Ideas for emergency kit? - Suzuki Burgman Forum
 8Likes
Reply
post #1 of 14 (permalink) Old 01-01-2017, 05:10 PM Thread Starter
Active Member
Outdoorsguy's Avatar
I just bought one of those Schumacher RedFuel jump starters for an upcoming trip where our vehicle may be sitting in an airport lot for almost three weeks in the winter cold.
I bought the small unit that is not much bigger than a large phone and can also charge phones and tablets.
I thought this would be a good thing to throw in the Burgman for long trips seeing how there's no way to start it other than a jump if the battery shits the bed.
It would appear that I would need to make a set of small leads from the B400 battery to hook up to. One for the + terminal with a small clip and one longer lead to find a ground somewhere on the bike for the - .
Anyone have any input on this for me? Perhaps there's an easier way? Or something I'm overlooking?
And while we're on it, Is there any product you guys are using in the event of a flat to get you up and running again? I'm thinking one of those "fix a flat slime" kits? Any experiences?
I want to have this all set up to go over the winter. I'm counting on the experience here to help me set this up correctly. Thanks!
Outdoorsguy is online now
Sponsored Links
post #2 of 14 (permalink) Old 01-01-2017, 05:53 PM
Insane Poster
Dave_J's Avatar
In the past, I have not had any battery issues. I stopped riding my 650 in Oct this year and may have started it once in Nov. On Dec 29 I rode it up 41 miles to have lunch with my old crew and it started a bit slow but it did start.
Some roadside flairs or personal strobe kit is handy. You put one of those strobes under a traffic cone and it can be seen for over a mile.
One or two MSR fuel bottles.
Snacks and water.
Small socket set.
Flat tires YES. I have a mushroom tire plug kit and a small "Slime" air pump I carry on my bike for trips.
Plug Kit
MSR Fuel Bottle
Lightman Personal Strobe
Outdoorsguy likes this.
Dave_J is online now
post #3 of 14 (permalink) Old 01-01-2017, 06:42 PM
Super Poster
Steve_YYZ's Avatar
Ok, everyone's idea of what to carry on trips will vary, but this is what I carry. And you'd be surprised just how small a package this all packs down into. Heck, this is all under my seat all the time actually.
- First Aid Kit
- Small 12V Airpump
- Tire Kit (Slimy worm type plugs, several sizes)
- Small 12V lithium booster battery (recharged @ start of each riding season)
- home-made very small jumper cables.
- Space Blanket (those aluminized type sheets)
- one 6" vice-grips
MP Tool (Metric)
https://www.motionpro.com/product/08-0161
Metric Allan Key set like this
Steve_YYZ is offline
post #4 of 14 (permalink) Old 01-02-2017, 12:55 AM
Insane Poster
E.D.'s Avatar
I keep lots of stuff on my B400. I keep a large zip lock bag with a big assortment of mechanical tools in it, plus electrical testers.
Tactical Flashlight(I carry this all the time anyway). Roadside Emergency Reflector. 12 Air Compressor, Flat tire repair plug kit. I keep Ride-On tire sealant in both my tires, Assorted Zip Ties (the large ones are handy if you have to take someone into custody). Electrical tape. Duct Tape. Small Motorcycle jumper cables with a charging plug. (to use the cables, you simply plug the cable into the charging plug on the bike, and connect the other end to an available 12 v battery) A charging plug connected directly to the battery, minimum #10 Gauge Copper Wire for Starting/Jumping Purposes. (Realize that your Battery WILL go dead one day, so be sure to GET THIS DONE BEFORE YOU NEED IT!) i made this jumper cable setup, and when my battery died last November, and I was glad I had it ready, it worked perfect the first and only time I used it so far.
Spare Micro USB Cables.
A stretchy cargo net is also very useful.
Also carry some small spare parts:
Fuses
Starter Solenoid
a few pieces of various insulated wire
On a Long Road Trip, I would carry an extra set of brake levers.
Check these links below out for useful items:
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
I might think of more stuff later, but this will get you started on being prepared for almost any emergency/disaster.
1979 Honda CB 750 Silver
1979 Penneys 50 Moped Red
1974 Yamaha 360 MX Yellow
1973 Yamaha 80 MX Silver
1972 Honda QA 50 Red
1970 Kaw H1 500 Red
1968 Kaw 120 Scrambler Red
1968 Kaw 120 Scrambler Blue
but Toyota's Rule, no doubt!
John 3:16
Burgman Owners Map:
https://
Burgman Travel Stops Map:
https://
E.D. is offline
post #5 of 14 (permalink) Old 01-07-2017, 09:00 AM Thread Starter
Active Member
I bought one of those little jump starter packs. It's not much bigger than my phone. It's the Schmacher RedFuel at Walmart for $48.
Sure enough.....the day after I bought it, the wife's car would not start in -2* weather after work. I hooked it up and it started immediately. The charge setting even still showed 100% after.
I just need to make a set of smaller leads to hook onto the Burgman battery in case I ever need to. Well, only the positive. The negative has to go to another metal source, but I should be able to find something, especially if the lead is made long enough.
Doc Wheezer likes this.
post #6 of 14 (permalink) Old 01-21-2017, 11:06 PM
Super Poster
I have a Cruz Tool mid-level set that I carry on group rides. And a MSR fuel can. But me personally, I have road side recovery thru my motorcycle insurance policy. For both the Burg. 200 and my wife's Spyder. I will probably jinx myself but I have only got 1 flat on a bike in my life so if I get one, I will call the roadside recovery. Have used it on a friends bike. Told him to take mine back and told the insurance company I was borrowing his. He had a v-belt snap. Insurance company didnt care, told me it covers any bike that Im using! I do plan on getting some of those new school,tiny led road side markers that do the siren pattern, while waiting for a rescue. Small, bright and light. Will post the brand name when I get them.
sc00ter is offline
post #7 of 14 (permalink) Old 01-22-2017, 10:07 AM
Super Poster
Doc Wheezer's Avatar
Location: ARMED and Quietly Riding Around The Mojave Desert
They are great aren't they!
These little "Jump Starter packs" were discussed on this thread
portable battery jump starter
Some members, for some reason, prefer to carry jumper cables and hope for help. Not me. I ride all over the Mojave desert. I can ride for 90 mins. and only see 2-3 cars. That's slim pickens hoping for help while standing there holding your cables in your hand.
I bought my Antigravity brand pocket jump starter two years ago and love it. I have never had to use it for myself. I have used it to jump start other peoples vehicles, a Ford F150 and an Aston Martin at the Fashion Show Mall on LV BLVD.
Needless to say the Aston Martin owner was VERY appreciative to me, so much so I bought a second one for my wife's car
Doc Wheezer is offline
post #8 of 14 (permalink) Old 01-22-2017, 05:27 PM
Turbo Poster
captainfish's Avatar
hey outdoorsguy,
For that Li-ion rechargeable jump starter, why would you consider finding a way to get a permanent connector to + terminal and to a - ground spot? These jump-starters come with alligator clips and aren't they supposed to connect to either the battery or temporarily to the + terminal and a metal spot?
Guess I'm asking why you are looking for a permanent connector for the battery side?
thanks.
Current Owner:
My 2nd 2005 Blue Burgman 650
Previous owner:
1987 Honda Helix
January 2005 Blue Burgman 650
"Blue Lightning"
Photo Gallery:
captainfish is offline
post #9 of 14 (permalink) Old 01-22-2017, 07:57 PM
Insane Poster
@ E.D. :
Ok, that one wouldn't have occurred to me -- but it's definitely a repair that can be done by the side of the road of something that would leave you stranded (I'm assuming this would be a bike-down scenario; in that case duct tape to temporarily re-attach damaged Tupperware would also help.)
And that's my criterion for "what goes into a bike tool/spares kit".
Not all who wander lack GPS.
Whir-chirp-chirp, purr...
Rusty J is offline
post #10 of 14 (permalink) Old 01-23-2017, 12:08 AM
Insane Poster
Dave_J's Avatar
Many years ago while riding off road in sand I hit a sharp rock and popped the rear tire. Tube was done. I was over 10 miles from town. But I happened to have a 40 foot piece of hemp rope. So I packed the tire with sand and tied the tire on with logger hitches wound thru the spokes. As long as I went less than 15 MPH it was OK.
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
A snow emergency zeco Jester's Court 0 01-22-2012 10:59 AM
emergency equipment fwtxsuperscooter Safety Tips and Ideas 18 01-19-2009 10:47 PM
Emergency tow asolof General Discussion 3 08-12-2007 08:44 PM
Emergency kit hatburger General Discussion 16 05-08-2006 03:14 AM
Emergency jumpstarter gruntled Aftermarket and Accessories 9 01-30-2006 03:12 AM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
