What RPM at 65 MPH - Page 3 - Suzuki Burgman Forum
 4Likes
Reply
post #21 of 35 (permalink) Old 11-07-2016, 08:01 AM
Turbo Poster
Mike33's Avatar
6800 RPMs @ 65 MPH minimum on mine. It's slowly creeping up in RPMs.
Mike33 is offline
Sponsored Links
post #22 of 35 (permalink) Old 11-10-2016, 02:36 PM
Active Member
Takahashi's Avatar
5,900RPM at 65mph on mine with Malossi Variator, 18g rollers, and Malossi kevlar belt and clutch bell, got some 20g rollers to go in so i can whack my average speed up witout sacrificig te 6000rpm smooth riding and fuel consumption
UK
2009 Burgman400 K8
2005 GSX1300R Hayabusa
Takahashi is offline
post #23 of 35 (permalink) Old 11-10-2016, 03:31 PM
Insane Poster
cliffyk's Avatar
Garage
Quote:
Is that at actual or indicated speed? The speedometers on these scoots typically indicate 10% higher than actual speed (so does my 2006 Silver Wing)...
-cliff knight-
cliffyk is offline
post #24 of 35 (permalink) Old 11-12-2016, 01:42 PM
Active Member
Takahashi's Avatar
indicated my friend. Im sure its out by a bit as the trucks dont seem much slower (they are restricted to 58mph in the uk)
UK
2009 Burgman400 K8
post #25 of 35 (permalink) Old 12-08-2016, 07:15 PM
Active Member
Send a message via AIM to zcarnut Send a message via MSN to zcarnut
It seems as if my rpm to mph ratio is higher than most, 7000 @ 65 mph indicated. Top speed 90 mph with the tach 200 into the red. I had the CVT cover off last week to clean the variator and clutch but I didn't measure the belt width because it has less than 8000 miles.
zcarnut is offline
post #26 of 35 (permalink) Old 12-09-2016, 01:13 AM
Insane Poster
E.D.'s Avatar
I ride two-up a lot, 315+225 lbs+fully loaded underseat and topbox
16 gram DP Sliders:
2008 Suzuki Burgman AN400
Cruising at indicated:
Speed/RPM
30 = 4300
40 = 4800
50 = 5200
60 = 5400
70 = 6100
80 = 6800
90 = 7800
100 = 8500
Wide Open Throttle acceleration from 40 mph to 60 mph = about 6800 rpm
Gas mileage runs City about 48, Highway about 65 with steady throttle.
1977 Honda CB 750 Silver
1977 Penneys 50 Moped Red
1974 Yamaha 360 MX Yellow
1973 Yamaha 80 MX Silver
1972 Honda QA 50 Red
1970 Kaw H1 500 Red
1968 Kaw 120 Scrambler Red
1968 Kaw 120 Scrambler Blue
but Toyota's Rule, no doubt!
John 3:16
Burgman Owners Map:
https://
Burgman Travel Stops Map:
https://
E.D. is offline
post #27 of 35 (permalink) Old 12-09-2016, 04:21 AM
Insane Poster
Quantum Mechanic's Avatar
Garage
E.D. she sounds like she is working a bit hard. Remember, she is a short stroke motor designed to thrive on revs. Speaking from a purely technical viewpoint, for maximum accelerationyou'd be best with the engine at 7,300 to 7,500rpm where max power is. I appreciate you probably already know that and that's the way you want it, but just for folks who don't know these things I'm mentioning it. It makes a huge difference to how she goes. Your cruising revs are also a bit on the low side at 70mph and she will be lugging at times for sure. You'll find your mpg's will almost certainly improve a bit if you let her rev a bit more at cruise. Suzuki set them up at the factory to run at 6,500rpm at 70mph (indicated). Mine now runs at 7,000rpm at indicated 70mph as my belt is wearing. She gives me between 78-83mpg at that speed depending whether I'm going into the wind or have it behind me...with about 80mpg in neutral conditions. Remember we are talking about imperial gallons for us folks in the UK.(4.54litres).
2016 Vespa GTS300ie abs/asr...
Quantum Mechanic is offline
post #28 of 35 (permalink) Old 12-09-2016, 08:22 AM
Insane Poster
Mech, that's probably right but can the speedo limit be reached with oem rollers on flat road -- i doubt that. The only change i experienced going from 18 to 16 g DPS was in the mid range, so i tend to think the best slider weight should be 13-14 g, and it complies with a recommended setup for the new Dr. Pulley variator.
Burgman 650 '04 Exec black (too much a scoot)
Last true 400.
Suzuki DL1000. (gone but still most miles)
Bolzen is offline
post #29 of 35 (permalink) Old 02-28-2017, 11:23 AM
Active Member
Danmichsr@gmail.com's Avatar
Garage
New Machine 2017 650
I will be getting a ride down to my dealers in a week or two to pick up my new bike. I need to drive it about a 100 miles to get back home and will keep it at about 4 or 5k rpm as mentioned on here. Speed limit on I95 is 75 so will keep to the back roads.
Of course I'll read the book when I get home but being on here sure helps with lots of questions and answers. I have NO IDEA what Dr Pulley Sliders (19GM) are or what they do.
Also not sure what oil is used in it but was wondering what would be the best to use when I change it at 600 miles. Thanks
Danmichsr@gmail.com is offline
post #30 of 35 (permalink) Old 02-28-2017, 01:53 PM
Super Poster
Garage
The 650 won't have sliders or rollers- its CVT works in an entirely different manner and shouldn't require any service.
Doesn't hurt to change the oil often, but if I recall correctly there are 3 different places to change the oil in the 650. Your owner's manual should tell you when and where and what type of oil better than us amateurs here on the forum ;>)
Take a quick look into the manual for break-in procedures before your ride, but I'm pretty sure you can exceed 5K rpm for short periods without damage in the first 600 miles. I think it's just sustained operation at high revs you want to avoid while breaking it in.
Squeazel is online now
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
75 mph 6800 rpm is it ok? DONSHINGON Burgman 400 (2007+ model) 15 03-18-2015 09:20 PM
Video- WORN CVT parts - by MPH / RPM reading micbergsma Burgman 400 (pre-2007) 0 05-31-2011 11:16 AM
mph - rpm look like it's bad now? micbergsma Burgman 400 (2007+ model) 10 11-03-2009 03:12 PM
MPH/RPM ? scootn Burgman 400 (2007+ model) 4 07-06-2009 12:50 PM
Majesty rpm/mph wilythek All others 6 09-28-2005 06:03 AM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
