2013 wet burgman 650 wont start - Suzuki Burgman Forum
 1Likes
  • 1 Post By E.D.
post #1 of 7 (permalink) Old 09-25-2016, 03:21 PM Thread Starter
New Member
Question 2013 wet burgman 650 wont start
I bought a 2013 Burgman 650 with 700 miles on it with some issues. The previous owner left bike in an area water came up on bike less than 2 feet while parked. I changed the oil checked all the fluids every thing looks good no contamination from water. I turn the key press power and nothing I have the service manual just wondering if the water sent a message to the main computer and now I need to reset with a service program. similar to reseting your maintenance lights. All the lights work fine mirror motors all good bench tested starter motor cvt motor all seem stong battery fully charged kick stand up...sensor..there ...... any burgman owners have had similar problems thanks water never entered the exhaust or anywhere internally. I cant find any blown fuses also when I try jumping the solenoid I seems like it wot allow power to starter motor. thanks for any solutions. and where to purchase diagnostic hookup to my laptop. I bought one from china has not come yet..may not work I have a 2013 650 Burgman the only one I found goes to 2012 oh well $63 dollars. thanks again nace
jimmy is offline
Sponsored Links
post #2 of 7 (permalink) Old 09-25-2016, 03:44 PM
Insane Poster
E.D.'s Avatar
The Lights are working, so that means you have power in the bike. Check to be sure the battery is fully charged and the connections are good. If the 12 volt battery volts drops below 9.5 volts when a heavy load is placed on the battery (as in starting), the battery is weak or bad. Then you push the start button and nothing happens means the trouble is in the starter circuit. Check at the starter solenoid, one big terminal should be HOT from the battery, verify that it is HOT. Then other big terminal goes to the starter motor. Use a piece of insulated heavy gauge copper wire and jump across the two big terminals, there should be a spark at the end of the wire, and the starter motor should turn. If you get NO SPARK on the end of the wire when you do this, that means the starter is not drawing a load, and you must investigate the other end of the wire at the starter and the starter itself. If you DO GET A SPARK on the end of the wire and the starter does not turn, that means that the starter IS drawing a load, but not turning, which means you need to look for a short or check the starter itself for lock up or short.
This procedure is the same as on any other vehicle, whether it be a car, truck, boat, motorcycle or whatever.
jimmy likes this.
1979 Honda CB 750 Silver
1979 Penneys 50 Moped Red
1974 Yamaha 360 MX Yellow
1973 Yamaha 80 MX Silver
1972 Honda QA 50 Red
1970 Kaw H1 500 Red
1968 Kaw 120 Scrambler Red
1968 Kaw 120 Scrambler Blue
but Toyota's Rule, no doubt!
John 3:16
Burgman Owners Map:
https://
Burgman Travel Stops Map:
https://
E.D. is offline
post #3 of 7 (permalink) Old 09-25-2016, 04:58 PM Thread Starter
New Member
thanks
jimmy is offline
post #4 of 7 (permalink) Old 09-25-2016, 05:02 PM Thread Starter
New Member
I'm in St Petersburg just noticed your in Tampa... I have a gremlin to find in this Burgman 650 well the good thing is snow is not coming
jimmy is offline
post #5 of 7 (permalink) Old 09-25-2016, 05:06 PM Thread Starter
New Member
Anyone recommend a mechanic in ST Petersburg, Florida to work on my 2013 650 Burgman .. I have all the plastic covers off
jimmy is offline
post #6 of 7 (permalink) Old 09-26-2016, 11:48 PM
Insane Poster
Dave_J's Avatar
Jimmy, check that both the left and right brake lever switches have connection. You must pull in ether one to get it to start.
Dave_J is offline
post #7 of 7 (permalink) Old 09-27-2016, 12:35 AM
Insane Poster
E.D.'s Avatar
Quote:
I sent you a pm. Did you get it running yet?
1970 Kaw H1 500 Red
John 3:16
Burgman Owners Map:
https://
https://
E.D. is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
650 wont start swabbie Burgman 650 22 04-24-2014 10:28 PM
Needy Newby! '03 Burgman 400 wont start... hcluxton Who are you? Where are you from? 2 07-26-2013 07:01 PM
Burgman wont start :( MLavore Burgman 400 (2007+ model) 9 09-19-2012 04:24 AM
650 Wont Start Sidewinder Burgman 650 15 10-28-2009 07:08 PM
bike wont start - 03' 650 csachs1 Burgman 650 2 02-10-2007 11:44 AM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
