Corbin Tall/Long Owners - Help - Suzuki Burgman Forum
Reply
post #1 of 19 (permalink) Old 03-06-2012, 09:50 PM Thread Starter
Insane Poster
rustynail's Avatar
First off, let me say that I am quite comfortable on my stock seat. The longest day I've done so far is only 540 miles, but I have found I am easily good for one full tank (around 175 miles) between breaks. I use a sheepskin pad to keep perspiration down.
So, I didn't consider a replacement seat- until I caught wind of the Corbin Tall. I'm 6'4", but it's a lot of leg (36" inseam). That's one of the things that put me on a Burgman 650 over the other competitors (Silverwing, AN400, T-Max). My knees hit the dash.
Still, with the backrest removed, I find I am still a bit cramped (legs only). Also, my knees are higher than my hips when I'm seated, which is bad for low back.
For those around my height, I'd like to know how the tall changes seating position. If I buy the tall, is there a good chance my legs will benefit from the 3 inches gained? Specifically, do you think I can get my knees lower than my hips? Is seat height higher or lower than stock seat? If I sit farther back, but lower, my knees could still be higher than my hips... I'd like to sit a bit higher, too if I can.
It's a big outlay of cash for a farkle I don't need (buttocks-wise, at least). I want to be sure it will fix my leg problem.
Thanks.
Motorcycle **** is riding a loud, heavy cruiser shoed with a car tire on the uninspiring interstate highway system. I chose something else.
rustynail is offline
Sponsored Links
post #2 of 19 (permalink) Old 03-06-2012, 10:56 PM
Insane Poster
Buffalo's Avatar
Re: Corbin Tall/Long Owners - Help
Quote:
I'm not your height (I'm only 5'11") but I am long legged for my height (33 inch inseam) and I am one of the few Corbin long owners that is active on the board so I'll try to answer your questions.
1) If I buy the tall, is there a good chance my legs will benefit from the 3 inches gained? Specifically, do you think I can get my knees lower than my hips?
I think you will benefit from the extra set back, I did. On the stock seat even with the butt stop removed my knees were also higher than my hips and now I can get my legs out so that they are not. I can put my feet up at the top of the upturned part of the footrest and straighten my legs completely out with my knees locked. With 3 inches more leg you might not be able to do that but your should almost be able to.
The seat is just a tiny bit higher than the stock seat but not a lot.
It is also just a little wider at the back most portion of the seating area. I find I must rock forward a little when I put my feet down at a stop because of this extra width.
One other thing you need to be aware of. Because you sit further back on the bike it changes the balance and handling of the bike. To me it seems to make the bike a little slower on the turn in. I compensated for it some by bumping the rear shock preload up to 5.
--- Craig AKA Cliffhanger----
"Big Red" 2007 Red Executive - 134,093 miles
"Little Blue" 2006 Blue 400S - 47,506 miles
Buffalo is offline
post #3 of 19 (permalink) Old 03-07-2012, 12:29 PM
Active Member
dhobin's Avatar
I'm 6'2" and also have a Corbin long. I moved it from my 1st 650 to the one I have now and combined I have over 80,000 miles on it.
I could not ride long distances with the stock seat as my right knee does not bend very far but with the long I don't have any problems.
I love the seat.
I do also have 1" risers which make the handle bar position very comfortable as well.
I did add a stronger piston as the stock one will not keep the heavier Corbin up.
I also have the back rest and I like it as well.
09 650 Exec. (black)
Darkside tire
Corbin seat
Clearview windshield
Poly grip heaters
Brakeaway MC Cruise control
Comagination headlight modulator
Givi E55 topbox
Kurikan ISO grips
Dual FIAMM horns
MB running light mod.
Custom flag mount
Amber strobes
Proud Patriot Guard Rider
dhobin is offline
post #4 of 19 (permalink) Old 03-07-2012, 05:31 PM
Insane Poster
paulcbrowne's Avatar
What did you use for a stronger piston to keep the seat up?
Shepherdstown, WV USA
paulcbrowne is offline
post #5 of 19 (permalink) Old 03-07-2012, 08:29 PM Thread Starter
Insane Poster
rustynail's Avatar
Hmmm. Some things to consider.
I got the Jac Vinson not so much for back support - just to be able to slide back a bit more and still use the stock butt-bumper to some degree. It does get me a bit more leg room, but my tail bone sometimes gets hit by the metal upright when I get bucked by a rough bump. Same thing only to a lesser degree when I run sans bumper altogether.
I don't like what you said about handling, Buffalo. Most often, I am perched on the tip of the seat with legs tucked under me when I am in the twisties - so perhaps it won't be an issue for me. I relax and sit back in the long stretches of straights.
I'm just thinking about the Corbin and might still do it if only because I can recoup maybe as much as 2/3 of the cost by re-selling it here in the classifieds as a barely used item. The resale value on one is pretty good.
I just wish there was someone near me that had one so I could try it out. It's a bigger gamble on fixing the leg issue. I know they have great testimonials for butts, but I don't need one for that...
post #6 of 19 (permalink) Old 03-07-2012, 09:05 PM
Insane Poster
Buffalo's Avatar
It's a minor but noticeable thing. Sliding forward on the seat will move your weight forward and negate it. I sometimes do that when I am serious about running the twisties. Most of the time I just start my turn in a blink earlier and don't worry about it. It's not enough of an issue that it will slow you down any. It's just something to be aware of the first time you head into the twisties so your not caught unaware.
Buffalo is offline
post #7 of 19 (permalink) Old 03-07-2012, 10:44 PM
Active Member
aamigos's Avatar
Garage
I was apprehensive about what Corbin to get. I'm only 6'1, 32" inseam,but wanted to strech my legs out. I decided to bite the bullet two weeks ago, and called Corbin. Those guys are great! We spent time talking about what I wanted, and how to achieve it. They wanted height, weight, and inseam. Then he explained that part of the warranty is that if it isnt right, they'll pay for return shipping, and make it right. I'm actually looking forward to the last week of the month when my seat is due to arrive. Since you're buying a new seat, give them a call, and talk to them.
Dennis
650 K7-Phantom Grey
Clearview XXL w/vent Corbin seat
Givi E50 Topboxw/Luggage rack/Admore light kit
Ram ball mount Drink holder Ram GPS holder
TomTom GPS. RockBox. SpeedoDRD
aamigos is offline
post #8 of 19 (permalink) Old 03-08-2012, 12:22 PM
Active Member
dhobin's Avatar
Here is wher I got mine.
Reinforced piston for opening automatic seat Burgman
Sell ??reinforced pistons for all models 400/650 Burgman.
The piston has a calibrated force to lift the seat completely, see video
http://www.youtube.com/watch?v=-rA0hAR6rrM
Price: € 40.00 + € 16.00 Shipping recommended
paypal payment
Mail: uomo-vitruviano@libero.it
by uomo-vitruvianoTue Jan 10, 2012 15:36 15 Forum: Aftermarket and AccessoriesTopic: Reinforced piston for opening automatic seat BurgmanReplies: 0Views: 154
Darkside tire
Corbin seat
Poly grip heaters
Givi E55 topbox
Kurikan ISO grips
Dual FIAMM horns
Custom flag mount
Amber strobes
dhobin is offline
post #9 of 19 (permalink) Old 03-08-2012, 03:16 PM
Active Member
aamigos's Avatar
Garage
dhobin, did the new piston replace the old one, or did you have to modify? In the video, it looks like the piston is on the left side of the scoot, but mine is on the right side.
Dennis
Dennis
650 K7-Phantom Grey
aamigos is offline
post #10 of 19 (permalink) Old 03-09-2012, 11:15 AM
Active Member
dhobin's Avatar
No modification just swap.
Darkside tire
Corbin seat
Poly grip heaters
Givi E55 topbox
Kurikan ISO grips
Dual FIAMM horns
Custom flag mount
Amber strobes
dhobin is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
corbin tall report johnny ro Burgman 650 3 05-08-2013 12:15 PM
Questions for Corbin Seat & Backrest Owners ted clement Burgman 400 (2007+ model) 7 04-25-2011 05:36 PM
Corbin "long" vs Corbin "close" vs Stock seat pictures suzuki650guy Burgman 650 20 08-10-2010 10:11 PM
Question for Burgman owners over 6' tall gpwitmer Newbie Questions! 18 06-14-2007 11:29 PM
Corbin Owners.. How Wide? ted clement Burgman 400 (pre-2007) 1 04-29-2005 06:09 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
