DYI -- Burgman 650 Rear Wheel Removal Instructions - Suzuki Burgman Forum
Reply
post #1 of 22 (permalink) Old 04-27-2008, 03:48 PM Thread Starter
Insane Poster
LeDude's Avatar
I thought I would pass this along to those that might have an interest in taking off the rear wheel on their Burgman 650.
Taking the rear wheel off the 650 is a pretty straight forward affair; it just takes a bit of planning. I put together a little step by step tutorial along with a parts, tools and materials lists. I also took a number of pictures to help illustrate the steps and remove some of the mystery about this simple procedure. You can view / download it from the link below.
As far as tire, I decide to go with another Bridgestone TH01 since I can easily get about 15k miles out it. I keep the pressure at 42 psi and check it at least once a week.
I also decided to replace the rear valve stem with a 90 degree one.
Happy Riding . . . . .
LeDude .... . . . . . .
LeDude is offline
Sponsored Links
post #2 of 22 (permalink) Old 04-29-2008, 11:55 AM Thread Starter
Insane Poster
LeDude's Avatar
Re: DYI -- Burgman 650 Rear Wheel Removal Instructions
Here is a copy of the instructions as of 04/29/08, it seems that some had problems downloading/viewing the document. The dowladable version will always be the lastest version for now since posts cannot be edited/updated on the forum after the 1 hour limit. I am using a free service to host the document for now, as such it has a 10 seconds delay before showing the link.
Removing the rear wheel off of the Burgman 650 is a simple endeavor which can be done very easily with a bit of planning.
Below is a parts, tools list and a step by step plan.
__________________________________________________ __________________________________________________ ___________
Parts list: -- New parts
Depending on the condition and age of your scoot, you may need some or all of these parts. I prefer to have them on hand since I do most of the work myself.
--> 2 Rear wheel bearing. I decided to use an aftermarket two sided sealed bearing, an SKF in this instance. Size: 6204-2RS.
-- ($18.00)
--> 1 Dust seal. Suzuki OEM part. Size: 28-47-7 ($4.00) Part#..: (09285-28001)
--> 1 Cotter Pin (25 cents)
I waned to change the stem on my rear wheel with a 90 degree one to make it easier to check the tire pressure. This would be a one time investment, especially if you get a steel one. Install the stem facing towards the left side of the bike away from the disk brake.
-- 1 90 degree valve-stem ($4.00). 90 degree stem -- New stem installed
Parts totalÖ.: $22.00 - $25.00
-- 1 Rear Tire. Brigestone TH01 160 / 60 R14 ($108.00) or your favorite brand
Tools list: -- Tools
--> A few pieces of 2x4/2x6 lumber to elevate the rear wheel
--> 3mm hex key
--> 8mm socket or wrench
--> 10mm socket or wrench
--> 12mm socket or wrench
--> 22mm socket or wrench
--> 24mm socket or wrench
--> Ratchet for your sockets
--> Pliers
--> Torque wrench
--> Small bungee cords
--> Plastic shim
--> Piece of tubing to use as a lever
Lubes & Cleaners list: -- Lubes / Cleaners
--> Moly paste lube or equivalent high temp lube
--> Disk break cleaner
--> General degreaser
--> Rubbing alchool
--> Cleaning towels/paper towels
Removal / Installation time: 30-60 minutes.
Elevate the rear wheel:
The rear wheel on the Burgman, while on the center stand, sits very close to the ground and getting the rear wheel off without removing the rear fender can be a very tedious affair if not impossible.
If you have the good fortune of owning a motorcycle lift/table then you know what to do. Otherwise you will need a few pieces of 2x4 or 2x6 to accomplish the elevation task.
This is how I went about elevating the center stand:
--> Place a piece of wood on the floor in front of the rear wheel. It was a lot easier to use the engine to get the rear wheel
-- up on the wood than to try and push it. Give it a little bit of gas and the rear wheel does the job for you.
--> Put the side stand down and steady the bike.
--> Push down on the center stand to get an idea as to where you need to place the other supporting pieces of wood
--> Place the other pieces of wood on the floor next to the one with the rear wheel resting on it.
--> Now push down on the center stand and prop up the scoot, it shouldnít take too much effort.
--> Check to make sure that the center stand legs rest firmly on the pieces of wood and can support the scoot.
--> Remove the middle piece, now you have a blank space where the rear wheel can fall into.
Ccenter stand elevated: 01-- 02
Rear wheel removal steps:
--> Remove the final gear case cover on the left hand side of the scoot with an 8mm socket/wrench.
--> Disconnect the brake lock cable. Start by removing the 10mm lock nut and loosen the 3mm hex screw (counter clock wise).
-- Now undo the two 12mm supporting bolts and the brake lock assembly should come right off.
-- Suspend it using a small bungee cord.
--> Remove the cotter pin with a pair of pliers.
--> Loosen the brake caliper 12mm bolts.
--> Remove the rear axle nut using a 22mm socket/wrench on the left hand side, to hold it while you use a 24mm
-- socket/wrench on the right side. I use a piece of tubing as a lever / extension to loosen the axle nut by slipping
-- it over the ratchetís handle. Place the nut and spacer aside.
--> Push the axle out halfway. Remove the collar / spacer between the swing arm and the wheel. There are two of
-- them. One has a lip and it goes up against the swing arm.
--> Pull the axle all the way out and the wheel should come loose.
--> Drop the wheel on to the ground.
--> Remove the rear wheel brake caliper and place a plastic shim between the brake pads. This way they wonít collapse
-- on you if you accidentally grab a handful of brakes.
--> Suspend the caliper with a small bungee cord.
--> Push the wheel out towards the rear fender and lean it slightly to the left to clear the fender.
--> Remove the inner wheel collar / spacer should fall out. It is a one long piece.
Rear wheel brake assembly: Rear wheel brake assembly -- Removed parts: Removed parts
Shim the caliper: 01 -- 02 -- Support the caliper: Support the caliper
In between steps:
--> Now that you have the rear wheel off, spend a bit of time cleaning / degreasing the inside of the hub.
--> Clean all the parts that came off the rear wheel.
--> Check your wheel bearings for proper play; replace them if you feel any resistance.
--> Check your stem for cracks, replace it if necessary or do what I did, replace it with a 90 degree one.
If you have the skills and tools to mount the rear tire, get going, otherwise find a nice bike shop that will do it for you for a reasonable price.
--> Once you have the new tire mounted, use a disk brake / contact cleaner to clean the disk brake.
--> Clean the wheel with rubbing alcohol or your favorite cleaner.
--> Lube the rear hub driven gear joint on the wheel and the hub housing.
--> Lightly lube axle and the inside of the collars.
Rear hub gear joint -- Rear wheel hub gear -- Axle hole
Rear wheel reassembly steps:
Reassembly is pretty much the reverse order of disassembly.
--> Start by inserting the left spacer, the big spacer into the final gear case.
--> Insert the axle and push it forward a bit.
--> Position the wheel under the scooter.
--> Place the brake caliper over the disk brake; try not to get any grease/dirt on the disk brake.
--> Remount the wheel, be patient and donít try to force it. It will fall into place once you have the right alignment.
-- If the wheel feels too heavy, place a peace of wood under the tier to help support it while you find the right fit.
--> Push the axle forward to support the wheel.
--> Insert the spacer, collar, the one with the lip goes against the swing arm, and push the axle all the way through.
--> Install the washer and rear axle nut (24mm). Tighten the rear axle nut to the specified torque level (72.5 lb-ft)
--> Install the new cotter pin.
--> Tighten the brake caliper nuts to the specified torque (19.0 lb-ft)
--> Install the brake lock arm and cable (12mm nut), tighten to the specified torque (19.0 lb-ft).
--> Adjust the rear brake. Position the brake lever in position/notch one. Turn the adjuster bolt clockwise until it
-- stops, donít over tighten it. Now tighten the (10mm) lock nut to the specified torque level (7.0 lb-ft).
--> Reinstall the final gear cover.
Thatís about it. You are done. Now take the scoot out for a spin and break in that new tire. Be careful for the first 50-100 miles as new tires can be a bit slippery.
Note: While I had the rear brake lock arm off, I noticed that there was some friction damage under the metal part of the housing against the rear swing arm. I placed a piece of adhesive foam tape between the swing arm and the cable housing to prevent any further damage.
LeDude is offline
post #3 of 22 (permalink) Old 05-14-2008, 04:37 AM
Active Member
Location: New York, New York City, Brooklyn, Fort Greene
Send a message via AIM to Slappy76 Send a message via Yahoo to Slappy76
Thanks for this great informative post. I have a couple of questions for you if you can help..
I was effected by the dreaded bad rear bearing this weekend at the New Holland, PA rally. When I took off the rear wheel the inner race and all the balls from the bearing (exhaust side) just fell off (it was shredded and mangled). I noticed I was missing one of the spacers when taking apart the wheel. It's the long one where the outside changes diameter slightly. Honestly I don't remember ever seeing that piece when I pull off the wheel before. Could Suzuki have forgotten to put that piece in somehow causing my bearing failure? (I have since ordered that piece)
Also now that the inner race and balls are gone, the outer race of the bearing still lodged into the rear wheel. How do I remove it? Do I pry it out with a screwdriver? How do you normally remove a bearing from the wheel? Do you HAVE to take it to a machine shop to press it in?
Finally where can I find the 90 degree stem locally? NAPA? I'd like to install that.
Thanks.
-Tony
http://burgmanusa.com/forums/viewtop...earing#p281543
Slappy76 is offline
post #4 of 22 (permalink) Old 05-14-2008, 12:25 PM Thread Starter
Insane Poster
LeDude's Avatar
Tony,
It would really surprise me if you were missing the big inner spacer, then again anything is possible. When I took my rear wheel off I had to reach in and take that piece out, so you might want to double check and see if it is in fact missing or just stuck in there.
As for the bearings, I would suggest that you buy a new set of sealed bearings. You can use a simple tool like this one or similar to pull the bearings.
HF bearing puller
There are a number of ways to insert bearings, you can build your own insertion tool from a few parts, threaded rod, a few washers and a couple of nuts.
If you don't have a lot of experience pulling bearings and such, it might be prudent to have a seasoned mechanic do it for you.
If the old bearing body is stuck, you might have to use a cutting tool to cut a few notches in it to weaken it structurally thus making it easier to pull out.
There is a lot of good info online for this procedure, here is a link that shows how to do it if you have never done it.
http://www.dansmc.com/wheelbearing.htm
I bought my 90 degree valve stems from a local motorcycle shop, they were like $3.95 each. Make a few calls to see if any of the local stores stock them. If you can't find one, let me know and I will get one for you and drop it in the mail. I highly recommend this upgrade, it has made life so much easier for checking and inflating the tire.
Here is a link to a 45 degree one...: 45 degree stems
LeDude is offline
post #5 of 22 (permalink) Old 05-21-2008, 12:27 AM
Turbo Poster
adentre's Avatar
Thanks Ledude very much for your informative post. I will be taking my tire off for replacement soon and this post is invaluable to me!!! I really appreciate it.
Andy
Andy
Intellectuals solve problems, geniuses prevent them. Albert Einstein
2003 650 blue Burgman
2006 400 grey Burgman with tow-pac (wife's)
adentre is offline
post #6 of 22 (permalink) Old 05-21-2008, 09:55 PM Thread Starter
Insane Poster
LeDude's Avatar
Andy,
You are welcome, I am glad it is proving to be of some use to some folks. I am also working on another DYI for the front and should have that out in the not too distant future.
LeDude is offline
post #7 of 22 (permalink) Old 05-26-2008, 06:03 PM Thread Starter
Insane Poster
LeDude's Avatar
Here is a new version of the Rear Wheel Removal Guide in a new format which hopefully will be easier to use and pirnt out.
This is going to replace the other document on the 4shared.com site as I will be phasing that account out.
Link to new document for..: DYI -- Burgman 650 Rear Wheel Removal Guide
LeDude is offline
post #8 of 22 (permalink) Old 05-26-2008, 06:55 PM
Insane Poster
Colchicine's Avatar
Yes! That is much easier to use! Thanks!
Kory's
Why Burgman? Because the world doesn't need yet another software engineer
playing make-believe outlaw, riding a Harley in a pirate costume. -larrysb
Colchicine is offline
post #9 of 22 (permalink) Old 07-14-2008, 11:28 PM
Active Member
Used your instructions today. Made the job easy.. If only Suzuki manuals could be so well written.. My compliments and thanks
WVPREZ is offline
post #10 of 22 (permalink) Old 07-15-2008, 01:25 AM
Turbo Poster
Send a message via AIM to flyerjmr33
You can save yourself a little trouble by removing the rear mud flap that holds the license plate. There are 2 pop rivets in the rear trim above it and 3 screws in the flap--- makes it a whole lot easier because the rear is now completely open and you don't have to jack the scooter up on wood blocks.
JR
Remember, no one is totally usless. They can always be used as a bad example!
****TRAVEL STOP****
flyerjmr33 is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
650 Rear Wheel Removal Hunter How To 13 10-07-2007 09:14 PM
Burgman 400 rear wheel removal lawrance Newbie Questions! 1 09-27-2007 05:57 PM
an 400 rear wheel removal! taffpike669 How To 8 07-19-2007 10:18 AM
Rear Wheel Removal?? gary Burgman 400 (pre-2007) 2 10-23-2005 07:21 AM
Removal of Rear Wheel RichC Burgman 400 (pre-2007) 1 09-21-2005 01:47 AM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
