Broken ring - Page 2 - Suzuki Burgman Forum
 26Likes
Reply
post #11 of 40 (permalink) Old 03-08-2017, 11:42 AM
Super Poster
Garage
The 2003-2006 400's have a steel sleeve-type cylinder, and I believe the 2007 on have nikasil coated aluminum. I've never heard of anyone boring and re-coating a nikasil cylinder although it's probably possible I'd worry then about getting an oversized piston- it doesn't seem like they're for sale anywhere. I'd say it's best to get a new OEM cylinder and piston, or buy an engine out of a wrecked bike. It looks like you'll get out for around $500 either way. Or roll the dice and get this set for $79: http://www.ebay.com/itm/BURGMAN-400-...NXNh6Q&vxp=mtr
BTW, the gasket set and 83 mm piston from aliexpress are for the 2003-2006 400, and won't fit the newer bikes.
Edit: On second thought, I'd be all over that Ebay cylinder and piston- only 7000 miles on it and it looks pretty clean. With shipping under $100. A couple of gaskets and another few hours of work and you could be back on the road for under $150. And the broken ring is a pretty rare problem- normally the 400 is a very reliable engine- I don't think it will happen to you again.
E.D. likes this.
Squeazel is offline
Sponsored Links
post #12 of 40 (permalink) Old 03-08-2017, 11:53 AM
Turbo Poster
captainfish's Avatar
this whole thread makes my heart sad.....
Sad that you had this happen to you at such a young age.
(sniffles)
Current Owner:
My 2nd 2005 Blue Burgman 650
Previous owner:
1987 Honda Helix
January 2005 Blue Burgman 650
"Blue Lightning"
Photo Gallery:
captainfish is offline
post #13 of 40 (permalink) Old 03-08-2017, 02:12 PM
Super Poster
Squar's Avatar
Send a message via Skype™ to Squar
Broken piston rings and 'easy-start' go hand in hand! I've Repaired 500hp marine diesels where Easy Start had been used..... NEVER EVER USE THE STUFF!
Jim
'83 Lead 80, '84 Lead 125, '52 Sunbeam S8, '09 Burgman 400 K8
Squar is offline
post #14 of 40 (permalink) Old 03-08-2017, 06:03 PM
Insane Poster
Lol, Easy Start -- that's how they call a C4-fuel-air mixture now
Burgman 650 '04 Exec black (too much a scoot)
Last true 400.
Suzuki DL1000. (gone but still most miles)
Bolzen is offline
post #15 of 40 (permalink) Old 03-08-2017, 06:17 PM
Insane Poster
E.D.'s Avatar
(sniffles)
Yeah makes me sad too to have this happen at such a young age. Broken Rings & Busted Things.
It reminds me of Elvis Presley, Jimi Hendrix, Janice Joplin, Buddy Holly, Ritchie Valens, J. P. Richardson(The Big Bopper), Otis Redding, Michael Jackson, and so many others!
gec343 likes this.
1977 Honda CB 750 Silver
1977 Penneys 50 Moped Red
1974 Yamaha 360 MX Yellow
1973 Yamaha 80 MX Silver
1972 Honda QA 50 Red
1970 Kaw H1 500 Red
1968 Kaw 120 Scrambler Red
1968 Kaw 120 Scrambler Blue
but Toyota's Rule, no doubt!
John 3:16
Burgman Owners Map:
https://
Burgman Travel Stops Map:
https://
E.D. is offline
post #16 of 40 (permalink) Old 03-09-2017, 02:51 PM Thread Starter
Active Member
Send a message via AIM to zcarnut Send a message via MSN to zcarnut
Thanks for spotting that for me Squeazel! I had checked ebay earlier and didn't see this. I think I got to it in time.
E.D. likes this.
zcarnut is offline
post #17 of 40 (permalink) Old 03-09-2017, 05:03 PM
Super Poster
Garage
Great! Always happy to help another burgusa member! I hope it works for you- now just a couple of gaskets from Bikebandit and you'll be on the road in a couple of weeks!
BTW- don't hone the cylinder- you don't want to break the coating. Just wipe it clean and put on a coat of oil before assembly.
E.D. likes this.
Squeazel is offline
post #18 of 40 (permalink) Old 03-11-2017, 11:47 AM Thread Starter
Active Member
The jug and piston should be here late next week, gaskets were ordered yesterday and cost almost exactly the same as the cylinder/piston combo. Now I have time to clean up the head and throttle body. I have seen post about oil collecting in the airbox, mine had 175ml of oil in the bottom likely due to excessive blow-by after the ring broke. There is a drain tube with a check valve at the end that should take care of normal oil mist, I'll make sure that is clean and functioning before it goes back together. Too bad simple things like this are so hard to get to.
zcarnut is offline
post #19 of 40 (permalink) Old 03-11-2017, 03:05 PM Thread Starter
Active Member
Correction: That is not a check valve at the end of that drain tube, it's just a plug. It would seem as if a rubber duck bill would be a better idea so that any liquid could get out but bad stuff couldn't get in.
zcarnut is offline
post #20 of 40 (permalink) Old 03-11-2017, 03:27 PM
Super Poster
Doc Wheezer's Avatar
Location: ARMED and Quietly Riding Around The Mojave Desert
Quote:
I'm sure EPA would not like that.
Doc Wheezer is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
The $5 O-ring stig Burgman 400 (2007+ model) 1 05-21-2016 02:45 PM
Broken O-Ring chikring Burgman 650 6 12-12-2009 08:27 AM
Ring of Fire scchasgal Burgman 650 6 06-08-2007 08:03 AM
Where does the o-ring go on the grip? Peggy Newbie Questions! 6 09-01-2005 11:54 AM
O ring chuckie#1 Burgman 400 (pre-2007) 19 05-11-2005 06:59 AM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
