Can't Remove Spark Plug - Suzuki Burgman Forum
Reply
post #1 of 21 (permalink) Old 04-18-2009, 04:34 PM Thread Starter
Super Poster
Valerio's Avatar
I tried changing the plug on my '07-400 and when I push in the socket set it would bounce around so in put a light to it and notice that there is a thin rubber sleeve around it and
absolutely cannot get the socket in.
Any experience this and have any suggestions?
Thx
"If you're not the lead rider the scenery never changes"
Valerio
12 Burgman 650 Exec
09 Burgman 650 Exec(Sold)
- Clearview Windshield
- Izuzu Back Rest
- Puppie Grips
- Breakaway Cruise Control
07 Burgman 400 (sold)
Valerio is offline
Sponsored Links
post #2 of 21 (permalink) Old 04-18-2009, 05:16 PM
Turbo Poster
tsc3047's Avatar
Send a message via AIM to tsc3047 Send a message via MSN to tsc3047 Send a message via Yahoo to tsc3047
Re: Can't Remove Spark Plug
Sounds like the rubber grip from inside the spark plug socket came off and stayed on your spark plug. You should be able to slowly rotate the socket until it fits down on the plug and turn it and pull it out plug and all. I know mine the spark plug tool did that when I was trying to get it out and it was annoying.
-Ian
2008 Burgman 400 Black: Suzuki Sport Windshield, Suzuki Passenger Backrest, DynoJet Power Commander III, DPS Weights 16g, NGK Iridium Plug, K&N Air Filter, Custom memory foam seat, Mobil 1 Oil and K&N Oil Filter.
Today's Advice: Beware of the Hit Clutch
tsc3047 is offline
post #3 of 21 (permalink) Old 04-18-2009, 08:33 PM
Insane Poster
You can grab the rubber thingee with some long needlenose pliers and yank it out. Just be careful not to damage the plug.
polyian is offline
post #4 of 21 (permalink) Old 04-19-2009, 10:48 AM Thread Starter
Super Poster
Valerio's Avatar
The spark plug socket supplied with the 400 has a thinner twall han a regular spark plug socket that you get with a socket set.
Has anyone used these rather than the one supplied without difficulty in get it in or is it too
thick to fit around the plug?
Valerio
12 Burgman 650 Exec
- Izuzu Back Rest
- Puppie Grips
Valerio is offline
post #5 of 21 (permalink) Old 04-19-2009, 11:10 AM
Insane Poster
I used a regular spark plug socket set. When I replaced the plug and pulled the socket the rubber thingee stayed behind and I used some needlenose pliers to pull it out. You can always remove the rubber thingee before re-installing the plug to avoid this issue. I had no issue with the thickness of the socket walls. If you use the spark plug tool that comes with the bike you can't use a torque wrench so you have to guess-ti-torque by hand.
polyian is offline
post #6 of 21 (permalink) Old 04-19-2009, 11:45 AM Thread Starter
Super Poster
Valerio's Avatar
Polyian, you state that you just pulled it out......I'm puzzled as to what the purpose
of this sleeve is. There has to be a reason for it and yet I've never seen it on
any engine, car , truck or otherwsie
In reading in the "How To" no one has ever mentioned that they experienced this problem so I suspect that this rubber was not in thiers?????? puzzled
Valerio
12 Burgman 650 Exec
- Izuzu Back Rest
- Puppie Grips
Valerio is offline
post #7 of 21 (permalink) Old 04-19-2009, 12:18 PM
TechArtGuy's Avatar
Send a message via Skype™ to TechArtGuy
The rubber insert was in the tool that came with my bike. As for the purpose of it it's just a grip for the end of the plug so when you get the plug loosened from the head you can just remove the tool and the plug stays in the end, no fishing it out with pliers. Though putting the plug back in I can see problems with the rubber part staying on the plug certainly.
Two Tone PUFFY seat, Rostra Cruise Control, Projector HID headlights, Tour Tank, Givi E21 Side panniers, passenger extensions, Izuzu backrest, chrome handbars, Powder coated wheels and calipers, DC sport exhaust mod (welded) w/baffle, V3 triton switchback turns, RGB ground effects lighting
- Soon to be offering basic maintenance services.
TechArtGuy is offline
post #8 of 21 (permalink) Old 04-19-2009, 12:21 PM
Insane Poster
The rubber insert is part of the spark plug socket and when you yanked the socket up the rubber stayed behind with the plug. This is common and the reason many people pull the rubber out of the socket before re-installing the plug. It is handy to have there when removing the plug. It's purpose is to help prevent damage to the porcelain on the plug. In the old days we never had these rubber inserts and I neve broke a plug.
polyian is offline
post #9 of 21 (permalink) Old 04-19-2009, 09:36 PM
Insane Poster
TheDarkCutlass's Avatar
I've never had this problem.... The rubber boot holds the socket in place as you snake it down the long tube to get to socket to screw it in and helps ensure it stays straight to help prevent crossthreading. And mine has always stayed in place, whether it be the one that came with the bike, or the set I used for my car.
Just got to not ''yank'' out the socket when you remove the plug.
Black 2009 Burgman 650 Executive
Clearview Windshield w/Vent
Corbin Seat
Halfabusa Stickers
I think, therefor I am... I think
TheDarkCutlass is offline
post #10 of 21 (permalink) Old 04-20-2009, 12:00 PM Thread Starter
Super Poster
Valerio's Avatar
Thanks for all the fine advise and I attacked it again yesterday and had to fish this
rubber washer out with a piece of bicylce spoke that I filed sharp & bent to a hook-
shape and finally was able to get at the plug with no problems. This thing was so embedded around the plug base that it broke up and I pulled it out in several pieces. Never have I had a
problem with a spark plug socket that comes with a socket set.
That tells you what a piece of garbage Suzuki supplied and had I known of this before
inserting the tool for the first time, I would have never used it.
Valerio
12 Burgman 650 Exec
- Izuzu Back Rest
- Puppie Grips
Valerio is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Can't remove ignition /coil caps from spark plugs gme Burgman 650 10 12-09-2016 08:52 AM
Spark plug boot after spark plug change whiteknuckler Burgman 650 8 09-13-2016 05:50 PM
Help With Spark Plug Gap Hammer Burgman 400 (2007+ model) 9 09-04-2012 01:13 AM
Remove a Stripped Plug ABQ How To 5 09-04-2008 09:35 AM
How do you get to the spark plug?? db297 Burgman 400 (pre-2007) 13 05-05-2008 01:56 AM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
