Seat release cable 400K7 - Suzuki Burgman Forum
 2Likes
  • 1 Post By Hammer
  • 1 Post By E.D.
post #1 of 10 (permalink) Old 03-13-2017, 04:50 PM Thread Starter
Active Member
I can manually close and open the seat latch, but not with the key. Turning the key to the left I can see the cable is not moving, but when I use the emergency mod, opens up very easy.
if the problem is by the ignition area, how I can check the cable in that area ?
Scoot have 2100 miles.
Thanks in advance
island18 is offline
Sponsored Links
post #2 of 10 (permalink) Old 03-14-2017, 05:55 AM
Turbo Poster
Hammer's Avatar
Garage
If the temperature is below freezing, any moisture accumulation in the cable will freeze and prevent the key turn from moving the cable. If temperatures are moderate then you have a problem at either end.
Blue AN400 K7
Kuryakyn ISO Grips
Nelson Rigg 850 Saddle Bags
Boulevard C50T K8
Hammer is offline
post #3 of 10 (permalink) Old 03-14-2017, 11:45 AM Thread Starter
Active Member
I don't think that frozen cable is the problem, I'm in Florida, " If the temperature is 75, Thanksgiving is around the corner " lol
Thanks
island18 is offline
post #4 of 10 (permalink) Old 03-14-2017, 03:22 PM
Turbo Poster
Hammer's Avatar
Garage
To open the trunk, I push the key in and turn to the right, not the left, but I guess you know that already and you meant to write 'right'. Right?
E.D. likes this.
Blue AN400 K7
Kuryakyn ISO Grips
Boulevard C50T K8
Hammer is offline
post #5 of 10 (permalink) Old 03-14-2017, 05:24 PM Thread Starter
Active Member
Nope, left
island18 is offline
post #6 of 10 (permalink) Old 03-14-2017, 06:23 PM
Insane Poster
E.D.'s Avatar
Ok then, I see your problem. Turn the key to the right and the seat will open!
Aside from that, the cable can become FROZEN, and I don't mean ICEY COLD, I mean STUCK with RUST. This has happened before. The middle of the cable dips down and can hold water, which then causes rust and corrosion and makes the cable get stuck. the answer is a lot of WD40 and pushing and pulling on the cable until it comes free, OR a new cable.
Cheers!
Hammer likes this.
1979 Honda CB 750 Silver
1979 Penneys 50 Moped Red
1974 Yamaha 360 MX Yellow
1973 Yamaha 80 MX Silver
1972 Honda QA 50 Red
1970 Kaw H1 500 Red
1968 Kaw 120 Scrambler Red
1968 Kaw 120 Scrambler Blue
but Toyota's Rule, no doubt!
John 3:16
Burgman Owners Map:
https://
Burgman Travel Stops Map:
https://
E.D. is offline
post #7 of 10 (permalink) Old 03-14-2017, 07:09 PM Thread Starter
Active Member
I'm sooo sorry, I can't figure out my right from my left!!!!
island18 is offline
post #8 of 10 (permalink) Old 03-15-2017, 02:04 PM
Turbo Poster
Hammer's Avatar
Garage
Did it open when you turned the key clockwise?
Right? Left? Like Einstein's theory of special relativity, it's a matter of perspective. When I refer to R or L on the bike, it is from my seated position but when someone else discusses R or L, I am never quite sure if they are speaking from a position of looking at the bike from the front to the back which would reverse all the R & L's. OR, it may just be our other left.
Blue AN400 K7
Kuryakyn ISO Grips
Boulevard C50T K8
Hammer is offline
post #9 of 10 (permalink) Old 03-15-2017, 06:22 PM Thread Starter
Active Member
Did not open, installed the emergency mod, and will let the dealer fixed
than you
island18 is offline
post #10 of 10 (permalink) Old 03-16-2017, 10:09 PM
Turbo Poster
Hammer's Avatar
Garage
I had a stuck cable every winter when the temps dropped below freezing. I installed the mod for those times so that I would not be locked out of the trunk. This year, for some reason I have not had to use the mod. It now opens with the key in any temp. I would like to think that the water/moisture in the cable had just evaporated but that is just wishful thinking. More than likely, the water has reacted with the cable and has corroded it. I will change it out this spring to avoid a 'snap'.
Blue AN400 K7
Kuryakyn ISO Grips
Boulevard C50T K8
Hammer is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
cable for seat release - any tricks? brap 4 me Burgman 400 (pre-2007) 3 10-05-2016 12:36 PM
Seat release cable Bayard General Discussion 0 03-20-2016 06:14 PM
Seat release cable GK13 Burgman 400 (pre-2007) 15 10-25-2015 08:46 PM
Broken Seat release cable JustSumDad Burgman 650 25 06-17-2014 11:43 AM
Replacing Seat Release Cable cason621 Burgman 400 (pre-2007) 8 07-15-2010 11:31 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
