Anybody used the pinstriping? - Suzuki Burgman Forum
Reply
post #1 of 13 (permalink) Old 05-26-2008, 09:16 AM Thread Starter
Insane Poster
CalvinFold's Avatar
I've had bad luck with other reflective pinstriping I've bought...can't stretch it around sharp curves, snaps easily, peels off in little pieces, and just generally very fragile. TapeWork's RimStealth/Reflective Pinstriping has always been a joy to work with compared to any other vendor.
But curious about the StreetGlo stuff since alot of people here have their kits and graphics goodies. Anybody done any extensive work with the StreetGlo stuff? Am also curious about the SuperBlack.
Kevin(aka "CalvinFold")
CalvinFold is offline
Sponsored Links
post #2 of 13 (permalink) Old 05-26-2008, 09:28 AM
Insane Poster
Buffalo's Avatar
Re: Anybody used the pinstriping?
I used the Superblack to run along the edge of the tupperware on the side from the windshield all the way to the passenger foot rest on my 05. I was able to stretch it around the bend at the top of the foot area where it bends back to the dash without to much trouble. The bend up by the glove box where it goes back toward the windshield was more difficult but I eventually got it to go around there also.
--- Craig AKA Cliffhanger----
"Big Red" 2007 Red Executive - 134,929 miles
"Little Blue" 2006 Blue 400S - 47,595 miles
Buffalo is offline
post #3 of 13 (permalink) Old 05-27-2008, 11:55 AM
JohnK's Avatar
I have used the streetglow stuff with very good results. Both my bike and FIL's were done with it. Took my time and did it the dry method way and even got it to make the tight turns.
[attachment=1:2gqnudwe]IMG_0123.JPG[/attachment:2gqnudwe]
JohnK
AN650A K6 (lifetime avg. 55 mpg)
JohnK is offline
post #4 of 13 (permalink) Old 05-27-2008, 12:19 PM Thread Starter
Insane Poster
CalvinFold's Avatar
So it stretches decently? Does it stick right down or is it repositionable a little until it sits a day or two?
Some of the features I've come o expect from TapeWork's product (my "Gold Standard" to date for decals and pinstriping):
--Stretches slightly for going around sharp corners without puckering (i.e. the "outide edge" of the corner can stretch a bit longer than the inner side for a clean turn)
--Even when stretched, retains 99% of it's color and reflectivity and color (doesn't "go white" or fade when stretched slightly)
--For the first hour or so (at least) it can be pulled back up with little or no ill effect in case you spot a problem. I sometimes find as I try to go around tricky corners, or to trim an end "just right" that I have to stick it down, then pull it up, adjust it, and try again. The TapeWorks stuff is very tolerant of this and doesn't achieve maximum adhesion for a day or two. I've bought products that stick instantly and if you screw-up the stuff it a bear to get off even seconds later.
--Long lasting. I've had TapeWorks RimStealth (now simply "Reflective Colors" pinstriping) for over 5+ years with no degredation of the color or reflectivity.
I always use dry-apply for pinstriping, but have come to like wet-apply for tricky multi-piece custom graphics. For Flexichrome, it's almost mandatory to use wet-apply.
Thanks again!
post #5 of 13 (permalink) Old 05-27-2008, 12:59 PM
JohnK's Avatar
Yes, it will stretch some w/o puckering if you do it when temps are above 70F.
If you only gingerly tack it down you can reposition it. Once I have it where I want it I use a burnishing tool or the smooth side of the decal paper to burnish it down in place. As you know burnishing it in place creates a little more friction heat so that the glue really sets good and also helps to smooth out any tiny bubbles. Once burnished it is not coming up again.
On the bigger or more complicated decals I will use the wet-apply method to prevent tearing, over stretching or big air bubbles.
I have not had any problems with peeling, flaking or fading for up to 5+ years and some of the vehicles if done are not garaged.
I have had good luck with 3M and street glow products and their service.
I decaled a lot of the Countys' vehicles on the side.
JohnK
JohnK is offline
post #6 of 13 (permalink) Old 05-27-2008, 02:34 PM Thread Starter
Insane Poster
CalvinFold's Avatar
I met a pro decal artist who does large vehicles like transit buses. He gets access to some cool colors in reflective that I've never seen from vendors like StreetGlo or TapeWorks. Seen his work on buses, nice stuff and the material is really quality.
He's going to get me scrap sheets leftover from projects to play with.
post #7 of 13 (permalink) Old 05-29-2008, 04:17 PM Thread Starter
Insane Poster
CalvinFold's Avatar
Well I e-mailed StreetGlo a few days ago but they never responded, and that always peeves me.
So I ordered other goodies that I didn't need to question: one of the helmet kits (in SuperBlack since I have a gloss black Shoei X-Eleven)...the one with the big thick loop from the chin to the top of the visor...a bunch of the "do not remove helmet" stickers (been looking for more of these). Wanted the "speed blocks" someone on this site was prototyping, but I guess they weren't for sale yet.
And I went ahead and got my pinstriping from TapeWorks. I noticed the StreetGlo SuperBlack doesn't come in a pinstripe version, which is what I was inquiring about, so it was a moot point anyway.
I also couldn't figure out what kinda of DOT tape StreetGlo is selling (what brand/type) so I got some Reflexite and SOLAS from Indenti-Tape to try, since they explicitly mention the brands.
If I had two pieces of advice for StreetGlo:
1.....Answer e-mails. For good customer service, that means within 24-48 hours. Anything else and why bother having an e-mail address customers can ask questions through?
2....Redesign the site. It's aweful, especially for Mac users. Hard to navigate, hard to read, hard to use. If I hadn't wanted what I wanted really badly, I'd have moved on without purchasing.
post #8 of 13 (permalink) Old 06-18-2008, 11:17 PM
Super Poster
RedRanger3's Avatar
JohnK- Nice job on the pinstriping. What width tape did you use?
Trn bpers and LED turn arrows ,ClearView -vent &tint,Streetglo refl. decals,cuphldrs,bkrest,beaded seat, powr distr syst, hump mat, grp puppies,Top Box, aux lighting,MCL RAM w GPS
RedRanger3 is offline
post #9 of 13 (permalink) Old 06-23-2008, 08:15 AM
JohnK's Avatar
RedRanger:
Sorry for the delay in answering, I was at the Blue Ridge Parkway Rally this weekend. I used the 6mm/ 1/4" streetglow tape. It is perfect width to go along the contour edges of the 650.
JohnK
JohnK is offline
post #10 of 13 (permalink) Old 06-23-2008, 10:43 AM
Super Poster
RedRanger3's Avatar
Thanks! much appreciated.
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Reflective PInstriping ml8853 Burgman 650 5 09-27-2009 07:42 PM
Reflective Pinstriping Picture Selias Photos 8 10-18-2006 02:34 PM
Pinstriping? djdre Burgman 650 19 06-27-2006 01:58 PM
Custom Decals, Pinstriping etc. 650Scoot Aftermarket and Accessories 3 11-27-2005 10:41 AM
Pinstriping Jim The Tavern 2 07-08-2004 11:09 AM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
