USB charging plug - Page 2 - Suzuki Burgman Forum
 2Likes
Reply
post #11 of 38 (permalink) Old 03-28-2016, 07:41 AM
Active Member
Boyitgobob's Avatar
Thanks for that link Xring, I ordered one. I have a Ram x mount I switch between the car and the FJR. I was planning on ordering a reservoir mount to use it on the burg but I had to check this out. Btw, instructions for the ram mount say to superglue the rubbers onto the arms. Probably a wise move since this one includes two spare rubbers. There're been a few reports of phones/rubbers coming loose with the ram.
Boyitgobob is offline
Sponsored Links
post #12 of 38 (permalink) Old 03-28-2016, 07:57 AM
Insane Poster
Its not the adapter that I was pointing out but the Powered Hub. The plastic stuff is junk and doesn't last.
westnash is offline
post #13 of 38 (permalink) Old 03-28-2016, 07:58 AM
Insane Poster
The Hub also comes w/ a RAM mount and ball so you don't have to also buy that.
westnash is offline
post #14 of 38 (permalink) Old 03-28-2016, 12:36 PM
Turbo Poster
xringracing's Avatar
Quote:
Originally Posted by Jarlaxle View Post
How, exactly, is that one powered?
If you're referring to my link, it has 2 wires you run down and can tap into the cig plug in the glovebox. I like that the 2 wires have a 3rd outer shield over them both. The usb cover is not as tight as I'd like to keep water out. But Like I said I bought it for the mount. I will wire it up and see if it holds up ok though.
2004 Burgman 400
xringracing is offline
post #15 of 38 (permalink) Old 03-28-2016, 12:44 PM
Turbo Poster
Quote:
I'm still not exatly sure which part you are pointing out. But looking back it says their parts are made in the USA. That's probably a great thing. Downright impressive actually now a days. Not enough for me to pay 5 times the price, but I would pay double if there's a big difference.
2004 Burgman 400
post #16 of 38 (permalink) Old 03-28-2016, 01:27 PM
Insane Poster
Here is a magazine review on the part I am speaking of:
http://ridermagazine.com/2016/01/29/...r-plus-review/
westnash is offline
post #17 of 38 (permalink) Old 03-28-2016, 09:28 PM Thread Starter
Turbo Poster
I already haave a Ram mount for a GPS...just need the power plug.
Founder and president of the New Hampshire chapter of Motorcyclists in favor of global warming.
Jarlaxle is offline
post #18 of 38 (permalink) Old 03-28-2016, 09:49 PM
Insane Poster
AlaskaGuy's Avatar
http://www.bikemaster.com/batteries/...arger-kit.html
You won't be disappointed. If you are, you're only out $20.
AlaskaGuy is offline
post #19 of 38 (permalink) Old 03-28-2016, 11:19 PM
Turbo Poster
Gbjbany's Avatar
Garage
I just bought one of these has a stickyBase or Handle-Bar mount - you will need to feed it to the battery but it has its own - on/off
full disclosure its for my NC700 - but thought it worth a mention
http://www.ebay.com/itm/131734922145...%3AMEBIDX%3AIT
Jeff
2015 Honda NC700XD
2008 Burgman 400
2011 Burgman 650 (sold)
Gbjbany is offline
post #20 of 38 (permalink) Old 03-29-2016, 12:44 AM
Turbo Poster
Scooter_Maniac's Avatar
BTW, running a charge cord from the glove box is not that bit a thing. I drilled a hole in the glove box just large enough to get the small end of the cord through (30 seconds), took the plastic off the handlebars (two or three minutes and, I believe only required removing a couple of the plastic rivets and unsnapping the plastics), snaked the cord out the back of the glove box and up to the hole where the steering goes through the dash then, along the handle bar to one side, leaving a few inches past where the handlebar plastics end (another few minutes), secured it to a few places to prevent snagging or chafing (another five or so minutes) and finally, replacing the handlebar covers. The only hole is in the top rear of the glove box where it will never show or be of any consequence.
The above was for a 650. On my 400, the only difference was I didn't have to drill a hole. Rather, I took the cord through the battery access hole, then secured the access cover.
Darksided AN400 in Lightning Fast White •*GIVI Airflow •Side deflectors • Bestem 929 top case • 19g Dr Pulley Slider Weights • Puppies • Backrest, tunnel bag and top case mods by self
'08 650 • Clearview with vent • Kuryakyn grips • GIVI V46 top case and E21 side cases • McCruise cruise control
Better to have scooted and got lost, than to never have scooted at all.
TRAVEL STOP
Add your Travel Stops, Road/Route Comments and, Recommended Places to the Travel Stops map!
Scooter_Maniac is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
Alternative to hard wired 12V or USB charging output. MacDoc Aftermarket and Accessories 0 10-14-2015 12:45 PM
Garmin Zumo 350 > charging while using it via USB fernando Aftermarket and Accessories 8 03-18-2014 06:13 PM
USB charger. TwoWheelTim Aftermarket and Accessories 1 12-28-2011 01:22 AM
Mini USB charger Buckybuck Aftermarket and Accessories 2 05-28-2010 09:48 PM
USB Memory Sticks NormanB The Tavern 10 01-17-2005 05:58 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
