Front wheel bearing worn out - Suzuki Burgman Forum
Reply
post #1 of 26 (permalink) Old 11-04-2011, 09:36 AM Thread Starter
Super Poster
Renegade1978's Avatar
Tried to get in one more ride before the weather turns bad. Went into a right hand turn, and the front of the bike went "squirrelly" on me. Almost felt like I had a flat tire. I stopped and inspected everything, but couldn't find a problem. Then, on the rest of the ride home, I heard the tell-tale squealing and the instability of the front wheel that told me my problem was a shot bearing. My odometer turned 21,000 miles on this trip, so those bearings must have about a 20,000 mile life to them.
Ordered the new bearings (and a new front tire - I noticed some strange wear patterns on it) from Online Cycle Parts. Great prices. Should get the parts soon and have them installed quickly just in case I can get another ride in before the cold weather. A friend of mine rides a Goldwing, and we have ridden together on Christmas Day for the past 3 years (because the weather rose above 40 degrees F those years). Hope to ride again this year.
Only a biker understands why a dog sticks his head out the car window!
2003 650
Kuryakyn ISO Grips
Givi Windshield & Topcase
Yoshimura exhaust
Racetech Gold Cartridge Emulators
Throttle Boss
Custom Seat by Cary Vincent
Renegade1978 is offline
Sponsored Links
post #2 of 26 (permalink) Old 11-04-2011, 10:52 AM
Turbo Poster
Keith Frye's Avatar
Re: Front wheel bearing worn out
I got 24k miles from my bearings. Sounds about right.
"S.U.B." Sport Utility Bike
400's - 12,500 miles
650's - 6,000 miles
Ride your Harley - I don't give a shift
Keith Frye is offline
post #3 of 26 (permalink) Old 11-04-2011, 12:54 PM
Insane Poster
LeDude's Avatar
Suzuki used single sided sealed bearings on the 03/04 models which are notorious for failing, make sure you get the double sided sealed bearings, I replaced mine on my o4 and it made such a huge improvement, next to no rolling resistance.
Happy Riding . . . . .
LeDude .... . . . . . .
LeDude is offline
post #4 of 26 (permalink) Old 11-04-2011, 01:55 PM Thread Starter
Super Poster
LeDude - just in case I get the old style of bearings (because I already ordered replacements) . . . where can I order the new style?
2003 650
Kuryakyn ISO Grips
Yoshimura exhaust
Throttle Boss
post #5 of 26 (permalink) Old 11-04-2011, 06:21 PM
Ken
Insane Poster
Suzuki usually sends the latest part that is available. The 03 & 04 were prone to bearing failure so I doubt that there are any of the old style bearings in inventory. When I replaced mine, I went to a local bearing supply and bought the best bearings and seals they stocked. Also less expensive than Suzuki dealer. Much more info is available on the top of this forum in a sticky called wheel bearings and seals.
Ken
Blue 2003 Burgman 650
Ken is offline
post #6 of 26 (permalink) Old 11-04-2011, 07:18 PM
Insane Poster
LeDude's Avatar
Quote:
Suzuki had upgraded their bearings to the two sided sealed bearings, if by any chance you get the old kind, you can check out and see if there is a http://www.applied.com dealer/reseller near you...
This is what I got from one of their local wearhouses:
The bearings are readily available from a lot of different sources online.
LeDude is offline
post #7 of 26 (permalink) Old 11-04-2011, 08:17 PM
Turbo Poster
From time to time Suzuki, and probably other manufacturers, use Chinese bearings of dubious quality, mostly due to reduced cost I suspect.
My local bearing supplier, Gopher Bearing, used to carry Chinese bearings as their lowest cost line, but gave up the line due to a high failure rate. My experience duplicates that with the need to replace all 5 wheel bearings on my Kawasaki W650 within the first 14K miles. The two front and three rear bearings were worn enough to allow detectable sideways slack at the wheel rims.
I chose the most expensive European bearings they carried, specified double sided seals and have enjoyed long bearing life ever since. Used these same high quality bearings on the front wheel of my Burgman 400 at about 12K miles, again with good results.
Ray Nielsen, in Minneapolis and going for a ride tomorrow!
Gonpher coughie
ray nielsen is offline
post #8 of 26 (permalink) Old 11-04-2011, 09:01 PM
Super Poster
EthanolBurgman's Avatar
Quote:
Originally Posted by ray nielsen
From time to time Suzuki, and probably other manufacturers, use Chinese bearings of dubious quality, mostly due to reduced cost I suspect. . . . I chose the most expensive European bearings . . . .
+1
I agree that your safety is too important to trust to $5.00 bearings.
I chose (hand-assembled and tested) custom ceramic racing bearings and don't ever think about them at all.
2005 AN650 Burgman ("chipped" ECM) running on E-85 ethanol.
Custom engine oil, transmission and final drive fluids.
BMC (FM388/19) Air Filter. Power Commander III.
Xenon Headlights
EBC HH Brake Pads and Rotors.
TCB on all Brakes.
Metzeler (Made in Germany) FeelFree Tires.
EthanolBurgman is offline
post #9 of 26 (permalink) Old 11-05-2011, 02:17 AM
Insane Poster
Dave_J's Avatar
I get my bearings from http://www.applied.com . Do a search for the closest store.
110,000 miles on a CAR TIRE/DARKSIDE.
Dave_J is offline
post #10 of 26 (permalink) Old 11-05-2011, 10:53 AM
Active Member
I am assuming that replacing both bearings must be fairly easy, since I see no video on the matter. No one has indicated a part number for the bearings! Do we measure both inside and outside diameters to know how to refer the right parts.
Thanks
rdalr is offline
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Search this Thread:
Advanced Search
Similar Threads
front wheel bearing Oldfart@36 Burgman 400 (pre-2007) 3 06-11-2010 02:55 PM
Front Wheel Bearing Life begger55 Burgman 650 8 06-23-2009 12:23 AM
Front Wheel Bearing Replacement rweis Burgman 400 (2007+ model) 4 05-02-2009 11:09 PM
06 Front Wheel Bearing troubles rchrds Burgman 400 (pre-2007) 2 08-18-2008 07:08 PM
front wheel bearing nzdeb Burgman 650 12 07-19-2006 06:53 PM
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
