Pictures: Rear Brake Pads and Lub. for '03 650 Standard - Suzuki Burgman Forum
Reply
post #1 of 14 (permalink) Old 05-03-2008, 05:53 PM Thread Starter
Jim
Jim's Avatar
Disclaimer
This is how I do it, and may, or may not be the way Suzuki does this procedure.
This is meant as a simple picture guide to brake Pad, and simple caliper maintaince.
This does not show removal or care of the Pistons, as I have yet, to have the need to remove, or rework them.
As always if you feel you are not qualified, or are unsure, please has this work done by a qualified mechanic. Always refer the the service manual for proper torque specs. on all fasteners.
Health and Safety notice on dust hazard.
Use proper Caliper specific grease
[attachment=4:1wolt2ht]1.JPG[/attachment:1wolt2ht][attachment=3:1wolt2ht]2.JPG[/attachment:1wolt2ht][attachment=2:1wolt2ht]3.JPG[/attachment:1wolt2ht][attachment=1:1wolt2ht]4.JPG[/attachment:1wolt2ht][attachment=0:1wolt2ht]5.jpg[/attachment:1wolt2ht]
Pictures of Modifications and Accessories
Jim is offline
Sponsored Links
post #2 of 14 (permalink) Old 05-03-2008, 06:04 PM Thread Starter
Jim
Jim's Avatar
Re: Pictures: Rear Brake Pads and Lub. for '03 650 Standard
[attachment=4:3gdqg6pc]6.JPG[/attachment:3gdqg6pc][attachment=3:3gdqg6pc]7.JPG[/attachment:3gdqg6pc]
[attachment=2:3gdqg6pc]8.JPG[/attachment:3gdqg6pc][attachment=1:3gdqg6pc]9.JPG[/attachment:3gdqg6pc][attachment=0:3gdqg6pc]10.JPG[/attachment:3gdqg6pc]
Jim is offline
post #3 of 14 (permalink) Old 05-03-2008, 06:26 PM Thread Starter
Jim
Jim's Avatar
[attachment=4:3swgkzcc]11.JPG[/attachment:3swgkzcc][attachment=3:3swgkzcc]12.JPG[/attachment:3swgkzcc]
[attachment=2:3swgkzcc]14.JPG[/attachment:3swgkzcc][attachment=1:3swgkzcc]13.JPG[/attachment:3swgkzcc]
[attachment=0:3swgkzcc]16.JPG[/attachment:3swgkzcc]
Jim is offline
post #4 of 14 (permalink) Old 05-03-2008, 06:45 PM Thread Starter
Jim
Jim's Avatar
[attachment=4:3qei4pdg]17.JPG[/attachment:3qei4pdg][attachment=3:3qei4pdg]18.JPG[/attachment:3qei4pdg]
[attachment=2:3qei4pdg]19.JPG[/attachment:3qei4pdg]
[attachment=1:3qei4pdg]20.JPG[/attachment:3qei4pdg][attachment=0:3qei4pdg]21.JPG[/attachment:3qei4pdg]
Jim is offline
post #5 of 14 (permalink) Old 05-03-2008, 07:04 PM Thread Starter
Jim
Jim's Avatar
[attachment=5:npqx07r6]22.JPG[/attachment:npqx07r6][attachment=4:npqx07r6]23.JPG[/attachment:npqx07r6]
[attachment=3:npqx07r6]24.JPG[/attachment:npqx07r6][attachment=2:npqx07r6]25.JPG[/attachment:npqx07r6]
[attachment=1:npqx07r6]4.JPG[/attachment:npqx07r6][attachment=0:npqx07r6]26.JPG[/attachment:npqx07r6]
Jim is offline
post #6 of 14 (permalink) Old 05-03-2008, 07:12 PM Thread Starter
Jim
Jim's Avatar
[attachment=0:2ja50a2j]1.JPG[/attachment:2ja50a2j]
I usually need to pump the rear brake a few times to get the brakes back, then I hold it a few seconds, it seems to help. Next check the parking brake operation, if all is well, test time.
On my test ride it took a few times, but I was able to lock the rear on dry asphalt, I couldn't before.
I did not need to bleed the brake line, and the brakes are firm.
Front brakes here
Pictures: Front Brake Pads and Lub. for '03 650 Standard
Jim is offline
post #7 of 14 (permalink) Old 07-01-2009, 12:57 AM
New Member
On an AN650 '03, removng the rear brake caliper to replace the pads, I can't get the pistons to retract enough to put the new pads in, much less put the caliper back on the bike straddling the disk. Note that the pads had worn down to metal on metal. Does the caliper assembly need to be replaced? Do you think there's something in the piston that isn't working? Any thoughts would be most appreciated. I'm a fool for a ride but I'm a little shy of the road without a back brake. Regards.
Scooter Daddy
sqtrddy is offline
post #8 of 14 (permalink) Old 07-01-2009, 02:13 AM
Turbo Poster
ybbor's Avatar
Great tutorial on the how to. My 04 is coming into a rear tire change, Will be inspecting the pads then.
Rob
Rob
Looking for spare 650 Front Rim
Various Style Backrests
Leg Wind Deflectors
LED Turn Signals, Switch Cluster lighting Add-on
VSTROM Hand Guards c/w Duplio Trunk bed Liner painted Brake Lever
Hump, First Gear Saddle Bags
High Visibility Yellow Olympic Jacket, MSR Fuel Cell
ybbor is offline
post #9 of 14 (permalink) Old 07-01-2009, 05:53 AM Thread Starter
Jim
Jim's Avatar
The rear brake assembly is a different beast, in that one piston is hydraulically operated buy the left brake, and the other piston is mechanically operated by the parking brake.
The hydraulically operated piston is what we are all familiar with and can be pushed back
The piston that is operated by the parking brake has a + on it and with a screwdriver needs to be turned to the right (clockwise)until it stops. Then align with the pin on the new pad Do NOT "push" the piston back, as there are threads inside it. I do not know how many turns it will take because I have yet to replace the rear pads.
Page 9-74 through page 9-90 in the Service Manual explain the process as well as a complete caliper rebuild.
This thread will also help
Burgman 650 - Rear Disc Brake Caliper and Parking Brake
Jim is offline
post #10 of 14 (permalink) Old 07-01-2009, 07:54 AM
Insane Poster
Chet_Benson's Avatar
Jim excellent information.
I paid to get mine done and was very glad. A good mechanic worked to free the pistons for quite a while. Only cost $68 for the job. My rear brake was not working good enough to hold the bike with the parking brake. The piston was froze and needed to be freed. Brake job was at 18,000 miles. Front was OK.
From the hills of Tennessee
Welcome to another day the Lord has made
2009 White Burgman 400
Chet_Benson is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
REAR BRAKE PADS REPLACEMENT HELP Badgator Burgman 400 (pre-2007) 5 05-29-2013 08:09 PM
rear brake pads ??????? doc exec Burgman 650 7 05-20-2010 01:56 PM
rear brake pads for ABS birddog Burgman 650 9 06-10-2009 08:24 PM
Pictures: Front Brake Pads and Lub. for '03 650 Standard Jim How To 10 05-04-2008 03:05 PM
Rear brake pads for AN 650. farqhuarforever Burgman 650 9 01-14-2008 08:26 AM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
