Making tight turns - Suzuki Burgman Forum
Reply
post #1 of 20 (permalink) Old 11-11-2015, 12:01 PM Thread Starter
Turbo Poster
Making tight turns
I've seen a couple of articles on making smaller U-turns with a motorcycle. See this month's, (Dec 2015) Rider magazine. But I have never seen an article about doing it on a scooter.
I feel fully confident riding my bike but can't seem to make small U-turns. Any suggestions?
Givi V46 top case with Admore LED tail/stop/directional signals
Modulator headlights
Break-Away cruise control
Hyper stoplight to replace reflector under the license plate
Oznium LED's
Utopia backrest
Garmin Nuvi 1490 GPS with Ram mount
Cramp Buster
X-Large Clearview windscreen
Marv is offline
Sponsored Links
post #2 of 20 (permalink) Old 11-11-2015, 12:13 PM
Active Member
Talked about in this thread:
650 Slow Speed Maneuvering Techniques
Jim
2013 Burgman 650
TNJim is offline
post #3 of 20 (permalink) Old 11-11-2015, 12:16 PM
Turbo Poster
xringracing's Avatar
The rear brake is key... "Feathering the rear brake helps with slow turns while holding a little pressure on the throttle."
2004 Burgman 400
xringracing is offline
post #4 of 20 (permalink) Old 11-11-2015, 12:17 PM
Turbo Poster
By they way, your model of bike is missing from your signature.
2004 Burgman 400
post #5 of 20 (permalink) Old 11-11-2015, 02:04 PM
Turbo Poster
Hussein Adil's Avatar
Garage
Wheels are two gyroscopes balancing the bike weight, but when you slow down these two can not handle the bike weight at slow speeds so you have to use the engine as another gyroscope to balance the weight by giving it some throttle while holding the rear brake a little. This technique does not apply to any bike has it engine crankshaft fitted longitudinally.
Hussein Adil is offline
post #6 of 20 (permalink) Old 11-12-2015, 06:22 AM
Insane Poster
Bluebottle's Avatar
Gyroscopic affects have almost no influence, the bikes geometry and having constant smooth inputs are what make feathering the brake work.
At low speed, what you lose is the
a) ability to shift the bike underneath you quickly by steering
B) castor forces on the front wheel that automatically balance the bike.
The gyroscopic forces of the wheels and tyres are a few Newton Meters at the most. You could easily combat it with your little finger on the riders helmet. A large engine produces about 10% of that amount.
Dragging the brake regulates the engine input and clutch action to make things smooth so they don't unbalance you and place a constant force on the bikes geometry so that it self-corrects.
If gyroscopic effects were the significant stability factor this guy would be having a very different experience.
Bluebottle is offline
post #7 of 20 (permalink) Old 11-12-2015, 06:28 AM
Turbo Poster
Garage
Then explain the counter steering if the gyroscope has no effect.
post #8 of 20 (permalink) Old 11-12-2015, 06:43 AM
Turbo Poster
Garage
These two videos show the effect of the gyroscope even when no one riding the bike it can keep it's own balance:
this is the second one:
Another side effect is the tank slapper issue at high speeds:
post #9 of 20 (permalink) Old 11-12-2015, 06:53 AM
Insane Poster
Bluebottle's Avatar
Countersteering moves the bike out from underneath you so you fall over in the opposite direction and into your turn.
The video shows that the bikes geometry will self correct it (that is why you have castor on the front end) and is the dominant factor in bike stability.
If gyroscopic effects were significant, the bike would have stayed down once it was down, (gyroscopes dont like change, they try to keep on doing what they are doing) geometry will stand it back up again.
Watch the front wheel in that second video. It over corrects a few times and the stabilises. Does that look like a castor img wheel or like a rock steady gyroscope ?
Tank slappers are also a geometry issue.
(Gyroscopic effects would prevent a tank slapper by holding the front wheel still).
There is always an element of precession and gyroscopic stability but it isn't as big as most people think. If it was you would not be able to steer the bike out of a straight line once you got up to speed.
You can calculate the forces mathematically to prove it
post #10 of 20 (permalink) Old 11-12-2015, 07:22 AM
Turbo Poster
Garage
I understand from you that the rider is mostly using his body to balance the bike.
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
still can't make those tight turns debbieg General Discussion 27 03-02-2008 12:23 AM
How do you take really tight turns happytech General Discussion 31 12-02-2007 08:43 AM
tight right and left turns in garages, parking lots. etc. scootervan Newbie Questions! 8 07-10-2007 10:47 PM
Tight right turns - some difficulty db297 General Discussion 59 11-07-2006 10:51 PM
slow and tight turns again? scootervan Burgman 400 (pre-2007) 3 09-18-2005 10:51 AM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
