tipover (or is it tip over) sensor - Suzuki Burgman Forum
Reply
post #1 of 36 (permalink) Old 11-02-2011, 11:02 PM Thread Starter
Insane Poster
happytech's Avatar
OK - my K9 shut off again today during a right turn (I don't think it's ever done it during a left turn). It hasn't done it at a stoplight/sign like the other posts on shutdowns read.
Does anyone have any experience with the tipover (or is it tip over - one or two words) sensor? I'll check the sidestand switch, but this is rather unpredictable as to when it happens.
As I said, it only happens on actual right turns (except once when I was getting ready to turn right) - never on a left turn. The idle seems strong. No, the turns are not hard (steep lean angles).
Thanks,
Bruce
Iím not afraid to go fast Ė itís the crashing and burning that scares me.
Actually, I'm too cheap to go too fast. Have you seen the price of gas lately?
It's SO time for another long road trip!!! - like THAT'S ever going to happen now.
happytech is offline
Sponsored Links
post #2 of 36 (permalink) Old 11-03-2011, 12:32 AM
Insane Poster
Elliott Larron's Avatar
Garage
Re: tipover (or is it tip over) sensor
Nope!! Never had it happend on Left Or Right turns, But when i Broke Me leg last year in October, when the Bike fell Over on it's Side Left side the Engine Did turn Off.....
it was off when the bike came to a draging Sliding end atleast 12 Feet , Notice when the sliding stoped engine was off. Not sure when it shut Down.
Not sure where the Tip Over Sensor is, it could be inside the ECU...
Gary L,
Polini Variator|Polini Clutch |Polini ClutchBell|LeoVince exhaust |K&N Oil - Custom.K&N Air|NologyHotWires |PowerCommander 3|Suaoki D21 500A Jump Starter PB
GIVI AF266|Bestek AC 200W inverter|JVC CD Radio|3BBR|Stebel TM80|20WCree XL Leds||Sean Polacik Speedo|80W 8000lm Cree LED Headlights|Voltage Monitor |Bike Master lithium ion 7W/Michelin P Pure SC
Elliott Larron is offline
post #3 of 36 (permalink) Old 11-03-2011, 01:44 AM
Insane Poster
v8eyedoc's Avatar
Garage
Send a message via Yahoo to v8eyedoc
Many scooters as well as motorcycles have what is termed - A TIP OVER SHUT OFF.when the machine goes beyond a certain number of degrees from vertical - the switch is activated........perhaps beyond 45-50 degrees.......!!!!!!!!! To see how far you can tip the scoot over before the cut out switch is activated - simply start the scoot ( with side stand up!) and start tipping it to one side....!!! You will find out quickly enough.!!!
OWNED:
51 HD EL
Vespa
55 HD KHK
98 Boss Hoss
2 GSXR-1000's
PRESENTLY OWN:
01 Honda GL1800
08 Burgman AN400 Coocase colormatched handguards heated grips Denali lights
"PROUD MEMBER OF THE PATRIOT GUARD RIDERS"
"RIDE WHEN IT'S SUNNY - WORK WHEN IT RAINS"
v8eyedoc is offline
post #4 of 36 (permalink) Old 11-03-2011, 02:53 AM
Insane Poster
Garage
It's Risky with the weight of these things you better be good and strong..
Gary L,
post #5 of 36 (permalink) Old 11-03-2011, 03:20 AM
Insane Poster
v8eyedoc's Avatar
Garage
GARY L. - I have picked up my Honda Goldwing GL1800 - which weighs close to 1,000 lbs......!!!!!!! I saw the video online of a 95 lb woman picking up her Golwing.....!!!!!!!!!!!!!! Just back up to the bike or scooter placing your butt against it - grab 1 handlebar - and another grab point.... bend your knees and use the strength of your legs (not upper body!) AND walk backwards........!!!!!!!! Works every time and I have done it 4 times so far.............
OWNED:
51 HD EL
Vespa
55 HD KHK
98 Boss Hoss
2 GSXR-1000's
PRESENTLY OWN:
01 Honda GL1800
v8eyedoc is offline
post #6 of 36 (permalink) Old 11-03-2011, 04:51 AM
Super Poster
greenyaris's Avatar
Quote:
My own view is a switch like that would be dangerous. If there were one, surely there would be mention in the hand book.
I reckon, from the OP's post that the side stand switch is loose or faulty or dirt there and not making contact properly; he di say mainly right hand turns which would tend to confirm this. My tip over shut off switch would be the cut off switch on the right side handlebar
Dave b UK
Ride Safe
Skill with Responsibility
greenyaris is offline
post #7 of 36 (permalink) Old 11-03-2011, 06:01 AM
Insane Poster
dropped mine on the right side once (first time ) of course at 0 mph,, rh turn tip over worked engine cut off , cussing sswitchkicked in as advertised, dropped her again on rt side , 0 mph reverse bank stop feet down, flop just like cartoon , engine ran cussing ran too ,
last time was left side slow speed left turn signal on, moving in a go slow for a left turn , started turn woman on cell phone in cage started to pass on left, cussing switch kicked in first I think, not sure , anyway bars hard right and on throttle and i went down left side ?? engine didn't shut off , neither did cusser , Thank God for full face helmet so she couldn't hear what I was saying about her unmarried single sex underage 22 chromosome single parent both side heritage
never swim nekkid, they'll know who farted
mikeyMarine is offline
post #8 of 36 (permalink) Old 11-03-2011, 06:45 AM
Insane Poster
Ralph M's Avatar
There is one ok and it is a separate switch it will not operate when the scooter is moving and turning
fast due to centrifugal force, if its the switch that is the problem once tripped you have to turn the ignition
off and then restart with the scooter upright ie it wont just restart by pressing the start button.
But for this switch a fuel injected scooter could keep running on its side till it seized or if the throttle
was held open did some other damage.
Ralph
Yamaha MT/FZ-07
The Bug's name is Jimmy, Please don't try to squash him he does not like it and it leaves greasy marks on your screen.
Ralph M is offline
post #9 of 36 (permalink) Old 11-03-2011, 09:49 AM
Insane Poster
v8eyedoc's Avatar
Garage
Thanks Ralph............................
OWNED:
51 HD EL
Vespa
55 HD KHK
98 Boss Hoss
2 GSXR-1000's
PRESENTLY OWN:
01 Honda GL1800
v8eyedoc is offline
post #10 of 36 (permalink) Old 11-03-2011, 10:25 AM
Super Poster
azrider's Avatar
Yup, both the 400 and the 650 have a TO Sensor. On the 650 it seems to be near wiring under the windshield. Troubleshooting steps are in the service manual. It works on lean angles of 65 degrees or more.
]2007 Burgman 650 - Phantom Gray Metallic, Givi windshield
2007 Burgman 400 - Oort Gray Metallic, Givi windshield
2006 Burgman 400s - Candy Grand Blue
2005 Majesty 400 - Dark Metallic Blue, Yamaha touring windshield (sold February 2012)
<charter member of scooter addictions anonymous>
azrider is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Crash or tipover bars? Longsnowsm Aftermarket and Accessories 39 06-04-2013 04:26 AM
ABS sensor zeco Burgman 650 3 08-25-2010 02:21 PM
More on the O2 sensor... QuantumRift General Discussion 10 12-15-2008 07:49 AM
Tipover remedy Cecil Feedback for Suzuki 2 04-29-2008 05:31 PM
Tipover sensor: discovered by accident Oldgoat General Discussion 4 07-15-2006 07:44 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
