Oil Leak Question - Suzuki Burgman Forum
Reply
post #1 of 13 (permalink) Old 03-26-2011, 09:56 PM Thread Starter
Insane Poster
Daboo's Avatar
Garage
Oil Leak Question
I decided to take a few minutes and try to determine where I'm dripping oil. Actually, I know where it is dripping oil at. The question is how it is getting there.
This isn't a bad leak at all, and is just one of those things I'd like to take care of. The location is forward of the oil fill plug and oil window on the bottom leading edge of the engine on the right side.[attachment=2:18ycs40i]P1020359.JPG[/attachment:18ycs40i]
When I took the air filter off to get access to the top of the engine, I found some oil in the air filter box.[attachment=1:18ycs40i]P1020358.JPG[/attachment:18ycs40i]
FWIW, here's what the air filter looked like after about 10,000 miles, compared to the cleaned air filter I'll be putting back in.[attachment=0:18ycs40i]P1020356.JPG[/attachment:18ycs40i]
The only area I can find with wet oil is the one area in the first picture. The rest of the underside and back of the engine just has a combination of oil, dirt, etc. that has built up after riding over the miles. (I should give my bike to Mitch for a week, and get it back looking sparkling clean!) Everything I can see from above and looking from below seems to be simply dry dirt with no signs of oil leakage.
So, two questions...
1. My assumption is the oil in the air cleaner box is coming from a crankcase breather tube. Correct? After about 10,000 miles, I'm not thinking this is unusual...what do you think?
2. Where would you look for the source for the oil leak that shows in the first picture?
Chris
- 2011 Honda NT700V 26000+ miles
- 2008 Suzuki Burgman 400 ( AN400K8 ) 27,389 miles (Gone, but not forgotten.)
- 2007 Suzuki Burgman 400 (AN400K7) 48,969 miles. (Gone, but not forgotten.)
IBA# 49894
True Rounder = 0-20's - Rounder — to — 100's+ Red Hot Rounder
Daboo is offline
Sponsored Links
post #2 of 13 (permalink) Old 03-27-2011, 12:09 AM
Insane Poster
Elliott Larron's Avatar
Garage
Re: Oil Leak Question
Strange i did find some Oil in Mines as well Chris, as you said crankcase breather tube is where it's coming from but thats inside the Air Box it should not be leaking out of the Airbox onless there is a Crack or Breach on that Corner someware - On The Second Picture from the look of the Top Cover Seals theres no Oil Getting thru there..
One thing you can Check Chris, is the crankcase breather tube and see if there a Split on the Rubber Tube, to the Airbox.
if it's not coming from inside the underside Airbox it could be leaking from the crankcase breather tube itself and flowing to the under Corner dripping on to the engine.
Gary,
Polini Variator|Polini Clutch |Polini ClutchBell|LeoVince exhaust |K&N Oil - Custom.K&N Air|NologyHotWires |PowerCommander 3
GIVI AF266|AC 400W|JVC CD Radio|3BBR|Stebel TM80|10WLuxeon Rebel Leds||Sean Polacik Speedo|HID|INNOVA VM|MotoBatt 20W/Michelin P Pure SC
Elliott Larron is offline
post #3 of 13 (permalink) Old 03-27-2011, 02:40 AM Thread Starter
Insane Poster
Daboo's Avatar
Garage
Your theory sounds good Gary, but I'm at a loss to figure out how it can happen. I could be wrong, but the breather tube opening is on the left side of the air filter box. There is some oil residue going across a small ledge on the back side of the box from the left side to the right. Even if the oil was traveling from the left side at the breather tube up into that ledge and over to the right side, I can't see how I'm getting fresh oil on the bottom of the engine, since everything outside those couple inches in the first picture is dry. Dirty yes, but dry.
In other words, how does the oil in the air filter box, go all the way to the bottom of the engine without leaving a visible trail?
This isn't like I'm spewing oil everywhere, it is more like an annoyance when you want things to be perfect and they aren't. Maybe in 5000 miles, I'm using a couple ounces of oil.
I appreciate the thoughts Gary. If I had it all figured out, I wouldn't have asked the question. Gosh, now you have me wondering. Could the oil seep under the built up dirt and get from up above in the air cleaner box and then show up where it would pool till it dripped off on the bottom? Maybe I should take the bike to one of those car washes with the hand held sprayers and do some cleaning?
Chris
IBA# 49894
Daboo is offline
post #4 of 13 (permalink) Old 03-28-2011, 05:13 PM
Desert Rat's Avatar
Garage
Chris
Have you cleaned it real well and checked again. Mine has the same type of oil leak but it's coming from were the (2) engine side bolt togeather. I guess it just thinks it's a Harley
Mike
Black 09 650 Exc Bought 3/30/13 7350 miles, grip puppies & Bearcat backrest.
Darksided 10/8/13 13,600 miles Formoza FD1 165/60r-14
07 400 bought 6/08 with 500 miles sold with 46,818 miles 3/23/13
First bike new 1966 blue Honda 175 Scrambler
Romans 10:9
Desert Rat is offline
post #5 of 13 (permalink) Old 03-28-2011, 05:38 PM Thread Starter
Insane Poster
Daboo's Avatar
Garage
I sprayed it down yesterday a couple times with Simple Green and polluted the environment. So yes, I cleaned it.
Now that you mention it, the independent shop I take it to for tire changes, did mention that there was a leak where the two halves of the crankcase join. They offered to fix it for me, but before I do that, I'll sell it and buy another. The repair bill would probably end up as much as the bike is worth. (While they are good honest mechanics, I think they were hoping I'd pay for a new add-on to their building. Ain't gonna happen.)
I was really tempted the other night to sell this Burgman and buy another. There's a brand-new 2008 in black on the Olympic peninsula for $4000. Brand new. And I also like the black color. It would be my second choice for color after the blue. Tempting, but I'm only barely through braking this one in.
Chris
IBA# 49894
Daboo is offline
post #6 of 13 (permalink) Old 03-28-2011, 09:11 PM
Insane Poster
Garage
Did you try tightening the screws first before you make the Plunge,
maybe there just Loose,
Gary,
post #7 of 13 (permalink) Old 03-29-2011, 02:34 AM
Active Member
Tightening the screws over recommended torque on important places like this make things worse usually
bobo44 is offline
post #8 of 13 (permalink) Old 03-29-2011, 02:44 AM
Insane Poster
Garage
Quote:
When i had my Old China Vento i had Oil leaks just like that What i did was Put JB Weld around the Seals, and it did work But make the engine Look Nasty onless it's Done Correctly.
as a matter of fact i did the same for this Burgman when i found some Cooling Fluid leaking from the Crankcase i JB welded it and had no leaks ever since...
Gary,
post #9 of 13 (permalink) Old 03-29-2011, 10:40 AM
Insane Poster
happytech's Avatar
I've heard of some riders patching an oil leak with a product called "Water Weld" - it's also by J-B Weld. Yes, it's for underwater but might be a better product than the standard J-B weld stuff.
I’m not afraid to go fast – it’s the crashing and burning that scares me.
Actually, I'm too cheap to go too fast. Have you seen the price of gas lately?
It's SO time for another long road trip!!! - like THAT'S ever going to happen now.
happytech is offline
post #10 of 13 (permalink) Old 03-30-2011, 09:00 AM
Insane Poster
Garage
Chris, What's The Status of your Oil Leaks What have you Done for it? have you made a Decision what your gonna Do?
Gary,
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
oil leak joe 90 Burgman 650 1 03-17-2012 08:35 PM
Oil leak helo-guy Burgman 650 16 11-12-2011 06:09 PM
OIl LEAK? jehutch2008 Newbie Questions! 9 04-12-2009 11:36 PM
Oil Leak john grinsel Burgman 400 (2007+ model) 0 08-13-2008 04:52 PM
oil leak gene phares Newbie Questions! 4 08-20-2007 10:41 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
