Windscreen holes to reduce turbulence - Page 2 - Suzuki Burgman Forum
 5Likes
Reply
post #11 of 28 (permalink) Old 08-14-2013, 07:37 PM Thread Starter
Active Member
THANK YOU to all those who replied. I'll probably install washers for a start & see what improvement those make.
shavian is offline
Sponsored Links
post #12 of 28 (permalink) Old 08-14-2013, 10:16 PM
Super Poster
Quote:
Originally Posted by ErikDK View Post
I cut 2 50mm (2") holes at the bottom of my cracked Giwi screen as an experiment, and it works so well that I never use the undamaged replacement, which gives more buffeting and noticeably worse fuel mileage.
Hmm. Sounds like I need to enlarge/add more holes.
Flywheel is offline
post #13 of 28 (permalink) Old 08-14-2013, 11:25 PM
Insane Poster
v8eyedoc's Avatar
Garage
Send a message via Yahoo to v8eyedoc
My solution for me on my '08 400 was to just remove the stock factory windscreen and replace it with a Givi...........Very happy now.!!
OWNED:
51 HD EL
Vespa
55 HD KHK
98 Boss Hoss
2 GSXR-1000's
PRESENTLY OWN:
01 Honda GL1800
08 Burgman AN400 Coocase colormatched handguards heated grips Denali lights
"PROUD MEMBER OF THE PATRIOT GUARD RIDERS"
"RIDE WHEN IT'S SUNNY - WORK WHEN IT RAINS"
v8eyedoc is offline
post #14 of 28 (permalink) Old 03-13-2017, 01:31 PM
Insane Poster
E.D.'s Avatar
Quote:
Originally Posted by Dave_J View Post
I added some steel washers under my shield that allows air under. Try that and see.
How many washers did you put under the windscreen? Steel or Rubber Washers? I'm getting a new Givi D257ST for mine.
1977 Honda CB 750 Silver
1977 Penneys 50 Moped Red
1974 Yamaha 360 MX Yellow
1973 Yamaha 80 MX Silver
1972 Honda QA 50 Red
1970 Kaw H1 500 Red
1968 Kaw 120 Scrambler Red
1968 Kaw 120 Scrambler Blue
but Toyota's Rule, no doubt!
John 3:16
Burgman Owners Map:
https://
Burgman Travel Stops Map:
https://
E.D. is offline
post #15 of 28 (permalink) Old 03-13-2017, 02:41 PM
New Member
carlrf42's Avatar
I too have what I would call extreme wind/cold down my neck. It's hard to believe such an age old problem hasn't been figured out and avoided at the mfg. design level. Like the V Strom too, it's different but worse yet. Madstad sounds like a possible answer.
Carl
carlrf42 is offline
post #16 of 28 (permalink) Old 03-13-2017, 03:56 PM
Insane Poster
Dave_J's Avatar
Quote:
You can only get about 1/8 inch of washers without going to a longer screw. I used two stainless steel washers.
E.D. likes this.
Dave_J is offline
post #17 of 28 (permalink) Old 03-13-2017, 03:56 PM
New Member
carlrf42's Avatar
I may be behind the game but I just emailed Madstad and asked them if they had anything for the Burg. here is there reply!
Hi Carl,
Yes, we do have a system for your ride and I have attached some images for you.
This kit includes a pair of adjustable brackets (3" height, 20 degrees angle) the "Sport SD" styled shield, in your choice of height and tint, along with all required attachment hardware. An example of pricing would be $219.95 for the complete kit with a 20" Light Gray shield.
At this time we do not have the Burgman system listed on our website so please give us a call should you decide to order. We will want to know your height and inseam as well as if any seat mods. This will help to recommend a shield size for you.
Thank You!
Blair
Support Team
Support@MadStad.com
(352)848-3056
(352)848-3646
carlrf42 is offline
post #18 of 28 (permalink) Old 03-13-2017, 07:26 PM
Super Poster
Skunkhome's Avatar
Quote:
Originally Posted by Flywheel View Post
Start with a 1/4" spade bit to place the holes. Space them to allow for enlargement if needed. Before you break through, put the drill in reverse and push--this will melt though the last bit and reduce potential cracking. If you're drilling the windscreen while it's on the scoot, put a barrier behind it, so the drill point doesn't prick the dash housing.
Air does flow through even at 1/4" diameter holes, but not much (enough to blow plastic shavings out). I increased the holes to 3/8", then (after a test ride) to 1/2". As I mentioned previously, it seemed to help a bit.
How do you enlargement the holes with a spade bit without wallowing since you loose the center support for the point when you drill the first hole through?
How does drilling a few holes improve the airflow significantly over and above the slot in the cowl at the base of the windscreen?
Skunkhome is offline
post #19 of 28 (permalink) Old 03-14-2017, 03:39 AM
Active Member
ericclapham's Avatar
Nobody's mentioned LeDude's website yet !!!! Refer his section on windscreen removal and shimming. Most comprehensive write-up............... as always. I shimmed the Givi D263ST on my machine so that the top lip moved rearwards, closer to my helmet. At highway speeds, with the screen max. UP, I find that head buffeting is greatly reduced. AS ever, there is a down side i.e. the inside of the screen surface get dirtier, faster and has to be removed for access to wash all the bugs off.
Dave_J likes this.
ericclapham is offline
post #20 of 28 (permalink) Old 03-14-2017, 03:42 AM
Insane Poster
E.D.'s Avatar
Thank You Dave_J, I will do that.
Cheers!
1970 Kaw H1 500 Red
John 3:16
Burgman Owners Map:
https://
https://
E.D. is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
HOW TO REDUCE YOUR PICS to 250K to upload Petaluma-Jeff General Discussion 0 07-21-2012 01:29 AM
Best way to reduce backpressure? (windshield question) Paladen Burgman 650 17 07-30-2010 11:06 AM
Stock Windshield Turbulence - Fixed? Daboo Burgman 400 (2007+ model) 8 06-07-2007 01:25 AM
Windshield Turbulence Lance62 Burgman 650 31 02-09-2007 08:07 AM
WIND TURBULENCE FROM TRACTOR-TRAILERS DON E SR. General Discussion 25 11-29-2005 12:51 AM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
