Malossi variator - Suzuki Burgman Forum
Reply
post #1 of 17 (permalink) Old 11-03-2005, 09:46 PM Thread Starter
Super Poster
Greg's Avatar
Malossi variator
Well finally jumped in and ordered ... Malossi variator and kevlar belt for my Burgman 250
First quoted $79.00 for belt and $395.00 for variator plus freight ...
But I think I got a good deal at $425.00 for both including freight ...
I let you know how it goes ...
Greg ...
OEM belt $150.00
Ex Burgman AN650K3 2003 (Stolen)
Ex Burgman AN250 efi 2003 (Sold)
Ex Suzuki Bandit GSX1250s ABS (Sold)
Ex Vespa GTS300 2011 (Sold)
Ex Yamaha Tmax 2012 (Sold)
Ex Suzuki Vstrom 650 2012 (Sold)
Present Burgman 650 2014 Matte Grey
Greg is offline
Sponsored Links
post #2 of 17 (permalink) Old 11-05-2005, 02:43 AM
Super Poster
I've also stuck my head out and ordered for my B400.... but I've ordered the Polini variator/belt/clutch/spring set instead...
Set me back around US$530 (everything included) from a local workshop for the whole lot....
William Liu
Burgman 400 K3 since 2005
william-liu is offline
post #3 of 17 (permalink) Old 11-05-2005, 03:26 AM Thread Starter
Super Poster
Greg's Avatar
Well my variator turned up friday ...
And I fitted it this morning ... took about an hour or so ...
Straight forward not to hard ... except removal & refitting nut ...
Used impact tool to remove the nut (tight) ...
There was no bolt holes in the fixed hub so had to (don't get scared) use large screw driver into the cooling fins to hold it ... 95nm not to tight ... the fins are thick so all went ok
Quick ride very impressed 90% of the clutch vibration is gone I can only feel it if I make it vibrate by staying with in the clutch engagement rev range ...
I think most of the result is from the revs being higher (800-1000) and the clutch now fully engages on normal take off instead of 1/2 & 1/2 when at lower revs ...
The hole scooter feels smoother and engine is reving higher but it feel like it is running smoother without bogging itself down at to lower rev range ... if you get my drift ...
Quick look at revs at speed
60klmph = 5,900
70klmph = 6,150
80klmph = 6,800
I'll post the before Malossi rpm to speed monday have all that info at work
Full throttle now goes straight to 8,000 when you reach about 40-45klmph it then continues up the rev range as you increase speed ... very nice ...
Even cornering is smoother out of the corner without the bogging down that it had before ...
Post more when I have a good ride during the week ...
Seeeya
Greg ...
William be interested to hear your verdict with polini kit
Greg is offline
post #4 of 17 (permalink) Old 11-05-2005, 07:27 AM
Insane Poster
Quote:
Greg, 8,000 rpms and increases?? Did you mean to say 6,000 rpms?
2015 Vstrom 650
roy_ryall is offline
post #5 of 17 (permalink) Old 11-05-2005, 11:56 AM
Super Poster
Greg,
Glad to hear about your positive review of the Malossi variator so far.... My own review may have to wait... seems like the Polini parts are quite horribly back-ordered....
William Liu
post #6 of 17 (permalink) Old 11-05-2005, 12:07 PM
NormanB's Avatar
Greg - glad to hear the fitting went smoothly and the effect on your 250 was useful, the effect on the 400 is as you can probably imagine now - quite dramatic!
I still miss my olde 400!
An expert = ex is a has been and a spurt is a drip under pressure.
AN650AL0 (new toy)
AN650K4 (Av 44mpUSG) (Sold 11/4/2010)
AN400 - 2001 (Sold 8/13/05)
NormanB is offline
post #7 of 17 (permalink) Old 11-06-2005, 09:25 PM Thread Starter
Super Poster
Greg's Avatar
Quick update on this mornings ride to work ...
Suzuki variator..................Maloossi
60klmph = 4,900...............5,900
70..........= 5,200...............6,150
80..........= 6,000...............6,800
90..........= 6,900...............7,150
100........= 7,500...............7,500
110........= 8,100...............7,900
120........= ?......................8,100
Ran out of freeway this morning, bit hard to go far without catching the traffic ... the 110 & 120 figures are app. due to not enough open freeway to settle on that speed ...
Full throttle with Malossi 7,500 till about 35 - 45Klmph then increases to 8,000 ...
Full throttle any speed above 45Klmph 8,000 ... pulls away smoothly without the rubber band effect ...
Let you know mileage in a week or two when I next fill up ... may be down on original but It maybe because I'm exploring the new performance abit to much ... if you know what I mean
Greg ...
Greg is offline
post #8 of 17 (permalink) Old 11-06-2005, 11:42 PM
WH
Super Poster
I'm finally expecting my 16g rollers to arrive tomorrow (for my 400). I'm hoping this is the best value / money spent. Will post results. Surgery prevents me from installing but have found a scoot shop to do it for me.
Best regards.
Warren
2007 650 Executive
WH is offline
post #9 of 17 (permalink) Old 11-07-2005, 12:05 PM
Super Poster
Well, the Polini parts arrived and it seems.......It seems I may have bitten off a bit more than I can chew! (as in changing the variator/clutch/belt and torque spring at the same time)
Results are not exactly what I expected... The bike revs much more freely now and doesn't bog down around the 3~4K rpms.... (which is what I wanted).... BUT the speed seems to pick up much, much slower than before!
Wondering now what could be the cause..... I've got a feeling it could be the spring (which looked longer than the original, stiffer too I suppose)...
Or could it be the parts take some time to "bed" or run-in?
William Liu
post #10 of 17 (permalink) Old 11-07-2005, 03:39 PM
NormanB's Avatar
Greg - you may be 'getting wrapped round the axle here' - top end - say from 95 Km/hr onwards AND top speed is unaffected by variator changes. The variation you are reporting here is the 'scatter' in results you can expect in the real world when conditions vary in terms of launch speed, terminal speed, road gradients and even reading the tach precisely.
AN650AL0 (new toy)
NormanB is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
malossi variator or j-costa dad66 Newbie Questions! 7 11-14-2010 02:09 AM
Malossi Variator on 08 B400 roy_ryall Aftermarket and Accessories 6 08-12-2009 04:18 PM
malossi vs costa (variator) H5N1 Burgman 400 (2007+ model) 11 01-13-2009 09:33 AM
J.Costa variator and a Malossi Max for my new 08 400 ??? ninja Newbie Questions! 2 05-20-2008 10:49 PM
Malossi Variator Burgman 400 (pre-2007) 2 07-13-2006 03:45 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
