Who's Using The lithium ion battery? - Page 2 - Suzuki Burgman Forum
View Poll Results: Who Uses lithium ion batterys
TO COLD TO USE TAKES TO LONG TO START 1 20.00%
LIGHTER BIKES MOVES FASTER 1 20.00%
DON'T LAST LONG FAILS FAST!! 1 20.00%
LOVE THEM IF ONLY WORKED IN THE WINTER 2 40.00%
Voters: 5. You may not vote on this poll
 42Likes
Reply
post #11 of 69 (permalink) Old 02-10-2017, 03:23 PM
Super Poster
san diego joe's Avatar
Garage
Quote:
Originally Posted by AlaskaGuy View Post
They both failed in far too short of a period (2 years or so), just stopped holding charge,
If you were using an ordinary battery charger, not one made specifically for lithium, you just destroyed 2 batteries.
Lithium requires a charging sequence different than lead-acid. Some batteries now have a built-in charger to be used by folks who do not know the drill.
Dave_J and BREMER-BURGI like this.
Old Burgman riders never die..they just fade away.
Home to that place that we all will someday stay.
A place in the sky where everyone rides every day.
And that is my epitaph....
san diego joe is offline
Sponsored Links
post #12 of 69 (permalink) Old 02-10-2017, 04:04 PM
Insane Poster
AlaskaGuy's Avatar
Quote:
I wasn't.
I was.
In fact, I was using the $80 (or so) one made and sold by the manufacturer of the the batteries I was using.
Contrary to common belief, I'm not a total moron.
Quai_Oui likes this.
AlaskaGuy is offline
post #13 of 69 (permalink) Old 02-10-2017, 06:21 PM
Insane Poster
A.G. none of us here think you are a TOTAL moron, I mean , not having a full deck and all (just kidding)
doctorate dietary medicene, graduate suma cum laude, Ima eta pi
laugh at yourself, everyone else is
mikeyMarine is offline
post #14 of 69 (permalink) Old 02-10-2017, 06:33 PM
Insane Poster
AlaskaGuy's Avatar
Quote:
Hey, my deck is not only full (of junk) it ALSO has a nice roof on it (:
mikeyMarine likes this.
post #15 of 69 (permalink) Old 02-10-2017, 08:39 PM Thread Starter
Insane Poster
Elliott Larron's Avatar
Garage
Thanks, I,v been using a Regular Charger, Will be sure to get the Other One,,!! From what i read Guys about the Circuit Protection, That if you leave your Lights on, If the Power Drops Below 9 Volts it Suppose to Cut it self OFF!! by Blocking the Terminals, Output!!!
Elliott,
Polini Variator|Polini Clutch |Polini ClutchBell|LeoVince exhaust |K&N Oil - Custom.K&N Air|NologyHotWires |PowerCommander 3|Suaoki D21 500A Jump Starter PB
GIVI AF266|Bestek AC 200W inverter|JVC CD Radio|3BBR|Stebel TM80|20WCree XL Leds||Sean Polacik Speedo|80W 8000lm Cree LED Headlights|Voltage Monitor | 7W/Michelin P Pure SC
Elliott Larron is offline
post #16 of 69 (permalink) Old 02-11-2017, 06:24 AM
Turbo Poster
Tromper's Avatar
I looked over the specs for the lithium batteries, & then bought an AGM battery.
By the numbers they last better, & do better in sub 40F weather. Really since I haven't had any major issues with 'em I'm not too concerned.
I do have a Lithium Ion jumpbox. Works great, but I keep it in my laptop bag for the most part so it doesn't spend much time below 40F
Dave_J and Elliott Larron like this.
2k7 B650 "Ohanzee"
2k8 SYM HD200 "Indigo"
2k6 Gray B650XR "Grau Geist" - Gone
Tromper is offline
post #17 of 69 (permalink) Old 02-11-2017, 12:00 PM
Insane Poster
Dave_J's Avatar
I have been studying Lithium batteries a lot due to trying to build a EV bike/trike. Without a well designed Battery Maintenance System (BMS) that works with a LI type charger, the batteries will over charge or charge too fast. SO, (copied from another thread) - usually the problem is dendritic chrystals growing and tying up ions and short circuiting tiny areas of a cell.
A good BMS can be real small, like for RC hobby batteries or huge for multy cell battery packs. A Chevy Volt or Nissin Leaf uses huge multy cell packs and 1 BMS.
A BMS will monitor a cell during charging/discharging to make sure they all remain constant. While charging say 100 cell's, 50 will be charging harder than the others so a BMS will shunt (shorted to ground, for milliseconds) those slightly so all charge at the same rate. But during discharge some will also discharge at a different rate and the BMS will float (disconnect) them (for milliseconds) so the whole pack remains constant.
When you just replace a AGM battery with a Lithium battery, the Burgman's charging system does not know or care. It will throw a full charge to the Li battery. If the Li battery does not have a built in BMS.......
But as Tromper said, UP here in the Great NorthWet, we rarely get above 40 Deg's F during Fall/Winter/Spring but can still ride in the cold rain 80% of the year. So I will stick to AGM.
YMMV
Elliott Larron likes this.
Dave_J is offline
post #18 of 69 (permalink) Old 02-11-2017, 03:02 PM
Super Poster
Garage
Dave J: Thank you for the BMS explanation. As for the on-board scooter charging system, I also wondered how that worked.
I been using a Shorai LiFe (not ion) lithium for several years now, so there must be some kind of an internal BMS in the battery, but there was no mention of it when I bought it from Battery Stuff.
So far there have not been any troubles with the battery and I like the instant start-up that no lead-acid can give, no matter how long it has been standing. Lead-acids have to be flash discharged a little before full current is available for starting. Not so with lithium. It seems there is a current surge instantly.
post #19 of 69 (permalink) Old 03-07-2017, 07:40 AM
New Member
Yes, Overcharging of lithium ion bateries make it explodes.
But ,lithium ion batteries are lighter in weight and we can use it for long run.
These batteries are cheaper than the other batteries.
Li-ion batteries are used in maximum of the products.they just switch the lead acid batteries.
Li-ion batteries are used from hoverboard to cars.
rooni is offline
post #20 of 69 (permalink) Old 03-07-2017, 10:34 AM
Super Poster
Garage
And we all know what happens to hoverboards
Squeazel is online now
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Shorai Lithium Ion battery ashby102 Burgman 650 20 07-03-2015 06:26 AM
Lithium Battery? GK13 Burgman 400 (pre-2007) 27 06-11-2015 03:25 PM
Another Lithium Iron Battery MJR General Discussion 15 12-30-2012 08:40 AM
Attach Leads to Battery or Battery Cover (Starter Relay)? CalvinFold Burgman 650 3 01-01-2008 03:16 PM
Lithium Powered Scooter Ed Csoltko General Discussion 16 06-30-2007 01:24 AM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
