Dr Pulley benefits ?? - Page 13 - Suzuki Burgman Forum
 22Likes
Reply
post #121 of 130 (permalink) Old 05-27-2016, 04:22 PM
New Member
Thanks for the update I think I will try 16 gram sliders after new tires. Buying a used bike takes a lot of work to make it feel like your bike.
Common Man is offline
Sponsored Links
post #122 of 130 (permalink) Old 06-13-2016, 01:13 AM
Insane Poster
E.D.'s Avatar
Quote:
The 16 gram sliders will go a long way towards making it feel like your own.
1979 Honda CB 750 Silver
1979 Penneys 50 Moped Red
1974 Yamaha 360 MX Yellow
1973 Yamaha 80 MX Silver
1972 Honda QA 50 Red
1970 Kaw H1 500 Red
1968 Kaw 120 Scrambler Red
1968 Kaw 120 Scrambler Blue
but Toyota's Rule, no doubt!
John 3:16
Burgman Owners Map:
https://
Burgman Travel Stops Map:
https://
E.D. is offline
post #123 of 130 (permalink) Old 06-13-2016, 09:55 AM
Super Poster
Foxyrhei's Avatar
Garage
Quote:
Just installed 16g SR's and I feel that I changed bike to magic trolley!
happy1465 likes this.
Burgman 400A L5 "Iuki"
Burgman 400 K2 "Siuzi" (sold)
Foxyrhei is offline
post #124 of 130 (permalink) Old 06-14-2016, 07:43 AM
Super Poster
Foxyrhei's Avatar
Garage
Thanks to @stig and @E.D. for guiding me before setup
So as @E.D. said, 16 grams is too different than stock, but maaan, it's so good when you're 2-up!
I've recorded short video for you, guys. Please watch @FullHD. Sorry for quality, it was recorded on iPhone by my passenger!
- Burgman 400 L5 , 14 000 km
- Stock CVT and Belt + Dr. Pulley SR 16 gram
- Givi Airflow
- Rider + passenger ~ 120 kg + Givi V47 case
Foxyrhei is offline
post #125 of 130 (permalink) Old 06-15-2016, 01:12 AM
Insane Poster
E.D.'s Avatar
[QUOTE=Foxyrhei;1371641]Thanks to @stig and @E.D. for guiding me before setup
- Givi Airflow
Looks good Foxyrhei, Good job on the slider install!
1970 Kaw H1 500 Red
John 3:16
Burgman Owners Map:
https://
https://
E.D. is offline
post #126 of 130 (permalink) Old 06-20-2016, 12:33 PM
Super Poster
Garage
The Dr is IN!
I installed Dr pulleys I got from CliffK with my new variator and clutch, and went for a short ride. The comparison to the original rollers is pretty dramatic- the new sliders are half 16 gram and half 18 gram. The lugging at low speed is gone- the revs come up nicely to 4000+ while accelerating. With the original rollers, the revs were below 3500 at 35 and the bike would chug. The acceleration is markedly better. With the installed sliders, the high speed RPM didn't change much from the rollers- 5000 at steady 50, 6000 at steady 60, etc. But when I twist the throttle, the RPM's increase even at 55- which means that there is still some variation in the variator; still some effective "downshifting" for passing.
I'm a believer. If they don't flip, then I'll be a true believer.
Squeazel is offline
post #127 of 130 (permalink) Old 06-21-2016, 08:34 PM
Super Poster
After eight years I finally clicked past 18k and did some long overdue maintenance, including replacing the rollers WITH 18g sliders and the belt (and final drive oil...) My neglected 2007 is rewarding the effort, but dang was that a pain without the proper tools. Also, actually having the pipe connector makes it sound like a scooter again. Enjoy the solstice!
iowaparrish is offline
post #128 of 130 (permalink) Old 08-27-2016, 08:01 AM
New Member
myvision's Avatar
I can attain 100mph indicated on a flat level road with no wind. That last 5mph, it just barely crawls up to 100mph. There is no ish to it. it is nowhere near 110, it can just barely make 100 mph indicated, probably 95 mph or less (no GPS). There are no hills in this area, but there are areas where the road is slightly inclined, Going up an incline, I might only do about 90+ mph, going down an incline I might break 105 mph. So 100mph might be a good average. Note that I am riding behind a Givi Windscreen that cuts the wind well and gives me no turbulence behind it & I am also sporting a Bestem 929 Top Box on the back.
When I install the Top Box on the back of the bike last month, I thought it would slow me down, but it does not.
And about the sliders, I have not lost faith in them, I ran them for 2 years with no problem, so this was the first time I had a problem with them. Their benefits are so good, that they are well worth while to me, as long as they don't flip often. Time will tell how they do. As I said, I will keep you posted.
Another important point: The job of getting into my CVT is made a lot easier by the fact that I cut out a small portion of the left lower leg shield, making it possible for me to pull the CVT cover without having to remove or touch the lower leg shield. It makes getting into the CVT easier and quicker. I cut it neatly and it looks nice, no one even notices it. I can post a picture of it if anyone is interested.
E.D.
I'd be interested in the picture of the cut out.
Thanks.
myvision is offline
post #129 of 130 (permalink) Old 09-07-2016, 03:34 AM
Insane Poster
E.D.'s Avatar
Here's the pics of the cut out. I took these at night with the flash.
It is giving me a hard time, says I have exceeded my quota of pics, Come on fellas, can't you get a bigger hard drive on that server or connect it to the cloud?
I guess I will have to delete some of my other pics. I had to delete 2 pics of my firefly transmitter garage door opener. If you want to see those, your'e out of luck.
I've got one in, I'll have to go back and delete another of my existing pics. I had to delete the pic of the MOSFET Rectifier Circuit. I don't think anybody will miss that.
Oh, Thank God, I got them in, 2 pics, a close up and one a little farther away.
Here you go.
Gio and myvision like this.
1970 Kaw H1 500 Red
John 3:16
Burgman Owners Map:
https://
https://
E.D. is offline
post #130 of 130 (permalink) Old 09-07-2016, 12:45 PM
Turbo Poster
xringracing's Avatar
Set up a photobucket account and post that way. lot more work, but your limits in photobucket are much higher and will not affect this site.
2004 Burgman 400
xringracing is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
DR Pulley Hit Clutch and DR Pulley 18 gram Slider install edvb Burgman 400 (pre-2007) 3 12-23-2014 07:11 PM
Benefits of owning a MAXI SCOOTER jedd General Discussion 13 12-16-2014 07:54 PM
trike benefits tomfelock The Tavern 6 12-03-2012 11:25 PM
Benefits of AMA membership SteveE General Discussion 4 05-28-2009 02:18 AM
Overdrive - Anyone note any personal practical benefits. kurnel Burgman 650 19 09-15-2005 07:52 AM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
