Oil Filter Reviews - Suzuki Burgman Forum
Reply
post #1 of 15 (permalink) Old 07-24-2004, 10:18 PM Thread Starter
Turbo Poster
Pappy's Avatar
Send a message via Yahoo to Pappy
Oil Filter Reviews
http://www.twocreeks.net/toby/oil_filters/index.shtml
Fight Cancer:
Former Burgman 650 Owner!
Honda Silverwing ABS
2006 Vespa GT200 Pearl White
Homepage:
Pappy is offline
Sponsored Links
post #2 of 15 (permalink) Old 07-25-2004, 07:24 AM
Insane Poster
allwalk's Avatar
Great link Pappy! I had seen it before but lost the link. I think this is very valuable info so I turned your post into a sticky so that it will remain at the top of the Web Links section and not get cycled down with new posts. Thanks again.
Allan - Only bikers know why dogs hang there heads out the window!
AN650K3 Flaming Silver see for yourself in my photo gallery
allwalk is offline
post #3 of 15 (permalink) Old 07-25-2004, 08:49 AM Thread Starter
Turbo Poster
Pappy's Avatar
Quote:
Glad I cpuld finally offer something besides my inhehent stupidity for a change!
Fight Cancer:
Homepage:
Pappy is offline
post #4 of 15 (permalink) Old 07-13-2005, 10:25 PM
Insane Poster
frugality's Avatar
Pappy, thanks for the link. I don't want to make it sound like I'm posting this to poo-poo your link, but I don't think his analysis was very sound. To me, it seems he cut come cans apart, looked at the contents, and if they appeared to be of high quality construction, he considered it a good filter. Personally, I think he was too keen on the metal end caps and against the paper/cardboard end caps. That really shouldn't matter much. What matters is that the oil goes through the pleats, where the filtering takes place. As long as the cardboard ends keep oil from flowing around the end of the pleats, it should be considered functionally 'good'. What's important is the gluing of the filter element to the end caps, to seal the ends and not let the oil bypass the filter element.
I think he missed the most important part of the analysis -- actual surface area of the filter element. He gave overall dimensions; big whoop. What he should have done is measured the depth of the pleats, the height of the element, and counted the number of pleats, to get the actual surface area. Without doing a much more expensive experiment to find out which brand's element catches more gunk, this would be the best way to estimate how good the filter is. One of the shorter filters had a lot of pleats, and probably does a better job of filtering than some of the taller filters with fewer pleats.
Just my $0.02
Dean
2005 Burgman 650|silver|50mpg|25k miles
2010 VW Jetta Sportwagen TDI|silver|42mpg|56k miles
2000 VW Golf TDI (diesel)|45mpg|sold at 284k miles
frugality is offline
post #5 of 15 (permalink) Old 07-13-2005, 11:02 PM Thread Starter
Turbo Poster
Pappy's Avatar
Heh heh. Ain't MY link! Just passing it on to give everyone ELSE an ulcer :P
Fight Cancer:
Homepage:
Pappy is offline
post #6 of 15 (permalink) Old 08-09-2005, 08:40 PM
New Member
Suzukiscoot's Avatar
Oil Filter Review
So you want a review that is more technical?
Sink your teeth into this one!
http://motorcycleinfo.calsci.com/Filter ... OilFilters
Steve
Bakersfield, California
Suzukiscoot is offline
post #7 of 15 (permalink) Old 04-27-2006, 12:07 PM
Insane Poster
Buffalo's Avatar
Not sure why these guys are getting worked up over cardboard end caps on the filter element. The filter element is made of paper in all these filters. Cardboard is just thick paper. If saturating the cardboard with oil causes it to come apart then saturating the paper element with oil should cause it to come apart also and the elements must be saturated with oil to work. The purpose of the end caps is to hold the pleats apart so that the oil can flow thru the pleats. The force of the flow is thru the pleats.
For what it's worth I've used Fram filters almost exclusively for 40+ years and have never had one to fail and I tend to drive vehicles till they are used up instead of swapping every couple of years. The last pickup I traded in had 196,000+ miles on it. Still had good compression and only used about a half quart of oil between changes which is what it had done since it was new.
--- Craig AKA Cliffhanger----
"Big Red" 2007 Red Executive - 134,929 miles
"Little Blue" 2006 Blue 400S - 47,595 miles
Buffalo is offline
post #8 of 15 (permalink) Old 12-23-2006, 01:23 AM
New Member
Burgman 650 Oil Filter
Can anyone tell me if the 2006 Burgman 650 uses the same oil filter as the 2004 650 did?
Also, where can I buy the Purolator ML16818 oil filter, it is listed in the Purolator guide, for the 2004 Burgman650?
And if they are the same from year to year, then this will be the number for the filter than I want.
Thank you,
bill
Alb. NM
06 Exec.
Thank You,
bill
Alb. NM
06 Burgman
WANLIKER is offline
post #9 of 15 (permalink) Old 05-11-2007, 08:52 PM
Turbo Poster
http://www.calsci.com/motorcycleinfo/FilterStudy.html
I like this study that says NO oil filter is good enough for the Burgman!
NONE are recommended!
I just left the filter off and run it that way!
Gary
Gars is offline
post #10 of 15 (permalink) Old 11-15-2008, 05:21 PM
Insane Poster
QuantumRift's Avatar
Send a message via AIM to QuantumRift Send a message via Yahoo to QuantumRift
Re: Oil Filter Reviews
Can we get something more current than 4 years old?
"If Opportunity knocks, and he's not at home, Opportunity waits."
KRISS Headlight Modulator
Kisan TailBlazer Brake Light Flasher 20W-D - Plug-In
Manic Salamander Bar End Weights (with throttle lock)
Grip Puppies
3Brothers Backrest
QuantumRift is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Book Reviews Big Jake General Discussion 3 03-28-2011 10:22 AM
It's even better than the reviews said it would be Waddell Burgman 650 25 02-19-2009 08:26 PM
MP3 Reviews NormanB All others 2 06-02-2006 05:24 PM
MSF Course reviews URL Prrrowler General Discussion 3 10-01-2005 01:36 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
