people change lanes in front of me ( one guy changed lanes 4 times - i guess he couldnt make his mind up) but whilst trying to avoid him i had taken my eye off the car in front of me and it had stopped - so i quickly grabbed a hand full, now i had plenty of distance but as it was wet and slippy the abs kicked in and made the stop less eventful than i think without. and as a new cyclist i dont have the extensive training others have so i probably overgrabbed !
Jeff
2012 FJR 1300
Gbjbany
- Lifetime Member
- My Ride: Other bike
- Year model: 2012
- Purchase date: 24 Dec 2012
- Current mileage: 204
by MLavore » Fri Mar 02, 2012 18:17 18
ErikDK wrote:MLavore wrote:It's good to know that you are alright and didn't sustain any damage to the bike, but it has been proven that ABS does not reduce braking distance. So even without it you would have very likely been okay, although it wouldn't have been as smooth
Not necessarily, momentum on a motorcycle follows a linear path. It's a little bit different for a car that has two parallel points of contact that can be at different traction levels. (what tends to cause a spin). By removing and reapplying brakes rapidly you aren't changing any factors then if you were applying brakes hard to begin with. The amount of force down on the brakepad and thus to the ground is the same, the rapid succession just keeps anything else effected by its momentum (rider) from being tossed forward as the transfer of momentum is the same but not constant like it is on non-ABS bikes. When the brakepads on the ABS clamp down for those brief periods in rapid succession they are gripping full strength the same as you would do in a panic so that does not change, you just have more changes of momentum from front to brakes to front etc, this makes it so that the tires cannot slide any farther than the very brief point in which they are gripped each time. So basically if you were on a road slicker than snot and slammed the ABS brakes, the tires would still slide, but briefly and then return to having adequate grip to allow control. Rinse and Repeat. Also, human reaction time going into the braking is what would have mattered the most, the 1.5 second average reaction time is what gets most people in trouble. I supposed I could have explained that better. I am not against ABS by any means, they make panic stops a lot less intense/scary/coronary. Just saying that either way he should have been fine.
MLavore
- Active Member
- Year model: 2011
by EthanolBurgman » Fri Mar 02, 2012 18:25 18
MLavore wrote: . . . Also, human reaction time going into the braking is what would have mattered the most, the 1.5 second average reaction time is what gets most people in trouble. . . . Just saying that either way he should have been fine.
Let's see what that might look like . . . http://www.youtube.com/watch?v=ds4bRTZfS3g
EthanolBurgman
- Super Poster
- Year model: 2005
by MLavore » Fri Mar 02, 2012 18:43 18
This is why I like cars that have doors that are locked shut until the vehicle is taken out of drive... It doesn't completely remove the risk but i'd imagine it helps reduce the amount of people opening doors.
MLavore
- Active Member
- Year model: 2011
by rustynail » Fri Mar 02, 2012 20:46 20
One more anecdote...
I'll not rehash any of the debunking here - as the OP was an active participant in my anti-ABS rant.
Steve D, I'm glad you're okay. Truly.
Motorcycle hell is riding a loud, heavy cruiser shoed with a car tire on the uninspiring interstate highway system. I chose something else.
rustynail
- Gold Member
- Year model: 2009
- Purchase date: 21 Apr 2011
- Current mileage: 9250
by Daboo » Fri Mar 02, 2012 23:48 23
EthanolBurgman wrote:MLavore wrote: . . . Also, human reaction time going into the braking is what would have mattered the most, the 1.5 second average reaction time is what gets most people in trouble. . . . Just saying that either way he should have been fine.
First, I totally agree with MLavore. At the speed the OP was going, ABS made no difference at all unless he was riding on ice, sand or ball bearings.. You cannot skid the tires at 15-20 mph otherwise. Your reaction time has a far larger factor in the ability to stop in time. Regarding the YouTube video...no one can anticipate when some jerk will open a door for no reason at all, even if you're looking for it. The cage driver wanted to have the rider hit him. ABS won't help you there either. I have nothing against ABS, but just because you stopped with ABS installed on your bike, doesn't mean it was a factor at all in every situation. I hit my brakes every time I drive my cages, but I have only used the ABS when I wanted to test the ABS...in snow. Chris
Ebenezer - 2011 Honda NT700V Deborah - 2008 Suzuki Burgman 400 (AN400K8) Barak - 2007 Suzuki Burgman 400 (AN400K7) 48,969 miles. (Gone, but not forgotten.)IBA# 49894 True Rounder = 0-20's - Rounder — to — 100's+ Red Hot Rounder John 14:6
Daboo
- Site Moderator
- Year model: 2008
- Purchase date: 09 Apr 2011
- Current mileage: 26000
by Steve D UK » Sat Mar 03, 2012 3:11 03
It was almost the same situation with me as in that youtube video only I was going perhaps a little quicker on a slippery road surface. ABS may not have increased my stopping distance but I'm convinced it was instrumental in keeping the Burg upright and that's the main benefit of ABS on a bike for a relatively inexperienced rider like myself.
Steve D UK
- Gold Member
- My Ride: Burgman 650 Exec
- Year model: 2011
- Purchase date: 14 May 2011
- Current mileage: 4515
by Bluebottle » Sat Mar 03, 2012 6:52 06
ABS gives the confidence to use the full braking capacity of the machine in most circumstances on public roads.
It can be be defeated in certain circumstances, particularly if the rider is skilled and forewarned. ABS becomes a liability on dirt bikes.
Bluebottle
- Super Poster
- Year model: 2010
by Daboo » Sat Mar 03, 2012 9:46 09
Steve D UK wrote:It was almost the same situation with me as in that youtube video only I was going perhaps a little quicker on a slippery road surface. ABS may not have increased my stopping distance but I'm convinced it was instrumental in keeping the Burg upright and that's the main benefit of ABS on a bike for a relatively inexperienced rider like myself.
I don't know what ABS in action feels like on a Burgman. I do know that on the cars I've owned, I can feel the brake pedal vibrate rapidly as they brake|release|brake|release. Did you feel anything like that? What is it that a rider feels when ABS kicks in on a Burgman? Chris
Daboo
- Site Moderator
- Year model: 2008
by Buffalo » Sat Mar 03, 2012 10:26 10
You feel a pulsing in the brake lever somewhat like the pulsing of the brake pedal in a car but not a pronounced. You also feel a slight vibration of the whole bike.
--- Craig AKA Cliffhanger---- "Big Red" 2007 Red Executive - 96,679 miles "Little Blue" 2006 Blue 400S - 38,275 miles "STING" 05 B650 gone but not forgotten, RIP My Gallery
Buffalo
- Lifetime Member
- Year model: 2007
- Purchase date: 20 Feb 2007
- Current mileage: 96679
by Daboo » Sat Mar 03, 2012 10:40 10
Then was that pulsing felt by Steve D UK? If not, the ABS never activated and the brakes worked as well as the standard brakes do. Which is good because he wasn't hurt.  I'm not saying ABS is beneficial. I'm just saying that not all times when we hit the brakes hard, are we using the ABS. In fact, we probably use it very rarely. Chris
Daboo
- Site Moderator
- Year model: 2008
by Buffalo » Sat Mar 03, 2012 10:47 10
When the ABS kicks in there is no doubt that it has happened. You feel it in the lever and the seat of your pants.
Buffalo
- Lifetime Member
- Year model: 2007
by paulcbrowne » Sat Mar 03, 2012 11:30 11
Can't lock the brakes at 15-20 mph? Try driving through the VA hospital parking lot! I've used my ABS in hard braking in other circumstances, but those low speed incidents when lots of aging drivers are on the move, I've felt it click in several times.
Shepherdstown, WV USA 2011 Suzuki Burgman 650 Exec
paulcbrowne
- Lifetime Member
- Year model: 2011
- Purchase date: 24 May 2011
- Current mileage: 10
by joe 90 » Sat Mar 03, 2012 11:45 11
think i would of stoped and scupped up the fag buts and tossed them back in the van.
joe 90
- Gold Member
- Year model: 2003
- Purchase date: 05 May 2011
- Current mileage: 38427
by rustynail » Sat Mar 03, 2012 11:54 11
joe 90 wrote:think i would of stoped and scupped up the fag buts and tossed them back in the van.
Me too. I have a hard time suppressing the urge to toss one back in a car.
rustynail
- Gold Member
- Year model: 2009
by Daboo » Sat Mar 03, 2012 14:29 14
Buffalo wrote:When the ABS kicks in there is no doubt that it has happened. You feel it in the lever and the seat of your pants.
That's why I asked the question of Steve. Did he feel that?  Chris
Daboo
- Site Moderator
- Year model: 2008
by Steve D UK » Sat Mar 03, 2012 14:46 14
Definately. You KNOW when the ABS kicks in. I can't say I've had it kick in at high speed but loads of tme at low speeds - especially the rear if you yank it on hard at 20 mph. You get a very rapid hammering/chattering on the associated brake lever.
Steve D UK
- Gold Member
- Year model: 2011
by rustynail » Sat Mar 03, 2012 14:49 14
Steve D UK wrote:I can't say I've had it kick in at high speed but loads of tme at low speeds
Hmmmm...
rustynail
- Gold Member
- Year model: 2009
by Gbjbany » Sat Mar 03, 2012 16:53 16
Exactly my feelings too - and yes I felt the abs and in our work car park have felt them at 20 mph the speed limit when the roads are damp
Jeff
2012 FJR 1300
Gbjbany
- Lifetime Member
- Year model: 2012
Return to General Discussion
Who is online
Users browsing this forum: Duster, Google [Bot] and 2 guests
