Fork Oil Replacement Step by Step AN650 - Page 2 - Suzuki Burgman Forum
Reply
post #11 of 42 (permalink) Old 01-11-2005, 10:37 AM
Super Poster
fork oil/springs
this week i removed the oil in the front shocks. the old oil looks like trans fluid. I'm looking to get a softer ride. on this site i read that the oil is 15wt. what oil can i put into the shocks to achieve the desired effect? if softer springs are the answer then where is a site to order them suzuki has no springs to replace the burgman spring other that original.
i have the dimensions in U.S. .185 wire dia. 13 11/16 overall with 4" closer wound. 1 3/8" total dia. for anyone interested it this for research.
corvairbob is offline
Sponsored Links
post #12 of 42 (permalink) Old 01-11-2005, 10:51 AM
Jim
Jim's Avatar
Quote:
Originally Posted by Dodger
Did my forks a while ago. Measured what came out of each fork, right 392ml, left 415ml (supposed to have 489ml each). Poured the old oil into a jar and left it sit. About 1/8 inch of water in the bottom of the jar along with a lot of crud. Would recommend everyone get the fork oil changed.
Dodger
How many miles on the scooter ?
Pictures of Modifications and Accessories
Jim is offline
post #13 of 42 (permalink) Old 01-12-2005, 09:23 PM
Active Member
Sorry Jim, I got called away. The bike has 5,824km (about 3,000 miles).
Never ridden in the rain. Only washed by hand (no power wash).
Dodger
Previous owner of '04 AN650
*Addeded by system admin.*
(Dodger has left our forum. His posts will remain as a contribution to our community.)
Dodger is offline
post #14 of 42 (permalink) Old 02-12-2005, 11:04 PM
Super Poster
Quote:
Originally Posted by allwalk
Hi corvairbob.
The 650 comes shipped with 10 wt oil in the front. I was experiencing the front end bottoming out. Thats why I went to a thicker oil. It increases the dampening and made my ride smoother. I found the stock oil was great for speeds under lets say 50 mph. Over that and the front end couldnt absorb the bumps fast enough. If you go to a lighter oil I would guess that the bumps would be felt even more at higher speeds.
well i put in 5wt fork oil and it did nothing for the ride today. looks like the heavier oil is the way to go just what wt did you install alwalk? it is not hard to replace. but i want a smoooooth ride and not one that just about throws you off the bike. like others on this site the burgy has way to hard a ride for a scooter. i miss the helix ride alot. thanks bob p
post #15 of 42 (permalink) Old 02-13-2005, 06:55 AM Thread Starter
Insane Poster
allwalk's Avatar
Quote:
I installed Bel-Ray 15 wt fork oil and the ride improvement was incredible. Definetely try it. If 15 doesnt work than try 20wt. BTW when I did my fork oil I weighed around 200 lbs. , just to give you some idea of the bikes load.
Allan - Only bikers know why dogs hang there heads out the window!
AN650K3 Flaming Silver see for yourself in my photo gallery
allwalk is offline
post #16 of 42 (permalink) Old 02-13-2005, 09:21 AM
Insane Poster
seatec's Avatar
But what do you weigh now
seatec is offline
post #17 of 42 (permalink) Old 02-13-2005, 01:42 PM Thread Starter
Insane Poster
allwalk's Avatar
Quote:
180 lbs and 4 inches off the waist line!!!!!
allwalk is offline
post #18 of 42 (permalink) Old 03-30-2006, 10:12 PM
Super Poster
mulepwr's Avatar
I have the Hyper Pro springs on order. Will post here when I have installed them. Will take picts of them againist the stock spring and note any difference in (recommended) oil.
mulepwr is offline
post #19 of 42 (permalink) Old 04-24-2006, 11:34 AM
Active Member
seeker's Avatar
Watch those spacers!
OK - a word of warning. The fork oil replacement job is fairly easy, except for one step. The tricky (and dangerous) part is getting the caps back on the forks. You really need 2 people for this step. I sliced my thumb wide and deep when the cap slipped and the super sharp metal of the spacer shot up and attacked me.
Here is what to do - Put the bottom of the fork in a vise. Have an assistant hold the slider tube up and also keep it from turning (preferably with a pair of gloves on). Somehow position your body atop the fork and tighten the cap with a straight down motion to prevent cross-threading. Once you tighten to the point where the slider spins despite your assistant trying to prevent that spinning, you are done.
Also - Good luck finding the 12mm and 17mm hex heads!!! I looked all over town and finally found them in a 3-pack of 12, 15 and 17 for $7.99 from AutoZone. Sears didn't carry any bigger than 12, and this was a big, ugly Allen Wrench for $9 and change. No luck with Parts America.
Suggestion - get these hex head tools before starting the job!
seeker is offline
post #20 of 42 (permalink) Old 04-25-2006, 09:32 AM
Jim
Jim's Avatar
Re: Watch those spacers!
I installed the fork tubes in the steering head (triple tree), and tightened it up before I installed the cap. That way you only have to push it down an inch or so, and you don't need the assistant.
Jim is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
DIY Oil Change on 2007 Burgman 400 - Step by Step, BIG Pics i64X How To 79 03-06-2017 10:15 AM
Step by step on the 600 mile maintenence? TJ99 Burgman 650 2 06-13-2008 11:52 PM
Acceleration Improvement Step by Step? mgreenfield Burgman 400 (pre-2007) 19 07-25-2007 12:56 AM
My first step! gbbear Who are you? Where are you from? 6 10-05-2005 08:43 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
