Tupperware mounting points - Suzuki Burgman Forum
 2Likes
  • 1 Post By E.D.
  • 1 Post By sbett
post #1 of 6 (permalink) Old 07-31-2014, 12:37 AM Thread Starter
Active Member
Gabby's Avatar
Don't know if they've done this, but it sure would be nice if they beefed up the mounting points on the tupperware, mainly the hooks on the tail and the front mounts on the leg shields.
Also, how about offering a front fender 'mud flap'? I've got nearly 87k on my 2005 and over the years little chunks of asphalt and other debris has either gotten in between the fins, or bent them over. Radiators cost $500 to replace.
I was once asked if I was scared riding all over the country by myself, "NEVER!" I replied, but there was this one time in Mexico....
Gabby is offline
Sponsored Links
post #2 of 6 (permalink) Old 07-31-2014, 03:47 AM
Insane Poster
ChipDoc's Avatar
Send a message via Skype™ to ChipDoc
2007 Burgman 650
Pearl Glass White
Givi windscreen
Givi E450 trunk
Bestbackrest
RAM Mount
Garmin Nuvi 50LM
ChipDoc is offline
post #3 of 6 (permalink) Old 08-03-2014, 12:54 PM
Super Poster
John Bailey's Avatar
I just finished taking off all the tupperware to do my 14,500 maintenance on my 2008 400. This bike is new to me so I hadn't taken off any of the tupperware before. I found both front mounts broken on the leg shields and one on the tail piece. So, I guess the 400's have the same problems.
John
John Bailey is offline
post #4 of 6 (permalink) Old 08-04-2014, 03:30 PM
Insane Poster
Garage
Now, my fender seems more than long enough in the back. Seems like the stock fender to me. Is this just the 400?
GK13 is offline
post #5 of 6 (permalink) Old 03-27-2016, 01:46 AM
Insane Poster
E.D.'s Avatar
This Thread is right on my topic, even if it is almost a year old. Those darn mounting points on the tupperware, mainly the hooks on the tail and the front mounts on the leg shields are really crappy. Mine broke off on the front of the legshields. I've seen some used ones, and they also have the mounting tabs broken off. It is a real shame that Suzuki had to make the tupperware fasteners so flimsy! I have not seen a solution on here, has anyone come up with one?
I had to fix mine, I already had the front of the red left lower leg shield come loose and catch the wind, while I was going 100 mph. It went with a great big bang! Busted the front half of it right off. So I was able to find one used one at a decent price at $50, shipped from Canada, and the color was black. It worked OK, since my B400 scoot is red and black anyway. The problem is that it had the front tabs broken off (not unexpected) so I came up with a solution that I think will hold up and doesn't look too bad, at least its better than it bustin off again. The lower leg shield should have had a 90 degree bend (flange)at the front that is screwed to the plastic beside the radiator. But it only has a small flange at the bottom, and the top fits flush against the side of the scoot. So what I did was drill some small holes (about 3/16 inch), one at the top and one at the bottom, and put a tie wrap thru it and fasten it, on each side of the scoot. You don't really notice it unless you look for it. So I included some pictures of the right side here to show what I did. Left one is the same. Anybody have any better ideas?
Next project is to fix the piece on the back between the tail lights. It has come loose when I hit a bump.
hscohen likes this.
E.D. is offline
post #6 of 6 (permalink) Old 03-13-2017, 08:54 PM
Super Poster
sbett's Avatar
Temporary fix for plastic panels that have broken mounting points.
The biggest problem is that when one breaks and is not properly repaired, others may break.
When a push pin broke on the panel below the tail light. I used the plastic zip strip solution.
This did not provide a tight enough fit to prevent other mounting points from breaking. It did keep
the panel from falling off.
Since the mounting points have snapped off, I am not sure that there is a solution short of purchasing
a new panel.
My temporary fix is to use clear plastic mailing tape. It is almost invisible and provides a tight fit
between panels for a year or more. It does prevent the problem from getting worse and
if I had used it when the panel first came loose, I would have kept the other mounting points from breaking.
hscohen likes this.
2006 Burgman 650
Garmin NUVI GPS
Cruise Control
taller Givi Windshield
Givi E33 Top Box
Driver's Backrest from Jac Vinson
sbett is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Mounting to Tupperware vs. Frame asolof General Discussion 3 12-06-2010 08:46 PM
side bag mounting points on pillion handles? DFOMara General Discussion 22 06-20-2008 09:58 PM
12 Points to Ponder Rollingbones Jester's Court 0 12-04-2007 07:46 PM
Tell me the negative points. wilythek Burgman 400 (pre-2007) 18 09-28-2005 12:04 PM
Tell me the negative points. wilythek All others 8 09-26-2005 11:14 AM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
