Burgman 200 Battery Went Flat - Suzuki Burgman Forum
 2Likes
Reply
post #1 of 12 (permalink) Old 01-21-2017, 04:14 AM Thread Starter
New Member
Hi, my YTX9-BS battery went flat and so I changed a new one, same brand Yuasa and same model, but it still went flat after about 3 days of non-use.
I measured the parasitic current draw, is about 2mA, and at 5000 rpm, the voltage is about 14 volts.
I am at a lost why the battery went flat.
Any ideas? Thanks in advance.
captainfish likes this.
Armadillo is offline
Sponsored Links
post #2 of 12 (permalink) Old 01-21-2017, 09:11 AM
Super Poster
san diego joe's Avatar
Garage
My idea is that you should give info on yourself, your current and past scooters, where are you? and also more about the situation that led up to this problem.
No need to post twice, but we do need more to go on.
Old Burgman riders never die..they just fade away.
Home to that place that we all will someday stay.
A place in the sky where everyone rides every day.
And that is my epitaph....
san diego joe is offline
post #3 of 12 (permalink) Old 01-21-2017, 02:59 PM
Insane Poster
Liamjs's Avatar
Was the new battery fully charged when it was put away for three days? New ones often need to be "topped off" when you first get them. Maybe put it on a charger for 24 hours and try it again.
"What is your measure of success? Warren Buffett has always said the measure is whether the people close to you are happy and love you." Bill Gates
Liamjs
Ingrid - '07 Blue Burgman 400 (56k mi) - original owner
Jesse - '05 Silver Burgman 650 (27k mi) - 3rd owner
Liamjs is offline
post #4 of 12 (permalink) Old 01-21-2017, 04:38 PM
Insane Poster
E.D.'s Avatar
Well Armadillo, (I like that name, very popular in TEXAS) seems like you did exactly the right thing, checking the charging voltage (14 Volts) and checking the parasitic current draw (2 ma). All looks well there. Possibly something is drawing the battery down when you aren't looking? One thing to try is to remove the battery, charge it fully, then let it sit for 3 days and see if it holds the full charge. This will determine if there is a problem with the battery or not. If the battery stays charged, reinstall it and put a Battery Tender Plug on the battery terminals, then place it on a float or trickle charger to keep it charged.
Since you are new here, Welcome to BUSA from Tampa Bay Florida USA.
If you haven't already done so, please fill out your User profile in the Control Panel to tell us about your bike, location, etc.
Please add your location onto the Burgman Owners Map:
https://www.zeemaps.com/map?group=1693807#
Cheers!
1977 Honda CB 750 Silver
1977 Penneys 50 Moped Red
1974 Yamaha 360 MX Yellow
1973 Yamaha 80 MX Silver
1972 Honda QA 50 Red
1970 Kaw H1 500 Red
1968 Kaw 120 Scrambler Red
1968 Kaw 120 Scrambler Blue
but Toyota's Rule, no doubt!
John 3:16
Burgman Owners Map:
https://
Burgman Travel Stops Map:
https://
E.D. is offline
post #5 of 12 (permalink) Old 01-21-2017, 10:49 PM
Super Poster
Should'n it still be under warranty? If not, try this. Put your phone on video, lay it under the seat and shut it. Pull it out and see if the seat bucket light turned off when the seat was closed from the video. That's the only thing I can think of. If you replaced a good battery with another good battery (truly doubt they were/are bad) it was a waste of money, but I have done the same thing in the past. Im still on my O.E.M. battery at 10,000 miles in the first year. The longest my Burg. 200 has sat non ridden was 5 days straight/never started/no tender/in below freezing weather when it snowed. It was outside with a cheap cover on it. Started right up no problem. Under normal conditions it gets ridden everyday. Let us know what you find.
sc00ter is offline
post #6 of 12 (permalink) Old 01-22-2017, 01:05 AM Thread Starter
New Member
Battery Flat - "Check Trunk Box Light"
Quote:
Thanks sc00ter,
I think you hit the nail, because lately I didn't think to close my trunk box. I just dump my helmet in and left. I studied the wiring yesterday and discover that the trunk box light is directly hook up to the battery through the trunk switch. The Gel battery is 8AH and the trunk light is 3.4W, so it works out 0.283A and the battery will goes flat in about 28 hours, slightly over a day. OK, it sounds logical, so I will fit the battery up later. I think your video handphone method will definitely work.
I have charged the battery using the special Gel battery charger and the battery hold the voltage over a night. I think the battery survive this time round. Though the battery is still under warranty, cause is new, but is my mistake here. I will *REMEMBER* to close the trunk box from now on.
I didn't know there is a light in the trunk box, LOL. You see, I just passed my bike license and Burgman 200 is my first bike. So this always catch the inexperience rider, I think and Man!, it cost me One Gel $battery and a lot of time in it. Glad that it should be solved soon.
But Burgman should have installed some fail safe and fool-proof circuit out of this simple light switch problem that can kill a battery. Maybe like time-out circuit, some sought.
There is another thing I learnt out of this episode and want to share here. Jump-Start the scooter. That's why it killed the first battery. Because it's a gel battery and it don't like to be jump starter when the battery is flat because a lot of current will be charging the battery. Per my experience, the scooter alternator may also be damaged because it's not designed to rapidly charge the battery from zero and run the scooter. Fortunately the scooter engine stopped shortly because the alternator cannot supplied the current draw. Luckily for me, the alternator was not damaged. But I think I did put a strain on it. The first Gel Battery was damaged and had an internal short. So, never jump start when a Gel battery is installed. Expensive lesson learnt.
Thank you all.
post #7 of 12 (permalink) Old 01-22-2017, 01:46 AM
Super Poster
I have a clunker 01 Ford Ranger and if you leave a door ajar (with the interior light on) or headlights on the truck will shut itself down to protect the battery from going dead. It has come in handy several times as the seat belt will catch in the door every now and then. To bad Suzuki couldn't do the same with the trunk light. If the trunk light proves to be the cause of your dead battery, for extra piece of mind you could either remove the bulb (its not that great of a trunk light anyways) or replace it with a led bulb (what I may do, hopefully brighter!). My full face helmet fits better laying on its side under the seat. If I set it in upright the seat does not close right, thus leaving the trunk light on, hence the video phone idea.
sc00ter is offline
post #8 of 12 (permalink) Old 01-22-2017, 02:17 AM Thread Starter
New Member
Removing the trunk box light box is a good idea as I don't need it anyway. BUT, have to remove the front and lower frame cover. It's not a easy job. Hope someone can put up a Youtube video how to dismantle the front and lower frame cover to dismantle the bulb.
post #9 of 12 (permalink) Old 01-22-2017, 10:48 AM
New Member
zmanH2's Avatar
Garage
Quote:
Originally Posted by Armadillo View Post
Thanks sc00ter,
Thank you all.
So have you confirmed that it was the trunk light?
Also, I've read a few threads here stating they were able to jump start their scooter using 12v car battery (engine not running) without issues.
zmanH2 is offline
post #10 of 12 (permalink) Old 01-22-2017, 01:53 PM Thread Starter
New Member
Yes confirmed, its the trunk light for sure, catch newbies every time. One tiny light bulb, in the day time, I cannot visualize it ever existed in the trunk.
I think you would be able to jump start provided;
1) the battery is not flat like Zero Volt
2) you are using lead acid battery.
Based on my bad experience, I would not recommend it if you are using Gel Type Battery because manufacturer written clearly, never allow the charging current to exceed 9A. Please note charger for lead acid accumulator cannot be used on Gel Type Battery, at least that's what the manufacturer said and what Burgman manual said. I mean, Who ever read manual, right? I don't, of course, until problems happened, right? I paid and learnt the hard way.
Anyway, I hope to disable the trunk light but at the mean time, I will just slam the trunk shut and never ever have to jump start again.... Hopefully... Cheers
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Suzuki Burgman 200 Battery Drain Flat Armadillo Burgman 399cc and below 2 01-22-2017 09:18 PM
after flat battery.. no start busman1239 Burgman 650 7 09-26-2012 02:08 PM
Flat battery twice! Lazyacre Burgman 650 37 10-12-2011 06:56 PM
Just flat or is it a dead battery. Treb Burgman 400 (pre-2007) 12 03-20-2006 09:52 PM
Flat battery -Twice...... Normsthename Burgman 650 7 01-30-2006 02:53 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
