Drive Belt replacement - Suzuki Burgman Forum
Reply
post #1 of 11 (permalink) Old 08-17-2010, 09:06 PM Thread Starter
Ino
Super Poster
Ino's Avatar
Okay, heres the situation, I'm not mechanically inclined and its way past time (according to the manual) for me to change the drive belt. My local mechanic has doubts on wanting to tackle this job, either he feels that he does not have the expertise to do a good job and he has only seen one super scooter such as this, mine. Now he can do the basic stuff which is good for me (ie, tires, etc).
My question: Anyone live in California with a Burg 400 that has taken to their local dealer or shop that has successfully replaced their drive belt? If so, please let me know the shop or dealer. I feel its worth it to take the burg to a place that have seen a couple of these scoots and can do a good job.
Thanks in advance for any assistance.
Ino
2007 Suzuki Burgman 400 with Velorex 700 Sidecar--Silver
2005 Suzuki Burgman 650 with Velorex 565 Sidecar--Blue (SOLD)
1978 Suzuki Angel Mo-Ped (48cc)--Blue
"4 wheels move my body but 3 wheels move my soul"
Ino is offline
Sponsored Links
post #2 of 11 (permalink) Old 08-17-2010, 10:44 PM
Insane Poster
Daboo's Avatar
Garage
Re: Drive Belt replacement
I know you were looking for a recommendation for a different mechanic, but you may wish to show your current mechanic some of the tutorials and videos we have for the procedure. It wasn't nearly as hard and complicated as I thought it would be and I'm not a mechanic.
Chris
Elnathan - 2014 BMW F800GT
- 2011 Honda NT700V 30000+ miles (Gone, but not forgotten.)
- 2008 Suzuki Burgman 400 ( AN400K8 ) 27,389 miles (Gone, but not forgotten.)
- 2007 Suzuki Burgman 400 (AN400K7) 48,969 miles. (Gone, but not forgotten.)
IBA# 49894
True Rounder = 0-20's - Rounder to 100's+ Red Hot Rounder
Daboo is offline
post #3 of 11 (permalink) Old 08-18-2010, 02:00 AM
Super Poster
rweis's Avatar
Location: Winter Haven, FL (Central Florida) ***TRAVEL STOP***
The key is the electric impact gun, then it is simple. Without it, flippen impossible. GREAT videos.
Bob Weis
Bob Weis, Winter Haven (Central), FL, Red 400K8 "Rebekah"
"You never see a maxi-scooter parked in front of a Psychiatrist office"
***TRAVEL STOP***Winter Haven, FL
rweis is offline
post #4 of 11 (permalink) Old 08-18-2010, 08:35 AM
Insane Poster
tarmacburner2's Avatar
Your mechanic maybe concerned about damaging the plastic panel that has to come off. Apart from that it is a reasonably straight forward procedure. If you do tackle it yourself then be sure to number the bolts that hold the CVT cover on as they are various lengths. Check out the threads and videos is good advice.
Cheers,
tarmacburner2
Beware, this poster has a wicked sense of humour
An400K7 (in black)
7Jurock / Givi Airflow
DPS (18 gram)
Givi topbox and panniers
Fehling racks
Stebel Magnum horn
Leo Vince 4Road Exhaust
Cree LED spotlights
Brain relocated to right hand glovebox.
Honda Silverwing FJS600 ABS
tarmacburner2 is offline
post #5 of 11 (permalink) Old 08-18-2010, 12:27 PM
Insane Poster
Daboo's Avatar
Garage
Ino, if you've had the final drive oil replaced, then that's all the body panels that need to come off.
I think in one of the videos, it showed the entire left side body panel coming off. It isn't necessary. Under the mat for the passenger's footrest, there are two screws, two bolts and a body pin to remove. From there, pull that out enough that the tongue of the panel will slip under the metal brace on the body and it holds it out of the way enough to get your hands in. From there, it is simply removing the five bolts that hold the plastic outer CVT on, and the 10 or so bolts under that that hold the inner CVT on. All that has to come off if the final drive fluid is changed at 7500 miles.
From that point, it is one nut holding the variator on. (Just make sure when reassembling it to turn the variator several times to get the belt seated prior to torquing the nut down.
Chris
IBA# 49894
Daboo is offline
post #6 of 11 (permalink) Old 08-18-2010, 01:12 PM
Desert Rat's Avatar
Garage
You can do it without removing any of the body tuperware. Only plastic that has to come off is the CVT cover. After that it's not a big deal. So have you ever had the oil changed in the final drive ? by the book it's every 7,500 miles. I change mine every 10k.
Mike
Black 09 650 Exc Bought 3/30/13 7350 miles, grip puppies & Bearcat backrest.
Darksided 5/8/16 33,215 miles Bridgestone 165/60r-14
07 400 bought 6/08 with 500 miles sold with 46,818 miles 3/23/13
First bike new 1966 blue Honda 175 Scrambler
Romans 10:9
Desert Rat is offline
post #7 of 11 (permalink) Old 08-18-2010, 01:21 PM
Super Poster
Ino,
I, too, feel mechanically inept. With the generous and patient help and encouragement from Daboo (and Mitch's videos) I was able to do the job. With the electric impact wrench from Harbor Freight ($49) I was able to skip using the variator tool.
You also might want to consider replacing the roller weights with 18gram DrPulley's, while you're at it. I really like the performance change. If you can afford it, you can also replace the OEM with a HiT clutch. I'll be doing that soon. If you do a site search on both of them; you'll see some positive reviews.
I'm not the best to give advice but if you have questions, I still have the pms from Daboo which might be helpful.
taly is online now
post #8 of 11 (permalink) Old 08-18-2010, 02:31 PM Thread Starter
Ino
Super Poster
Ino's Avatar
Guys,
Thanks for the input but I to be perfectly clear, I am a "rider" and the only thing I'll do is change oil and basic pre-ride checking and tightening, beyond that I prefer the techs with the know how and correct tools to dig into the burg.
I may have found the dealership that has serviced and repaired about a dozen burgs over the years and its only about a two hour ride away, I can make a nice day of the ride. I'm just pleasantly surprised the drive belt lasted this long .
Ino
Ino is offline
post #9 of 11 (permalink) Old 08-19-2010, 03:49 PM
Super Poster
I am in Mira Loma.
Bring it to me and I will show you how to do it. I have the tools. Time is short but it should take no longer than 30 minutes. If you are changing your drive belt, how is the clutch, clutch bell, and final drive oil?
utter chaos is offline
post #10 of 11 (permalink) Old 02-15-2011, 10:38 AM
Active Member
Where are the videos for replacing the drive belt on a 400 that are referred to in this string of threads?
Thanks..Tom
restlessailor is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
400-Final Drive Oil Check(and a Drive Belt Inspection!!) NormanB How To 9 02-03-2014 08:20 PM
Drive Belt Replacement Yokota Burgman 400 (2007+ model) 15 05-27-2012 09:05 AM
Poll time. AN650 final drive replacement with a BELT drive. Dave_J Burgman 650 28 10-31-2011 03:50 PM
Drive Belt Replacement komobu Burgman 400 (2007+ model) 2 11-18-2010 07:34 PM
Drive Belt Replacement, Oil Loss, Valves 20,000 miles Teacher Burgman 400 (pre-2007) 1 12-25-2005 01:38 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
