Who's Using The lithium ion battery? - Page 4 - Suzuki Burgman Forum
View Poll Results: Who Uses lithium ion batterys
TO COLD TO USE TAKES TO LONG TO START 1 20.00%
LIGHTER BIKES MOVES FASTER 1 20.00%
DON'T LAST LONG FAILS FAST!! 1 20.00%
LOVE THEM IF ONLY WORKED IN THE WINTER 2 40.00%
Voters: 5. You may not vote on this poll
 39Likes
Reply
post #31 of 62 (permalink) Old 03-18-2017, 08:47 PM
Insane Poster
AlaskaGuy's Avatar
One thing about those capacitors....as I understand it, they're one shot deals. Use it and then you have to recharge it. No thanks (:
AlaskaGuy is online now
Sponsored Links
post #32 of 62 (permalink) Old 03-18-2017, 08:58 PM
Insane Poster
Dave_J's Avatar
Large Capacitors can be charged real fast and then the discharge can be drawn out for a longer time. So you will get more than a couple seconds of cranking. But STILL....
a AGM battery is going to be hard to beat if it is kept good care of.
Heck we could go back to KICK starting bikes.
Dave_J is offline
post #33 of 62 (permalink) Old 03-18-2017, 08:59 PM
Super Poster
Skunkhome's Avatar
Quote:
Originally Posted by MacDoc View Post
3 years and counting for my Shorai in tropical Australia.
Even sitting for months the bike starts instantly. I would have gone through 3 stndard batteries in that time. I think they are ideal for hot/humid climates.
so there is no answer for you on this poll.
Skunkhome is offline
post #34 of 62 (permalink) Old 03-18-2017, 09:14 PM
Insane Poster
AlaskaGuy's Avatar
Quote:
My point was really that if you needed more than one jump start before you had a chance to plug it in somewhere and charge it up, you would be SOL.
And yes, I have been on trips where this has happened (:
Dave_J likes this.
post #35 of 62 (permalink) Old 03-18-2017, 10:33 PM
Insane Poster
E.D.'s Avatar
Quote:
Originally Posted by Elliott Larron View Post
I,v Been Testing it for a Week With Great Results, So Great it's been Starting at First Crank at a Outside Temperature of 50" Degrees
LOL, is 50 degrees any kind of battery test?!
And Yes, the fire it makes can certainly warm you up!
Why the heck would I want one of those LI things when I got a nice brand new 10AH Sealed AGM Lead Acid Battery for my 400 from amazon.com for only $33 with free shipping and two day delivery? Fellas, this is a no brainer!
Elliott Larron likes this.
1979 Honda CB 750 Silver
1979 Penneys 50 Moped Red
1974 Yamaha 360 MX Yellow
1973 Yamaha 80 MX Silver
1972 Honda QA 50 Red
1970 Kaw H1 500 Red
1968 Kaw 120 Scrambler Red
1968 Kaw 120 Scrambler Blue
but Toyota's Rule, no doubt!
John 3:16
Burgman Owners Map:
https://
Burgman Travel Stops Map:
https://
E.D. is offline
post #36 of 62 (permalink) Old 03-19-2017, 03:46 AM
Turbo Poster
Tromper's Avatar
Sounds about right from my research, if you're not in an environment that drops below ~ 40F (~ 4C) you're probably better off; however it is a bit more volatile than an AGM, so you are more likely (but still unlikely) to cook one off as noted above.
In the cool, damp PNW. probably the wrong combination of things for that unless it winters in a garage that stays 40F+. Maybe if I get that second home in San Diego I'd like for winters...
2k7 B650 "Ohanzee"
2k8 SYM HD200 "Indigo"
2k6 Gray B650XR "Grau Geist" - Gone
Tromper is offline
post #37 of 62 (permalink) Old 03-19-2017, 10:03 PM Thread Starter
Insane Poster
Elliott Larron's Avatar
Garage
Just Don't Jump it MacDoc, Thats how i blew My Chip, I Jumped it with a Jumper,
Well i,v been looking on those Super / Ultra Capacitors Gio, i'm gonna Order Some when i Order My New Acid Battery, Only gonna be used for Back up!!!
I think i saw some User Made Ones on Ebay, already Built to work....
Good Point E.D., Those Batteries are just to expensive and you don't get enough Amps , and there CHINA Made i'm not a Fan of Made in China Much,
My Old Batt is installed MotoBatt, it is a 20 Amp, But don't really need that many Amps. So when i get a new one it will be a 10 Amp
The more Amps the Heaver the Battery...
Elliott,
Polini Variator|Polini Clutch |Polini ClutchBell|LeoVince exhaust |K&N Oil - Custom.K&N Air|NologyHotWires |PowerCommander 3|Suaoki D21 500A Jump Starter PB
GIVI AF266|Bestek AC 200W inverter|JVC CD Radio|3BBR|Stebel TM80|20WCree XL Leds||Sean Polacik Speedo|80W 8000lm Cree LED Headlights|Voltage Monitor | 7W/Michelin P Pure SC
Elliott Larron is offline
post #38 of 62 (permalink) Old 03-20-2017, 02:18 AM
Insane Poster
E.D.'s Avatar
It's a 10 AMP/HOUR battery , not 10 Amps. The 10 Amp/Hour battery will put out 200 COLD CRANKING AMPS. It's important to understand the terminology and differences. The 400 uses a 10 Amp Hour Battery and the 650 uses a 12 Amp/Hour Battery of the Lead Acid AGM type.
The load testing of the battery is always based on the COLD CRANKING AMPS of the battery.
With a Variable Load Bank and a voltmeter both placed across the battery, and an ammeter connected in series with the Variable Load Bank, the LOAD is increased through the LOAD BANK until ONE HALF of the COLD CRANKING AMPS is achieved, and the voltage is read at that time. For a Lead Acid Battery of the Automotive/Motorcycle type, the voltage should be 9.5 volts or higher to pass. The higher the voltage is, the stronger the battery is.
1970 Kaw H1 500 Red
John 3:16
Burgman Owners Map:
https://
https://
E.D. is offline
post #39 of 62 (permalink) Old 03-20-2017, 02:20 AM
Turbo Poster
Tromper's Avatar
...The more Amps the Heaver the Battery...
Elliott,
True dat, but seriously on a scoot that's being used for bumping around, not racing, a pound or even two just isn't that big a deal, but a few extra amps could bail ya out, particularly as the battery gets older.
Full disclosure..I just bought the YUASA replacement for the burger I didn't check the specs.
2k7 B650 "Ohanzee"
Tromper is offline
post #40 of 62 (permalink) Old 03-20-2017, 11:56 AM
Insane Poster
AlaskaGuy's Avatar
Quote:
I have to disagree. I routinely use my lithium battery in a cold environment. I was riding at 16F one day. It does just fine in the cold - that was actually a selling point for me.
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Shorai Lithium Ion battery ashby102 Burgman 650 20 07-03-2015 06:26 AM
Lithium Battery? GK13 Burgman 400 (pre-2007) 27 06-11-2015 03:25 PM
Another Lithium Iron Battery MJR General Discussion 15 12-30-2012 08:40 AM
Attach Leads to Battery or Battery Cover (Starter Relay)? CalvinFold Burgman 650 3 01-01-2008 03:16 PM
Lithium Powered Scooter Ed Csoltko General Discussion 16 06-30-2007 01:24 AM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
