Normal Air Pressure Loss ? - Suzuki Burgman Forum
Reply
post #1 of 15 (permalink) Old 08-25-2010, 05:23 PM Thread Starter
Active Member
How much tire air pressure loss would be considered normal ? I checked mine when I got it. Front had 33 and back had 41 - just as specified. Month later both were down about 4 lbs., so I put air in them to restore those numbers. In the last week, both have lost a couple more lbs. I guess if people are checking these tires every time they ride, then I should expect this is normal; otherwise, they wouldn't check it so often. But I need to hear you say it. Dealer told me when I bought it to check it once a week or so.
Please ride safely, and pray that I do.
clappd is offline
Sponsored Links
post #2 of 15 (permalink) Old 08-25-2010, 06:31 PM
Insane Poster
QuantumRift's Avatar
Send a message via AIM to QuantumRift Send a message via Yahoo to QuantumRift
Re: Normal Air Pressure Loss ?
Yes, check your tire pressures at LEAST once a week.
What you report is about what I see with my tires as well, and the tires are < a year old.... So I just check 'em and add air as necessary.
"If Opportunity knocks, and he's not at home, Opportunity waits."
KRISS Headlight Modulator
Kisan TailBlazer Brake Light Flasher 20W-D - Plug-In
Manic Salamander Bar End Weights (with throttle lock)
Grip Puppies
3Brothers Backrest
QuantumRift is offline
post #3 of 15 (permalink) Old 08-25-2010, 07:30 PM
Insane Poster
Buffalo's Avatar
Motorcycle tires don't hold a very large volume of air compared to a car tire so they don't have to loose much air to drop the preasure down a few lbs. Just the litte bit of air you loose when you put the gauge on can drop them a lb or so.
--- Craig AKA Cliffhanger----
"Big Red" 2007 Red Executive - 134,093 miles
"Little Blue" 2006 Blue 400S - 47,506 miles
Buffalo is offline
post #4 of 15 (permalink) Old 08-25-2010, 07:52 PM
Active Member
JeffC_58's Avatar
The dealer was correct - you should check all tires once a week, especially motorcycle and in our case, scooter tires. Outside air temperature makes a difference too. So as the seasons change, be sure to check tire-pressures frequently.
Jeff
She calls me Scooter
05 650 - Silver
Clearview Medium, Gray tint
JeffC_58 is offline
post #5 of 15 (permalink) Old 08-25-2010, 07:53 PM
Turbo Poster
Terry Dill's Avatar
Send a message via Yahoo to Terry Dill
My scoot loses about 3 pounds of air a month. I even have a plug in the front tire and it doesn't lose anymore air than it did when it was new.
You are not lost until you run out of gas.
46 yr riding motorcycles, first 1964 Honda 90
Lifetime GWRRA Member
Clearview Windshield, Mirror Turnsignal Conversion
Stebel Horn, McCruise, LED Voltmeter,
Besteem 929 Top Case, GIVI E21s
Brake Res. Ram Mounts, Garmin EMAP
SAENG Quick Scans
Terry Dill is offline
post #6 of 15 (permalink) Old 08-25-2010, 08:20 PM
Insane Poster
Daboo's Avatar
Garage
You might put some saliva on the valve stem opening to see if you have a slow leak there.
I find it interesting that my tires will lose air if I'm not riding...but hold air just fine if I'm riding each day.
Chris
Elnathan - 2014 BMW F800GT
- 2011 Honda NT700V 30000+ miles (Gone, but not forgotten.)
- 2008 Suzuki Burgman 400 ( AN400K8 ) 27,389 miles (Gone, but not forgotten.)
- 2007 Suzuki Burgman 400 (AN400K7) 48,969 miles. (Gone, but not forgotten.)
IBA# 49894
True Rounder = 0-20's - Rounder to 100's+ Red Hot Rounder
Daboo is offline
post #7 of 15 (permalink) Old 08-25-2010, 09:23 PM Thread Starter
Active Member
Quote:
Chris
Maybe that's my problem ? I screwed my right knee up good and haven't been riding much at all for about 3 weeks now. If I had to hold any weight up with my right leg/knee, I would be in trouble. Looks like a rebuild is sure to come.
clappd is offline
post #8 of 15 (permalink) Old 08-25-2010, 11:20 PM
Turbo Poster
I find I can go several weeks with only minimal loss of air pressure, maybe 1-3 PSI. It's possible that your valve cores are not tightened fully. Metal valve caps with a tool on the end that fits the valve core are available cheaply at auto parts stores and are recommended over the plastic ones due to superior strength.
When I replace a tire I use a NEW valve core just to minimize the possibility of leakage -- seems to help a bit.
Ray Nielsen, in Minneapolis and going for a long ride on Friday!
Gonpher coughie
ray nielsen is offline
post #9 of 15 (permalink) Old 08-26-2010, 12:26 AM
Turbo Poster
Just Me's Avatar
Every time you check tire pressure with a barrel type gauge that pushes out a stick with numbers in it you lose the amount of air in the barrel gauge so I bought a digital gauge. New tires were mounted on July 18 and as of yesterday -1psi in the front and -2 in the rear. Not bad.
'12 650
Givi windshield
VIP top box with optional wrap around backrest
Puffy seat
3Brothers backrest
Rostra electronic cruise control
Car tire
Ram iPhone mount
Just Me is offline
post #10 of 15 (permalink) Old 08-26-2010, 12:18 PM
Insane Poster
The amount of air that pushes the piston in a barrel gauge is negligible. What does matter is properly seating the gauge each time you press it down on the valve stem so as not to lose excess pressure.
Grip Puppies
3Brothers Backrest
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
has anyone done something about 400 oil loss? GARider Burgman 400 (pre-2007) 21 10-14-2015 01:33 AM
Loss of speed? why? Waldo Burgman 650 25 10-28-2008 11:40 AM
Slight Loss Of Air Pressure? GBB Newbie Questions! 2 06-05-2006 05:56 PM
sharing a loss mrlizzzard The Tavern 28 10-02-2005 01:31 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
