What RPM at 65 MPH - Suzuki Burgman Forum
 4Likes
Reply
post #1 of 35 (permalink) Old 04-18-2015, 11:18 AM Thread Starter
Active Member
DrJohn's Avatar
What RPM at 65 MPH
I'm breaking in a new Burgman. What are the RPM's at 65 mph?
John
DrJohn is offline
Sponsored Links
post #2 of 35 (permalink) Old 04-18-2015, 01:25 PM
Insane Poster
cliffyk's Avatar
Garage
At an indicated 65 mph the engine should be running around 6000 rpm. However indicated 65 is probably an actual speed of 60, as the speedometers are characteristically 10% fast. At an actual 65 (use a GPS) the revs should be around 6500...
captainfish likes this.
-cliff knight-
cliffyk is offline
post #3 of 35 (permalink) Old 04-18-2015, 01:39 PM
Insane Poster
If properly broken in, nobody will say it's only 400 cc.
Burgman 650 '04 Exec black (sold)
Burgman 400 hopefully next.
Suzuki DL1000 current seat
Bolzen is offline
post #4 of 35 (permalink) Old 04-19-2015, 05:50 AM
Insane Poster
Quantum Mechanic's Avatar
Garage
I bought mine new and the engine revs were 5,900rpm at indicated 65mph. My speedo was 2 mph out with the new tyres according to my gps. So I was in fact doing 63mph. Now my bike has loads of miles on it and it turns at 6500rpm at indicated 65mph, and that's with a new rear tyre fitted just a couple of thousand miles ago. Clearly my belt is wearing which accounts for my higher engine revs. My speedo is still just 2mph out. So don't assume your speedo is definitely 10% out. Most are not (never seen one that is yet but clearly some will be) and it will vary depending on your tyre pressures, tyre wear, your weight, speed etc which all affect the wheel circumference. It's one of those variables. Enjoy your new bike and don't worry about it. These engines are designed to rev, not slog at lower revs. It has a low piston speed compared to a long stroke motor so it's not stressed.
2016 Vespa GTS300ie abs/asr...
Quantum Mechanic is offline
post #5 of 35 (permalink) Old 04-19-2015, 08:09 AM Thread Starter
Active Member
DrJohn's Avatar
What speed is related to 4,000 rpm's? I know that I must not go over 4,000 rpm's for the first 500 miles.
I'm still not riding it though. I had an infection in my right jaw. Had the tooth extracted and was on two antibiotics. That has cleared. Now, I'm having the same problem in my left jaw. Too sick to ride right now.
John
DrJohn is offline
post #6 of 35 (permalink) Old 04-19-2015, 06:28 PM
Insane Poster
cliffyk's Avatar
Garage
John
I would not worry about that.
For the 1st 500 miles do not let it idle for extended periods, do not go full throttle at any speed, and do not travel for extended periods at any single speed--then change the engine oil at 600 miles. It will be fine...
-cliff knight-
cliffyk is offline
post #7 of 35 (permalink) Old 04-20-2015, 07:23 AM
Insane Poster
Garage
Agree with Cliffy. In fact Suzuki GB said I could use 5k revs during the first 500 miles as 4k is too slow. Do as Cliffy says with the throttle, vary it lots and it will bed in fine. 4000rpm will give differing speeds depending upon your weight, whether you are going up hill, down hill, giving it power, or just cruising. It will barely give 30mph if you hold the revs at 4k but if you give it some power (use the torque) as you accelerate, you'll find 4600rpm gives nearer 50mph. I kept mine between 4500-5000 revs for the first 500 miles, varying the throttle a lot and building up the speed and revs a little each day after 500 miles. It goes well and uses no oil at all under any type of riding.
post #8 of 35 (permalink) Old 04-20-2015, 08:46 AM
Turbo Poster
DR Pulley Sliders 19 GM change things considerably.
I have posted test results (Dash Pictures of SPEED vs RPM) with the sliders for various speeds (indicated) after installing the sliders. Take a look at that data.
Not that it has anything to do with break in on a new bike with Rollers.
Paul 38Burg650 07 is offline
post #9 of 35 (permalink) Old 04-20-2015, 09:44 PM
Insane Poster
mike1nw's Avatar
Location: LA (Lower Alabama) or out wandering on my scoot
I think my last high-speed burst on I-10 here was 95 indicated MPH, at 7,000 RPM. With 19g sliders. It just hums along!
The Schofield Kid: Yeah, well, I guess they had it coming.
Will Munny: We all got it coming, kid.
2008 red B400
OTHER vehicles- 1997 Saturn SL, 2002 Haro mountain bike
mike1nw is offline
post #10 of 35 (permalink) Old 04-20-2015, 09:52 PM
Turbo Poster
Quote:
Sounds about right --- I rememebr from my test after 19GM sliders installed (posted results on here) at 80 MPH (indicated) was 6200 RPM (if my memory is correct).
Seems also that 95 MPH (indicated) was all she would do - same top speed as before the sliders, but at much less RPM (would not get up to 9500 RPM with the higher gearing - I think someplace around 8000).
PS: Can't say for sure without looking back at my test Posts of speed vs rpm after installing the sliders.
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
75 mph 6800 rpm is it ok? DONSHINGON Burgman 400 (2007+ model) 15 03-18-2015 09:20 PM
Video- WORN CVT parts - by MPH / RPM reading micbergsma Burgman 400 (pre-2007) 0 05-31-2011 11:16 AM
mph - rpm look like it's bad now? micbergsma Burgman 400 (2007+ model) 10 11-03-2009 03:12 PM
MPH/RPM ? scootn Burgman 400 (2007+ model) 4 07-06-2009 12:50 PM
Majesty rpm/mph wilythek All others 6 09-28-2005 06:03 AM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
