Making tight turns - Page 2 - Suzuki Burgman Forum
Reply
post #11 of 20 (permalink) Old 11-12-2015, 07:30 AM
Turbo Poster
Hussein Adil's Avatar
Garage
Quote:
Does that look like a castor img wheel or like a rock steady gyroscope ?
Do you mean the caster angle? If so my answer will be both of them.
Hussein Adil is offline
Sponsored Links
post #12 of 20 (permalink) Old 11-12-2015, 07:39 AM
Turbo Poster
Garage
Quote:
Gyroscopic effects would prevent a tank slapper by holding the front wheel still
Actually the gyroscope is causing it because of rider mistake and make it worse by applying more force on the handle bars or due to lose of traction on the road, for that reason i said it's a side effect.
post #13 of 20 (permalink) Old 11-12-2015, 07:46 AM
Super Poster
thebrauns85's Avatar
Garage
"Gyroscopic affects have almost no influence, the bikes geometry and having constant smooth inputs are what make feathering the brake work. "
Totally agree at slow speed (the subject of this thread) ... pretty much disagree at higher speed. The primary forces behind the transition from regular steering at slow speed to counter steering at higher speeds are gyroscopic forces. Certainly there are other factors that are in play, including the bike's design, but gyroscopic affects do have a significant influence on how the bike handles as speed increases.
A simple illustration ... take a wheel off anything you have (a bicycle, a wheel barrow, etc.) and put an axle through the hub. Holding both sides of the hub with each hand, it's easy to move the wheel around when it's not spinning. Start the wheel spinning, and you'll see very quickly the effect of gyroscopic forces.
thebrauns85 is offline
post #14 of 20 (permalink) Old 11-12-2015, 08:07 AM
Turbo Poster
Garage
A spinning wheel can even balance itself on one single end of the axle while the other one is free in the air.
post #15 of 20 (permalink) Old 11-12-2015, 08:11 AM
Insane Poster
Bluebottle's Avatar
A spinning wheel is hard to disturb using the hub, yes - but that is because you only have a 1 inch lever, not because the force is large.
Multiply your lever by 30-40 times and things change dramatically. Its an illustration of levers more than anything else.
I want to point out that I'm not guessing about this stuff - I work on dynamics for vehicle/aircraft manufacturers and the military.
If you calculate the torque from gyroscopic forces on a bike they come out at about 6 NM, that isn't going to hold a bike up.
Bike stability comes from its geometry.
Keep the tyres the same and change the rake of the forks and the bikes stability will change, half a degree will make a significant difference.
A sports bike and a cruiser with exactly the same wheels and tyres have the same gyroscopic forces but the stability will be different. The sports bike will be twitchy and the cruiser will be relaxed because the geometry is different.
The sports bike will be more prone to tank slappers too, again because of its geometry.
Bluebottle is offline
post #16 of 20 (permalink) Old 11-12-2015, 12:38 PM
Insane Poster
There have been made made experiments with counter-rotating discs on the wheels, cancelling out all gyroscopic effects, and they proved that the geometry is the main factor.
ErikDK is offline
post #17 of 20 (permalink) Old 11-12-2015, 04:30 PM
Insane Poster
Bluebottle's Avatar
Dynamicists have done a lot of empirical work over the years and there is solid maths and physics - but that tends to make people's heads bleed
Feathering the rear brake definitely works
Keep the engine steady and control the speed with the brake. Smoothness is the important thing. Notice that increasing your speed will tend to stand the bike up and reducing it will drop it down - but try to stay constant.
On the tank slappers that have been mentioned but are a bit off topic - the main cause is a feedback oscillation. I'm happy to discuss it if anybody wants to go into it.
Note that to a dynamicists you get "wobble" (oscillation at the front wheel countered by the "normal rake"), "weave" (oscillation around the rear wheel, countered by the wheelbase length) and "capsize" (where there is no oscillation - so it is just falling over). Things get complicated but the larger forces and concepts aren't too bad.
post #18 of 20 (permalink) Old 11-12-2015, 06:43 PM
Desert Rat's Avatar
Garage
Quote:
Originally Posted by TNJim View Post
Talked about in this thread:
650 Slow Speed Maneuvering Techniques
This will give you the best answers to your question.
Some of the answers got off track from your question. Nothing wrong with their info just doesn't help you with your problem.
Mike
Black 09 650 Exc Bought 3/30/13 7350 miles, grip puppies & Bearcat backrest.
Darksided 5/8/16 33,215 miles Bridgestone 165/60r-14
07 400 bought 6/08 with 500 miles sold with 46,818 miles 3/23/13
First bike new 1966 blue Honda 175 Scrambler
Romans 10:9
Desert Rat is offline
post #19 of 20 (permalink) Old 11-12-2015, 08:14 PM
Super Poster
san diego joe's Avatar
Garage
After all the foregoing the only I can say is that when making a U-turn from a stop, turn the handlebar all the way over to lock on the side you want to go, lean over on that side then give it the gas.
san diego joe is offline
post #20 of 20 (permalink) Old 11-23-2015, 04:53 AM
New Member
And as you start the u turn, most important, "look where you want to go."
hardybaker is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
still can't make those tight turns debbieg General Discussion 27 03-02-2008 12:23 AM
How do you take really tight turns happytech General Discussion 31 12-02-2007 08:43 AM
tight right and left turns in garages, parking lots. etc. scootervan Newbie Questions! 8 07-10-2007 10:47 PM
Tight right turns - some difficulty db297 General Discussion 59 11-07-2006 10:51 PM
slow and tight turns again? scootervan Burgman 400 (pre-2007) 3 09-18-2005 10:51 AM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
