Starter Removal, 650, and the body panels to facilitate that - Page 2 - Suzuki Burgman Forum
Reply
post #11 of 22 (permalink) Old 10-31-2007, 07:07 AM Thread Starter
Active Member
eclypser's Avatar
Send a message via AIM to eclypser Send a message via MSN to eclypser Send a message via Yahoo to eclypser
9. Floor mat removal
Note: This is probably the easiest step and one that can completed at any point before this .
1. Pry up a corner of the floor mat.
2. You can then just pull the mat up slowly. Make certain that you are applying force as close to the compression fittings as possible to avoid ripping.
3. Repeat for all four mats.
End: You have now finished removing the floor mats.
Wishes - When you wish upon a falling star, your dreams can come true. Unless it's really a meteroite hurtling to the earth which will destroy all life. Then you're pretty much hosed no matter what you wish for. Unless it's death by meteor.
--www.despair.com
eclypser is offline
Sponsored Links
post #12 of 22 (permalink) Old 10-31-2007, 07:22 AM Thread Starter
Active Member
eclypser's Avatar
10. Leg side cover removal
1. Remove the fasteners from the passenger foot rests.
(Shown with a bit on the bolts. This will not be on your bike.)
2. Remove the screw holding the rear of the cover to the passenger foot rest.
3. Remove the fasteners from the driver's foot rests.
4. Remove the three screws at the front of the foot board.
5. The front of the cover is held on with a compression fitting. You will have to pull off the cover from the front. If you find that the cover is not coming off at any point once you release the compression fitting, make certain you have removed all the fasteners.
Note: Do not remove the bolts holding the leg side cover to the foot board until you have removed the leg side cover. It will make pulling the cover off a lot more difficult if you do.
End: You have now removed the leg side covers.
--www.despair.com
eclypser is offline
post #13 of 22 (permalink) Old 10-31-2007, 07:31 AM Thread Starter
Active Member
eclypser's Avatar
11. Foot board removal
1. Remove the screws from the air intake on the right side.
2. Remove the screws holding down the top of the foot board.
3. Remove the bolts holding down foot board from the foot rests.
4. Lift the foot board off from the back pulling it away from the front of the bike.
End: You have removed the foot board.
--www.despair.com
eclypser is offline
post #14 of 22 (permalink) Old 10-31-2007, 07:41 AM Thread Starter
Active Member
eclypser's Avatar
12. Starter removal
12. Starter removal
The starter is located on top of the back of the engine.
1. Pull back the rubber boot on the wire connected to the starter and use a wrench to remove the wire from starter.
2. Remove the screws holding the starter to the engine. You may need a wrench to get them started.
(Shown with wrench on screw/bolt)
3. Pull the starter away from the engine case.
3. Turn the starter a quarter turn counter clockwise and lift it out.
Note: It may seem at first like the starter won't fit, but if you take your time and work with it, it will come out.
End: Congratulations you have finished the removal of the starter. Good luck putting it all back together.
--www.despair.com
eclypser is offline
post #15 of 22 (permalink) Old 10-31-2007, 08:44 AM
Insane Poster
Colchicine's Avatar
Congratulations on producing a new standard for the "How To" section! I'm sure hundreds of people will be thanking you for the many hours it took to put this together. Everyone else: bookmark this one and reference it whenever anyone needs to know to remove any of the body panels!
Kory's
Why Burgman? Because the world doesn't need yet another software engineer
playing make-believe outlaw, riding a Harley in a pirate costume. -larrysb
Colchicine is offline
post #16 of 22 (permalink) Old 10-31-2007, 12:55 PM
Insane Poster
GammelDansk's Avatar
Wow, this is fantastic!! Nice job!!
Still The Burger Queen
Former: AN650K4, Black Duc-Burger
GammelDansk is offline
post #17 of 22 (permalink) Old 11-05-2007, 08:45 AM
Jim
Jim's Avatar
Deserves to be a "Sticky", so now it is.
Pictures of Modifications and Accessories
Jim is offline
post #18 of 22 (permalink) Old 03-10-2008, 03:38 PM
Super Poster
Steve1948's Avatar
Re: Starter Removal, 650, and the body panels to facilitate that
Okay, now can you do one to remove all the body panels for a 400? Great job!
2005 Burgman 400 aka "Lola"
Blue (new to me)
1948 Cushman
1965 Honda trail 90
1966 Honda Scrambler 305
Steve1948 is offline
post #19 of 22 (permalink) Old 08-15-2008, 04:00 AM
New Member
Fantastic information here. Followed your step-by-step guide to remove the passenger back rest and the rear panel. Then installed a Givi base plate and my Maxia 52l topcase. Simple once all the 'prep' was done using your photo guide. You get a gold medal from me.
Scubado1057 is offline
post #20 of 22 (permalink) Old 03-03-2009, 02:02 PM
Super Poster
TheBlackMoon's Avatar
Send a message via Yahoo to TheBlackMoon
Thank you for such a detailed and informative guide (with pics, no less). Now I have the info needed to finish tearing down my bike. Others have been great at explaining the details, but without step-by-step pics, I've still been more than a bit wary. Now I feel confident enough to do it!
TheBlackMoon is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Changing body panels BobL Burgman 650 11 11-02-2008 07:19 PM
burgman 400 body panels zavsdad General Discussion 6 12-01-2007 09:15 AM
switching body panels mru Burgman 400 (pre-2007) 1 11-23-2006 01:09 AM
AN400 Plastic Body Panels mgreenfield How To 1 10-10-2005 11:08 AM
Removal of lower body panels pauljo Burgman 650 15 04-26-2004 05:57 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
