Broken ring - Suzuki Burgman Forum
 15Likes
Reply
post #1 of 26 (permalink) Old 03-07-2017, 04:33 PM Thread Starter
New Member
Broken ring
The engine stalled while stopped at a traffic light last week and would not start (2013, 400). When I got it home I found good spark, fuses were ok and a shot of starting fluid while cranking had no effect. Looking for a reason for poor compression I checked valve clearances, within tolerance but toward the tight end. Digging deeper I found the top ring broken and the bore gouged pretty bad. Sometimes you can find a complete engine on ebay for about what Suzuki wants for a cylinder and piston. Not sure what my next move will be.
zcarnut is online now
Sponsored Links
post #2 of 26 (permalink) Old 03-07-2017, 04:37 PM
Insane Poster
AlaskaGuy's Avatar
****, that sucks. How many miles on it?
AlaskaGuy is offline
post #3 of 26 (permalink) Old 03-07-2017, 04:43 PM Thread Starter
New Member
9000 but I've only put on the last 2000.
post #4 of 26 (permalink) Old 03-07-2017, 04:49 PM
Insane Poster
AlaskaGuy's Avatar
Quote:
that sucks even more ):
post #5 of 26 (permalink) Old 03-07-2017, 05:31 PM
Insane Poster
E.D.'s Avatar
That is a shame about the broken ring, very unusual for one of these engines, since you have the top end all apart, you might as well buy the parts to fix it, if eveything else is OK with the engine. Use standard piston if the bore can clean up with a glaze removing hone, OR have it bored out to clean up the gouge. If you chose to bore, buy an oversize piston first and hand it to the machine shop, so that they can bore and fit the cylinder to match the piston with proper clearance.
You can buy a standard piston with rings and wrist pin (83mm bore) for $35.99 w free shipping here:
https://www.aliexpress.com/item/Moto...2-237841289718
They also have OVERSIZE piston/ring sets if you choose to bore out the cylinder.
They also have the cylinder base gasket and Cylinder head gasket for $14.24 w free shipping here:
https://www.aliexpress.com/item/Moto...0-1d16f851b775
Always double check parts to be sure that they fit your make, model and year.
I have bought a few things from them, and what I have bought has been good so far. I bought a drive belt for $114, I'll be putting it on in a week, and the deals on starters and such items look to be unbeatable prices.
Elliott Larron and Hammer like this.
1979 Honda CB 750 Silver
1979 Penneys 50 Moped Red
1974 Yamaha 360 MX Yellow
1973 Yamaha 80 MX Silver
1972 Honda QA 50 Red
1970 Kaw H1 500 Red
1968 Kaw 120 Scrambler Red
1968 Kaw 120 Scrambler Blue
but Toyota's Rule, no doubt!
John 3:16
Burgman Owners Map:
https://
Burgman Travel Stops Map:
https://
E.D. is offline
post #6 of 26 (permalink) Old 03-07-2017, 08:47 PM Thread Starter
New Member
Great information, thanks. That gouge in the cylinder is .61 mm deep (.024 in) as close as I can measure. Having the cylinder bored and honed to that depth will have an aluminum piston running in an uncoated aluminum cylinder. Will that work ok?
post #7 of 26 (permalink) Old 03-07-2017, 08:55 PM
Insane Poster
Might want to try nikasil plating for the cylinder, a bigger bore piston kit is available from Vertex.
Elliott Larron and zcarnut like this.
Burgman 650 '04 Exec black (sold)
Burgman 400 hopefully next.
Suzuki DL1000 current seat
Bolzen is offline
post #8 of 26 (permalink) Old 03-07-2017, 09:29 PM
Insane Poster
Elliott Larron's Avatar
Garage
You Must have had A Defective Ring That's All, Manufacture Error
Bolzen, there Big Bore for are 400's, Don't look like theres room for Much but 450cc
Elliott,
Polini Variator|Polini Clutch |Polini ClutchBell|LeoVince exhaust |K&N Oil - Custom.K&N Air|NologyHotWires |PowerCommander 3|Suaoki D21 500A Jump Starter PB
GIVI AF266|Bestek AC 200W inverter|JVC CD Radio|3BBR|Stebel TM80|20WCree XL Leds||Sean Polacik Speedo|80W 8000lm Cree LED Headlights|Voltage Monitor | 7W/Michelin P Pure SC
Elliott Larron is offline
post #9 of 26 (permalink) Old 03-07-2017, 10:50 PM
Insane Poster
I dunno all sizes available. Should consult the manufacturer.
Elliott Larron likes this.
Bolzen is offline
post #10 of 26 (permalink) Old 03-08-2017, 04:42 AM
Insane Poster
E.D.'s Avatar
You can check with the machine shop and see if they can do the cylinder coating, or it they know where to send it to get it done.
I have not seen the cylinder bore myself, so I was wondering if it is an aluminum bore or a steel lined bore? If it is aluminum, I would certainly see the need for the bore coating. Myself. I love steel cylinder bores, as they tend to give less trouble and long service life.
1970 Kaw H1 500 Red
John 3:16
Burgman Owners Map:
https://
https://
E.D. is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
The $5 O-ring stig Burgman 400 (2007+ model) 1 05-21-2016 02:45 PM
Broken O-Ring chikring Burgman 650 6 12-12-2009 08:27 AM
Ring of Fire scchasgal Burgman 650 6 06-08-2007 08:03 AM
Where does the o-ring go on the grip? Peggy Newbie Questions! 6 09-01-2005 11:54 AM
O ring chuckie#1 Burgman 400 (pre-2007) 19 05-11-2005 06:59 AM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
