Tire pressure monitoring - Page 2 - Suzuki Burgman Forum
 4Likes
Reply
post #11 of 34 (permalink) Old 10-14-2006, 06:04 PM
NormanB's Avatar
Sorry Wes - but I had my right angle valves (metal) fitted so they point towards the final drive and away from the brake calipers- much easier to access!
An expert = ex is a has been and a spurt is a drip under pressure.
AN650AL0 (new toy)
AN650K4 (Av 44mpUSG) (Sold 11/4/2010)
AN400 - 2001 (Sold 8/13/05)
NormanB is offline
Sponsored Links
post #12 of 34 (permalink) Old 10-14-2006, 06:51 PM
Wes
Missed but Remembered
Wes's Avatar
Yeah, Norman, I have mine the same on the back. It's the front one that was hitting the caliper and it doesn't matter which way you point it. I have it pointed to the right which is easier to reach when it's on the side stand. Sure a lot easier to service than the stock ones anyhow.
Wes Jackson
Nanaimo BC
Canada
Silver '04 650 - My Evil Twin (written off)
HOG Life Member
AMA Charter Life Member
Wes is offline
post #13 of 34 (permalink) Old 10-20-2006, 10:13 PM Thread Starter
Insane Poster
Ragman's Avatar
Here's another option for tire pressure monitoring caps. This looks promising, but I find the delta P in the various color changes a bit high, do you agree with that?
http://www.quik-chek.info/product.htm
The good thing about them is that they only read the tire pressure when you press the top. That allows the regular valve to do its job, preventing air loss from a poorly sealed cap that is always under pressure.
PJ
Scoot's name: Alfie
E52 Maxia Givi box with light kit, Garmin Quest 2, Givi windscreen, Airhawk seat cushion, Cat "O-ring" cruise control, Grip Puppies, Nolan N-102 modular,
Ragman is offline
post #14 of 34 (permalink) Old 10-21-2006, 12:50 AM
Super Poster
BurgBass's Avatar
I got some "Tire Minders" from this site:
http://www.tireminder.ca/
They have been FLAWLESS in operation for over a year. The only "hassle" is that if you can't see the valve stem on the front wheel because it happens to be hidden by the fender, you have to roll the scooter forward or back to check it. Rear tire stem is easy to check because I always use the center stand in the garage.
When I posted this previously, someone opined that they MUST be checked regularly because they've been known to leak. That has NOT been my experience.
'05 Burgman 650 BLUE, Clearview L, Comagination headlight modulator, Givi E52 w/brakelight kit, Jac Vinson Backrest and non-skid pocket liners, Airhawk Medium
Previous bikes:
1981 Honda Goldwing Interstate
1972 Honda CB500
1968 Honda CL175
BOB
BurgBass is offline
post #15 of 34 (permalink) Old 10-21-2006, 01:20 AM
Super Poster
hatburger's Avatar
You must have bought the same model as I did. The self hiding model. It seems that no matter how I stop the bike, the stem is always where you can't see it.
__________________
2005 Suzuki Burgman 650 - Faster Blue / Garmin Quest GPS / Laminar Lip
2008 Honda Goldwing GL1800 - Metallic Red/Navi/Audio/Comfort
hatburger is offline
post #16 of 34 (permalink) Old 10-21-2006, 07:44 AM Thread Starter
Insane Poster
Ragman's Avatar
From the TireMinder site:
Quote:
How often do I need to replace the Tire Minder?
As a general "suggestion" you may consider replacing them each spring or annually on your birthday.
Were you aware of this?
Also they mention the sale of two "matched" caps. I wonder if they're available for 33psi and 41psi (unmatched) as required on the 650? I guess I'll have to drop them a line.
PJ
Scoot's name: Alfie
Ragman is offline
post #17 of 34 (permalink) Old 10-21-2006, 12:32 PM
Super Poster
hatburger's Avatar
Check the link I had in my earlier post. They are available individually in various psi.
__________________
post #18 of 34 (permalink) Old 10-21-2006, 12:34 PM
Super Poster
Both my cars have onboard tire pressure monitoring and I believe this feature will become mandatory on all cars. The cost of the sensors, which are integrated into the valve stems, is pretty reasonable. Motorcycles would be a good application for this technology seeing as how maintaining the correct tire pressure is even more critical on a bike.
Dale_K is offline
post #19 of 34 (permalink) Old 10-21-2006, 12:56 PM Thread Starter
Insane Poster
Ragman's Avatar
hatburger: Right you are the TireMinders being available as single units. I should've read the third line......
I guess I'll go and buy a 2 or 3 sets if they recommend them to be changed yearly. But since I only use the scooter 6 or 7 months, I'll probably go to a 2 year replacement schedule and remove them during the winter storage period.
Thanks for setting me straight.
PJ
PJ
Scoot's name: Alfie
Ragman is offline
post #20 of 34 (permalink) Old 10-21-2006, 01:22 PM
Active Member
cfargo's Avatar
Has anyone here tried the SmarTire product?
http://www.smartire.com/products/motorcycles/index.html
Only $199
Curt Fargo
Burgman 650 w/sidecar
2-Vespa GTS250ie
Vespa LX150
cfargo is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Tire pressure monitoring system - alarm setting rdalr Burgman 650 10 02-23-2013 10:13 AM
Tire Pressure Monitoring Systems. Terry Dill General Discussion 22 02-24-2011 07:49 PM
TIRE PRESSURE JOHN FLETCHER Newbie Questions! 31 03-08-2010 06:39 PM
Wanted: Tire Pressure Monitoring System night-timer Burgman 650 8 07-02-2009 01:00 PM
Tire Pressure Monitoring Louie Burgman Newbie Questions! 22 04-17-2008 01:16 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
