Windscreen holes to reduce turbulence - Page 3 - Suzuki Burgman Forum
 5Likes
Reply
post #21 of 28 (permalink) Old 03-14-2017, 02:27 PM
Insane Poster
Dave_J's Avatar
Quote:
Originally Posted by E.D. View Post
Thank You Dave_J, I will do that.
Cheers!
I did Double Shim mine. I put two washers under the plastic bracket and the bikes steel sub-frame, then two washers under the shield between the plastic bracket. With this it moves the top of the shield BACK some and down about 3/4 inch.
Dave_J is offline
Sponsored Links
post #22 of 28 (permalink) Old 03-14-2017, 05:00 PM
Insane Poster
but we need that turbulence to dessicate them obnoxious fumes that build up sometimes
never swim nekkid, they'll know who farted
mikeyMarine is offline
post #23 of 28 (permalink) Old 03-20-2017, 03:32 PM
Super Poster
Quote:
Originally Posted by Skunkhome View Post
How do you enlargement the holes with a spade bit without wallowing since you loose the center support for the point when you drill the first hole through?
How does drilling a few holes improve the airflow significantly over and above the slot in the cowl at the base of the windscreen?
I don't remember wallowing being a problem (some small chips but nothing serious). I later used a step drill bit to enlarge the existing holes and add a few more. The step drill bit was a much cleaner solution.
Keep in mind that my 650 is a 2003 with a GIVI windscreen and I wasn't able to shim the windshield like other members. I don't know if the underlying windscreen supports were bent, but adding washers/longer screws meant that the black plastic overlay wouldn't fit properly.
The holes helped to noticeably reduce the turbulence that tended to collect around my helmet. Noise levels didn't seem affected all that much (still ride with earplugs). YMMV, of course. There are so many variables in the equation (bike, rider, gear, roads, traffic, weather) that you have to feel your way along and try things out. Good luck.
Skunkhome likes this.
The Motomaster-Fram-WD40-Slime experiment continues.
Flywheel is offline
post #24 of 28 (permalink) Old 03-20-2017, 07:25 PM
Insane Poster
Dave_J's Avatar
Fly, I too have a 2003 and a GIVI shield. But I did shim mine out. The plastic overlay looks OK to me.
I do not remember what year of Goldwing that I bought a vent from but I cut the hole for it and it fit fine. Pic's of vent (Don't look at the right side of bike)
Dave_J is offline
post #25 of 28 (permalink) Old 03-20-2017, 11:39 PM
Super Poster
Skunkhome's Avatar
I can see the step drill doing a nice job. I pan to use to install my top box.
Skunkhome is offline
post #26 of 28 (permalink) Old 03-21-2017, 05:06 PM
Super Poster
If it's a GIVI top case mount, make sure you use the right allen screw in the right location (IIRC, one is shorter, two are longer). I accidentally used a longer one in the shorter location and punched through the top of the trunk liner, LOL. Fortunately, a foam ear plug sealed the resulting hole nicely.
Flywheel is offline
post #27 of 28 (permalink) Old 03-21-2017, 05:10 PM
Super Poster
Quote:
Yeah, that's why I think the mounting brackets were cross-threaded or bent at some stage. It had scuffs on most of the fairings when I bought it, so it wasn't particularly loved. Comes with the <$3000 CDN pricetag, I guess.
Flywheel is offline
post #28 of 28 (permalink) Old 03-22-2017, 12:26 AM
Super Poster
Skunkhome's Avatar
Thanks for the heads up.
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
HOW TO REDUCE YOUR PICS to 250K to upload Petaluma-Jeff General Discussion 0 07-21-2012 01:29 AM
Best way to reduce backpressure? (windshield question) Paladen Burgman 650 17 07-30-2010 11:06 AM
Stock Windshield Turbulence - Fixed? Daboo Burgman 400 (2007+ model) 8 06-07-2007 01:25 AM
Windshield Turbulence Lance62 Burgman 650 31 02-09-2007 08:07 AM
WIND TURBULENCE FROM TRACTOR-TRAILERS DON E SR. General Discussion 25 11-29-2005 12:51 AM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
