USB charging plug - Page 3 - Suzuki Burgman Forum
 2Likes
Reply
post #21 of 38 (permalink) Old 03-29-2016, 07:32 AM
Insane Poster
AlaskaGuy's Avatar
I USED to run a USB cord off my 12v outlet, using one of those "plug in to make it USB" things. I found the reliability of the connection doing that to be a bit sketchy. Since going with a real USB outlet wired directly to the battery, I've not had any issues....FWIW.
waysu likes this.
AlaskaGuy is online now
Sponsored Links
post #22 of 38 (permalink) Old 04-02-2016, 09:46 AM Thread Starter
Turbo Poster
Quote:
Originally Posted by Scooter_Maniac View Post
BTW, running a charge cord from the glove box is not that bit a thing. I drilled a hole in the glove box just large enough to get the small end of the cord through (30 seconds), took the plastic off the handlebars (two or three minutes and, I believe only required removing a couple of the plastic rivets and unsnapping the plastics), snaked the cord out the back of the glove box and up to the hole where the steering goes through the dash then, along the handle bar to one side, leaving a few inches past where the handlebar plastics end (another few minutes), secured it to a few places to prevent snagging or chafing (another five or so minutes) and finally, replacing the handlebar covers. The only hole is in the top rear of the glove box where it will never show or be of any consequence.
The above was for a 650. On my 400, the only difference was I didn't have to drill a hole. Rather, I took the cord through the battery access hole, then secured the access cover.
You are not paying attention: the charger will not fit the plug in the glove box! The glove box will not close with the charger plugged in!
Founder and president of the New Hampshire chapter of Motorcyclists in favor of global warming.
Jarlaxle is offline
post #23 of 38 (permalink) Old 04-02-2016, 08:07 PM
Turbo Poster
xringracing's Avatar
Quote:
I'm not following all of the story, but there are definitely short plugs. I bought a VERY short plug to use for my GPS from a dollar store... or it might have been from "5 Below". It's almost flush/
2004 Burgman 400
xringracing is offline
post #25 of 38 (permalink) Old 04-02-2016, 09:36 PM
Turbo Poster
Racer X's Avatar
Shortish plug for $5 and a 90degree usb cable from ebay for $2.
Cable runs out corner of glovebox when closed, charges at 2 amp.
Rusty J likes this.
Oct 2015 purchased 2007 Phantom Grey Metallic AN650 - 7000 miles
Feb 2016 and have done more miles in 5 months than the previous owner did in 8 years.
Mar 2016 3 MC tires in 17500 miles then went Darkside - Federal Formosa FD1 165/60r 14 - now 8000 miles in and finding it far superior to the MC tyre's.
Racer X is offline
post #26 of 38 (permalink) Old 04-06-2016, 02:15 AM
Insane Poster
I run a ribbon-cable USB cord through the gap between the glovebox door and the surrounding panel. In dry weather I run it out the top gap (to the left of the latch mechanism) to minimize the length of wire exposed to getting snagged; in wet weather I run it out the bottom gap between the hinges so as to keep the wire from letting/guiding water into the glove box. When parked in wet weather, I'll tuck the loose end into the left upper glove box ('12 and earlier; would need to take a close look at the later models to know if it'd reach).
They're fairly inexpensive these days, as are 12V USB adapters that fit flush into the cigarette lighter receptacle.
Not all who wander lack GPS.
Whir-chirp-chirp, purr...
Rusty J is offline
post #27 of 38 (permalink) Old 05-16-2016, 11:23 AM
Super Poster
Foxyrhei's Avatar
Garage
Quote:
Originally Posted by AlaskaGuy View Post
I like the waterproof one from BikeMaster. It is flat, and flexible, and you can mount it up out of the way rather than on the bars (I don't want any wires on my bars).
Thanks for sharing this solution. Just ordered this charger kit and will try to mount on bottom of handlebar GPS mount to power up my Zumo
Burgman 400A L5 "Iuki"
Burgman 400 K2 "Siuzi" (sold)
Foxyrhei is offline
post #28 of 38 (permalink) Old 05-16-2016, 12:20 PM
Insane Poster
AlaskaGuy's Avatar
Quote:
You are welcome (;
I hope it works for you. I liked it so much that I bought two more to install on my bike. Not sure when i will get around to it. One will be fairly soon, maybe this weekend. The other will go under the seat, which will be a lot of work, so that may be a while.
Recommendation: get stainless steel screws and nuts to mount it, to avoid rust.
post #29 of 38 (permalink) Old 05-16-2016, 03:04 PM
Super Poster
Foxyrhei's Avatar
Garage
You are welcome (;
Thanks for additional recommendation, but I'm pretty sure that will be tight on space and will be able to fix only with plastic clamps to avoid drilling
Foxyrhei is offline
post #30 of 38 (permalink) Old 05-16-2016, 03:23 PM
Insane Poster
AlaskaGuy's Avatar
Well, plastic doesn't rust either (:
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Alternative to hard wired 12V or USB charging output. MacDoc Aftermarket and Accessories 0 10-14-2015 12:45 PM
Garmin Zumo 350 > charging while using it via USB fernando Aftermarket and Accessories 8 03-18-2014 06:13 PM
USB charger. TwoWheelTim Aftermarket and Accessories 1 12-28-2011 01:22 AM
Mini USB charger Buckybuck Aftermarket and Accessories 2 05-28-2010 09:48 PM
USB Memory Sticks NormanB The Tavern 10 01-17-2005 05:58 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
