Oil change with Pics(Long) for AN650 - Page 11 - Suzuki Burgman Forum
 4Likes
Reply
post #101 of 120 (permalink) Old 04-25-2011, 10:26 PM
Super Poster
Jetfixer's Avatar
Garage
Re: Oil change with Pics(Long) for AN650
I don't think this has been mentioned before, but since this is such a great post for those who may not be mechanically inclined, or who may not be confident of their ability to change fluids, I'd like to point out something that is not addressed in the owners manual. The engine oil drain plug, the transmission drain plug, and the final drive drain plug all are what is known as "magnetic chip detectors". They have a small magnet in them that traps ferrous particles in the fluid stream and hold them until oil change. When you change your oils, look at the tip of the drain plugs. If this is your first 600 mile break-in oil change, you WILL want to see an nice black "sludge" on these plugs. This sludge should be of a very uniform consistency, and NOT have any large chips, spirals, or anything where the part number is still readable! A nice black pasty sludge indicates a proper break-in of new parts. Be sure to wipe off this sludge before you re-install the plugs, so you can "read" them again at the next oil change. After the initial break-in, the amount of this sludge should diminish, but as long as it stays a fine even consistency, everything is fine internally. One important thing to remember is that the final drive drain and "fill-to-spill" plug are interchangeable. Only the drain plug is a chip detector. Make sure you put the chip detector in the drain position so it can "catch" any particles for your next inspection.
2005 Burgman 650 traded in with 26000 miles.
2011 Burgman 650 Exec traded in with 11000 miles.
2013 Burgman 650 currently over 13000 miles
It's spelled B-u-r-g-m-a-n, but pronounced,
"beyb mag-nit"!!
Jetfixer is offline
Sponsored Links
post #102 of 120 (permalink) Old 04-25-2011, 10:41 PM
Insane Poster
Ragman's Avatar
Sound advice to heed indeed. Thank you
PJ
Scoot's name: Alfie
E52 Maxia Givi box with light kit, Garmin Quest 2, Givi windscreen, Airhawk seat cushion, Cat "O-ring" cruise control, Grip Puppies, Nolan N-102 modular,
Ragman is offline
post #103 of 120 (permalink) Old 05-31-2011, 05:25 PM
Active Member
Motorman-CA's Avatar
Over a year since I bought it and the 600 miles was finally up.
Yeah, I haven't been ridin' a lot...
So I called up the dealer for a service appointment. They were busy and said they would call me back. I remembered this thread and printed out the pics with the screw locations and headed out to the garage. I had the covers off and the oil draining before they called me back - Sorry, I got tired of waiting. He wished me luck and I told him that they would be getting some business as I broke one of those stupid plastic rivits
I had bought some oil and a couple of filters a while back when they were on sale, so I had everything I needed. All went well, I added the trans oil though the level check hole with a squeeze bulb.
I had asked before what this service cost and it was $210 plus parts. So after tax and all, this thread saved me $300 I imagine.
Thanks!
Motorman-CA is offline
post #104 of 120 (permalink) Old 05-31-2011, 05:36 PM
NormanB's Avatar
Good to hear the forum was such good support to you and you were able to save so much money in one service!
Do not worry about the broken rivet - we have all done it.
An expert = ex is a has been and a spurt is a drip under pressure.
AN650AL0 (new toy)
AN650K4 (Av 44mpUSG) (Sold 11/4/2010)
AN400 - 2001 (Sold 8/13/05)
NormanB is offline
post #105 of 120 (permalink) Old 03-24-2013, 07:09 PM
New Member
Is this the same procedure for a 2009 650AN. Just picked it up in the DFW area and my first ride was 350 miles home, which I loved! This was more comfortable than my 2000 Yamaha Venture Royal! I was amazed, and so much easier than shifting up and down, which at 67 weight and shifting was becoming a slight issue! Love this 650! Had only 4000 miles on it in pristine condition and got it for $4600 and that included a 2 yr UNLIMITED mileage full platnum warrentee !
SteveRn
Live Free and Healthy
stevern is offline
post #106 of 120 (permalink) Old 03-24-2013, 07:19 PM
Insane Poster
Quote:
Yes it is the same. I have K9 AN650 and follow the same instructions. You might also want to check out LeDude's oil change info in the Knowledge Base at the top of the home page.
Presently-White Lightning 2009 Burgman 650 (wife's) 13,600 miles
Formerly-Blue 2007 Burgman 400 (wife's) 9980 miles-----SOLD TO BUY FATBOY
Formerly-Blue 2007 Burgman 400 (mine) 4985 miles-------SOLD TO BUY K9 650
Scootermikie is offline
post #107 of 120 (permalink) Old 07-14-2013, 08:04 PM
Super Poster
Thanks for instructions and photos
Thanks, Allwalk, for the great instructions. I just bought a 2007 Burgman 650 with only 2,400 miles and the Honda dealer did not change any of the fluids. ("It only has 2K miles, the oil doesn't need changed.") No mention that Obama was just moving into the White House the last time it was probably changed. So today I removed the tupperware (broke 2 of the plastic push-pins, so I have got to learn the secret handshake on how to remove them). Once the panel was off, everything was just like you showed in the photos. Your descriptions and instructions were right on the money too. Changed engine oil/filter and trans oil (both with Rotella T6 synthetic JASO-MA), and the final drive (75-90W semi synthetic). All back together with no leftover pieces. Total cost, including a fancy funnel with loooonnnng skinny tube for the tranny, was about $40. Ready to hit the road now.
2007 Burgman 650 (SOLD - Nov 2015)
Retired US Air Force MSgt (E7)
Church Organist/Pianist
My Website:
BurgPnoMan is offline
post #108 of 120 (permalink) Old 07-14-2013, 10:03 PM
New Member
First Service
Just did the 1000km inspection with all the oil changes. Found some videos on youTube quite helpful. Anyway, got it done, took a little longer than I thought. The 60cc syringe worked well for the transmission oil filling.
Now I think the bike runs better, just imagining of course, but runs great nevertheless.
Dietrich
Hamburger is offline
post #109 of 120 (permalink) Old 07-16-2013, 01:33 PM
Super Poster
Quote:
Originally Posted by Jim View Post
Allwalk, I found it's not necessary to remove the left lower cover to change the transmissiton oil. I fill my trans. with an oil can in the over flow hole until it runs out, I wait a while (about 30 sec.) then give it a few more shots with the oil can to be sure . This really speeds up the time.
I've changed the engine oil, tranny oil, and final drive oil several times in my 650, and I have never removed any tupperware. Waste of time and effort. Get the squirt can at Walmart and you're all set.
2011 Burgman 650 Exec. with Clearview Windshield, Corbin Seat & Backrest, ISO Grips, fenda extender, gps mount, cup holder, suzuki luggage rack, Kappa k21 Side cases with Kiwi Daves bracket, USB power outlet on handlebar cover, voltage meter, Auto Zone driving lights, brake light flasher.
thomphoto is offline
post #110 of 120 (permalink) Old 01-16-2014, 05:44 PM
New Member
Garage
23000 mile oik change
How many different oils are there to change, and what are they?
Rob
newtoscoot is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
How long before next oil change jonnydz Burgman 400 (pre-2007) 2 09-24-2008 02:45 PM
Pics to change rear tire EdCG Burgman 400 (2007+ model) 7 05-22-2008 09:59 PM
Burgman AN650 Transmission fluid change? Vic How To 2 04-12-2005 05:06 PM
My journey to AN650 nirvana... (long) WLB :>) Burgman 650 14 08-15-2004 04:19 AM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
