AN650K9 Back-Off Wig Wag Brake Modulator Installation - Suzuki Burgman Forum
post #1 of 9 (permalink) Old 05-19-2010, 01:26 AM Thread Starter
TechArtGuy's Avatar
Send a message via Skype™ to TechArtGuy
Here's how to install a Back-Off wig wag brake light modulator. You'll have to excuse the extra connectors not pointed out in the photos as my personal installation has more going on behind the scenes. But, use the following diagram and steps for installing it just for the factory brake lights.
Needed:
- wire strippers
- wire cutters
- crimpers
- small flathead screwdriver
- 16-18 butt connectors x 4
- 16-18 wire taps
- 18" length of red(or white w/black stripe)16 or 18 guage wire
- exacto knife
- #33 electrical tape
Ok, first of course you'll need to remove the bottom rear body panel to get access to the taillight wiring. There's two plastic snap rivets that hold it in place on the bottom of either side. Remove those then slightly push in on the sides of the panel closest to the rear side panels and pull down and out. If it doesn't budge, try pushing forward a bit while pulling down and inward on the sides. The trick is not to force it as the 90 degree hooks that fit into the slots on the side panels are fragile and prone to breaking. So take your time removing it.
The following diagram is a rudimentary drawing of how it hooks up to the factory wiring for mode 2 (wig wag flash, combined flash, then steady on). If you want mode 1 which is a repeat of the wig wag and combined flashing continuously until you let off the brake handle, then use the solid red wire in place of the orange wire in the diagram.
[attachment=4:1egeabgp]diagram.jpg[/attachment:1egeabgp]
It's easy to hook up if mounting the module on the right of the bike as that places the wires coming out of it towards the rear. Once you have removed the cover, use the exacto knife to cut the plastic tubing bundling the wires for each brake light socket to expose more of the wiring. Then, cut the white wire with black stripe on each of the sockets about 3" away. Tape off the end of the wire coming out of the harness for the left brake light socket as it won't be used.
[attachment=3:1egeabgp]DSCF4009.JPG[/attachment:1egeabgp]
Strip the white wire with black stripe coming out of the harness for the right brake light and connect it to the orange (Mode 2) or red (mode 1) wire on the module, depending on which mode you want, using one of the butt connectors.
[attachment=2:1egeabgp]DSCF4011.JPG[/attachment:1egeabgp]
Then, using the wire tap, connect the black wire from the module to the black wire with white stripe on the right taillight socket.
[attachment=1:1egeabgp]DSCF4012.JPG[/attachment:1egeabgp]
Now, strip one end of the 18" length of wire and connect it to the white wire with red stripe from the module using a butt connector. Run the wire behind the center metal bracket over to the left brake light socket. Strip the white wire with black stripe on the socket and connect one side of butt connector. Then, see how long you really need it then cut, strip and connect it to the other side of the butt connector.
[attachment=0:1egeabgp]DSCF4015.JPG[/attachment:1egeabgp]
Two Tone PUFFY seat, Rostra Cruise Control, Projector HID headlights, Tour Tank, Givi E21 Side panniers, passenger extensions, Izuzu backrest, chrome handbars, Powder coated wheels and calipers, DC sport exhaust mod (welded) w/baffle, V3 triton switchback turns, RGB ground effects lighting
- Soon to be offering basic maintenance services.
TechArtGuy is offline
Sponsored Links
post #2 of 9 (permalink) Old 05-19-2010, 01:29 AM Thread Starter
TechArtGuy's Avatar
Re: AN650K9 Back-Off Wig Wag Brake Modulator Installation
Then, strip the white wire with black stripe on the right taillight socket and connect the red wire with white stripe from the module using a posi-lock connector
[attachment=0:kgth9gzy]DSCF4014.JPG[/attachment:kgth9gzy]
Now you can test it out to see if you like the mode it's in. If not just switch the mode wires and tape off the end of the unused one, all done
post #3 of 9 (permalink) Old 05-21-2010, 10:27 PM
Insane Poster
Elliott Larron's Avatar
Garage
Nice Job Sean, Great Connections..
Elliott,
Polini Variator|Polini Clutch |Polini ClutchBell|LeoVince exhaust |K&N Oil - Custom.K&N Air|NologyHotWires |PowerCommander 3|Suaoki D21 500A Jump Starter PB
GIVI AF266|Bestek AC 200W inverter|JVC CD Radio|3BBR|Stebel TM80|20WCree XL Leds||Sean Polacik Speedo|80W 8000lm Cree LED Headlights|Voltage Monitor |Bike Master lithium ion 7W/Michelin P Pure SC
Elliott Larron is offline
post #4 of 9 (permalink) Old 10-07-2010, 11:29 AM
Turbo Poster
bearcat's Avatar
Location: Land O Lakes FL. Ocean View DE. East Berlin PA.
I just installed a Kahtec Flashing Brake Light, (blinking smart stop plus) rather than the Back-off Wig Wag. I used the same basic wiring used in your drawing and photos, although the same wiring diagram comes with the unit. It works great, thanks for the photos. I used the quick connects that came with my
unit, didn't have to strip any wires.The hardest thing to do is cutting that first wire
White wire with black stripe is positive +
Black wire with white stripe is negative -
ASA, "In god we trust, all others we monitor"
Old Guys Rule
Black 2008 Burgman 650 Exec.
White 2009 Burgman 650 Exec.
Grip Puppies
Twin Fiamm blaster horns
Isuzu backrest
Gel seat pad
Garmin 750 GPS
LED turn signals on mirrors
Kahtec Brake Light Modulator
Nelson Riggs Touring Saddlebags
bearcat is offline
post #5 of 9 (permalink) Old 10-09-2010, 01:13 AM
Insane Poster
rtAnimal's Avatar
Location: Ohio, City is home of the Pumpkin Show ( Circleville ), USA
Send a message via AIM to rtAnimal
If you use the posi-lock connectors and experience a problem with the wig-wag unit not working properly. Trash the posi-lock connectors and use crimp on connectors or solder the connections for the best results! I found that the posi-lock connectors don't make a good enough connection and the brake lights would be continuous wig-wag/quad flash then repeat mode. They would never cycle to the constant on mode. I went with soldering the connections and the problem about the continuous looping of the flash modes was fixed.
Happy Sc°°ter´ng!
rt┼n´mal
Realize deeply that the present moment is all you ever have. ~ Eckhart Tolle
rtAnimal is offline
post #6 of 9 (permalink) Old 10-09-2010, 09:59 AM
Turbo Poster
bearcat's Avatar
rt,
Been using the posi-lock connectors on my 650 in Florida now for 2 years now with no problems. If I ever have a problem I would switch to the crimps. Thanks.
Old Guys Rule
Grip Puppies
Isuzu backrest
Gel seat pad
Garmin 750 GPS
bearcat is offline
post #7 of 9 (permalink) Old 10-11-2010, 03:31 AM
Insane Poster
rtAnimal's Avatar
Bearcat
In other positions they should be ok. The WigWag module is very sensitive to electrical fluctuations. The posi-locks don't create a tight enough connection and that causes problems with it functioning properly. I had the same problem with emergency beacons I would use on my semitruck when I carried oversized loads. You had to turn them on and off until you got to the flash pattern you wanted to use. With these two Star Model 911 lights that cost over $200.00 each and came with a 5 year warranty, I thought I had purchased an expensive " pig in a poke ". They was always changing flash patterns while I was using them while driving down the road. In a parking lot with the engine off they didn't have a problem. Start the engine up on my Freightliner semi and they would change patterns but not very often. Start down the road and the patterns would be changing constantly. Even using two pairs of pliers to tighten the posi-locks up didn't fix the problem. Soldering the connections fixed the problem. On other items, like a clearance light mounted on the outside points of an oversized load for night time running I didn't have a problem with the posi-locks. These lights was constant on and didn't require a flashing unit. On my two rear mountable emergency beacons that only had one set flash pattern the posi-locks worked ok. For the Back-Off Wig-Wag unit the posi-locks are an unwise choice!
Happy Sc°°ter´ng!
rt┼n´mal
rtAnimal is offline
post #8 of 9 (permalink) Old 10-11-2010, 09:29 AM
Turbo Poster
bearcat's Avatar
rt,
I'm just sayin, they work for me. But then again, I don't have the WigWag, I have a Kahtech, If they stop workin I'll change them out.
Old Guys Rule
Grip Puppies
Isuzu backrest
Gel seat pad
Garmin 750 GPS
bearcat is offline
post #9 of 9 (permalink) Old 01-30-2011, 03:01 PM
Active Member
Good info thanks, helped me put mine in today. The 400 is a little differnent in taking off the back pannel. There are no snap rivets. The 2 on the bottom inside look like they need to be removed but they don't. Don't waste your time with them like I did.
TomN is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
AN650K9 Installation of 3 gal Aux Fuel Tank TechArtGuy How To 14 08-12-2011 08:27 PM
Back-Off Wig Wag Brake Light modulator TechArtGuy Classifieds Archive 2 06-04-2010 07:25 PM
Back Off Wig Wag Brake Light Signal Module Installation jhrburgman650 Burgman 650 0 03-13-2008 10:17 PM
Back Off Brake Light Modulator Gars Member reviews of aftermarket products 0 05-10-2007 07:34 PM
Headlight Modulator Installation lilleyen Aftermarket and Accessories 8 08-18-2006 07:13 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
