I am looking to get some info on if it is needed to use premium gas or not for my 2015 Burgman 400. The dealer said I should, but I have also heard otherwise. Thanks!
The story I heard is that premium gas contains hydrofluoric acid and other additves that prevent varnish build-up in carburetors and injectors. So the cleaning that we used to do is not necessary with premium.
It is not easy to get any info on the quality of gas that we all use, or see reports and studies of different brands.
All grades of gasoline contain additives to combat build-up of varnish and other crud, and keep injectors clean, etc. With 95%+ of all new cars running 87 octane they have to...
Buy the cheapest you can find and every now and then run a can of Techron or Seafoam through it and you will have a good running machine and save many $$$$$.
BMW made a major mistake in requiring premium fuel.
The owner's manual for my 2015 400 recommends 87 octane fuel.
In Alberta, most premium fuel does not contain alcohol so that should give marginally better fuel economy, but probably not enough to justify the extra cost.
I put premium fuel in my Burgman and my Triumph sports car for winter storage so that I don't have to worry about the alcohol separating out over the winter. I also use fuel stabilizer.
Alberta: The owners manual for my 2014 400 recommends a minimum of 87 octane fuel. Is that just a case of a dropped word by mistake, or was there a change in something for the 2015 model ?
Also, California scooters and their manuals are a little different than others. So you are limited to 87 octane but I can use premium if I want !!
I find that my B400 runs best on Shell or Chevron. But always low octane. It gets the same MPG so why spend more? Now you might get better MPG if you KNOW there is premium in there. Psychology at work.
Premium gas burns slower, when high-compression engines are fed low octane gas, it ignites early in the compression stroke. We don't need it.
Plus, I owned a Shovelhead for about 5 years and had to use premium. In a machine that could be outun by 150 scooters :laugh Never again.
san diego joe: You are correct. I should have said that it requires a minimum 87 octane. I wasn't home when I posted so I was going by memory (which doesn't seem to be as good as it once was).
Neil
What about non-ethanol gas. We have that here in Kentucky. It's almost $3.00 a gallon and I have noticed a difference in how my mower, blower, weedeater runs after using it. They all start easier. And run smoother. I figure I can fill it up every 3rd or 4th fill up just to let it help clean the system. It's still cheaper than a $9.00 bottle of seafoam. Do you have opinions? Please share. You can even call me names. I'm a police officer so I'm used to it...
Cost savings aside, why not use premium BP in the scooters? One caution I'd have is that nobody else using it...old gas sitting in that underground tank?
$8000+ scooter....a few pennies extra for more nutritious gas does not seem a bad idea, unless it is actually bad for the engine and its systems.
Funny how on the forum of one of the world's most expensive scooters - so many get exercised if one mentions using something other than the cheapest fuel, filters, oil, belts, rollers, etc !!
Why spend the most you can? Most riders on two wheels have economy as a one factor in their transportation decision. Like it or not, the world's most expensive scooter is still cheap compared against many other transportation options. Others, like myself, ride for the manly raconteur image it provides. Nothing says macho like a 400cc step through with all weather protection.
"Pay more because it won't hurt you" is not a persuasive argument. A better argument (also presented in this thread) might be "pay more for a good tier 2 fuel product" but the most persuasive is probably "pay what you need to, to get what you want"
I'm driving my AN400Z on a propane/butane mix. octane lil' over 100. But very cheap in the Netherlands
Converted from liter to gallon and euro to dollar, its $ 2.21 a gallon.
(Ofc it has to be cheap cos I'm dutch...)
I have converted a number of gasoline powered AC generators to run on LPG and am curious as to what changes were needed for the '400 Burgman?
Obviously your need a pressure tank to hold it; what is the tank's capacity, what sort of range does that provide?
Converting small engine generators (10 to 20 HP) to use LPG down-rated their output by 10 to 12%, sometimes more--what changes were needed for the EFI system to properly meter the fuel and retain power output with the LPG's lower energy density?
+ 1 on Cliff's remark, I've been using LPG on my Lexus RX300 for 11 years and on my Jag XJ6 4ltr Sovereign for 5 years before that, both run happily on LPG and as petrol (Gas) prices have risen the installations have paid for themselves several times over.
On the Burgman 400 about the only place for a tank would be in place of a Top box and it wouldn't be very large.... Was this fitment a 'Kit' or a DIY invention and fitting? What about balance... The extra weight of LPG must make the bike top heavy... I love saving money but on the Burgman to my mind, it's a NO NO.
But with the gas prices in the USA now, does it make sense to spend the time/$$$ to convert to alternatives? I doubt it unless you plan to rack up mega miles.
@cliffyk / Squar.
It is a 10 liter tank which is placed under the seat. So the weight is no problem at all. I drive 140 km before it's empty and then its full after tanking exactly 7 liters.
So it's 1:20. Which would be 47 miles a gallon I think.
How it is done I dont know. I bought the burgman with everything installed already. And since it's working I'm not going to fiddle around with it.
It was build in by a german company (mizu.de) as a test project, but they dont do it anymore I think. I mean it will cost around €1500,-- to build it, so you would have to drive (in the netherlands atleast) 40000km before you have earned it back.
But I bought it with 8000km on it for the same money as the ones without LPG. So basicly a free installation and with the 30000km a year I drive I can't stop smiling when I think of the money I have saved so far.
I will upload a few pics later this week.
The higher the octane the cooler the burn and the more detergent it has as well. For how little gas these things use I feel it's foolish to us low octane with ethanol in it. All around high octane non ethanol premium is the only way to go for anything that runs on gas.
From paragraph 1:
"The octane number of a gasoline IS NOT a measure of its hotness or coolness in the burning process, nor is it a measure of how powerful it is—it is simply a measure of how good the gasoline is at resisting detonation (knocking/pinging)."
There is no reason to use higher than needed octane gasoline in any internal combustion engine. Also contemporary formulations of E-10 will not hurt any modern vehicle (MY 2000+); not its engine, not its fuel system nor its exhaust system. The only effect will be 3 to 5% higher consumption (reduced mpg)...
That settles it ! From now on I'm going to use 89 octane and pay less than I would for premium... and at the same time I'll have the satisfaction of knowing that I am not using the cheapest stuff in my precious 400.
Not being an expert or scientist on Octane effects and not being well read on the subject, only what I heard and I believe is:
An engine designed to run on lower octane is a lower compression engine (high compression engines require higher octane to reduce pre-ignition).
SO, running higher octane (which has less energy per unit because of additives) does not burn completely (resulting in even less efficiency and harm to the engine, like wash down on cylinders).
A lot of people think if it costs more it is better. What can I say, have at it. :crying
Worried about ethanol (never bothered me - never had a problem), if I was worried I would buy regular with no ethanol not premium (I am not worried about it and neither are worth the money difference).
Related Threads
Suzuki Burgman USA Forum
798.7K posts
28.2K members
Since 2003
